rvator(at)lindonnet.com Guest
Posted: Wed Jan 11, 2006 4:10 pm Post subject: Need help with HVLP gun |
I got a new HVLP gun (Alltrade from Costco) and attempted to use it this
weekend to prime some parts for my ailerons. Unfortunately, I could not get
a good spray pattern out of it. It seemed no matter what I tried, it would
only spray a very week, splattery pattern - the paint did not atomize very
well at all. I'm using AFS water-based primer, BTW. Pressure was at 40
psi, then increased to 45 (the gun says use max of 43). I did not thin the
primer because I've had good luck spraying it straight out of the bottle in
the past with my high-pressure touch-up gun. I ended up finishing the job
with my old gun, which does a good job, but I was hoping to significantly
reduce the overspray and amount of paint vapor in the air (and wasted
paint).
The little pamphlet that came with the gun was of little help; I tried its
recommendations for changing the flow and pressure. Anybody here have
experience with a top-feed HVLP gun that could give me some pointers?
Thanks much,
Bob Smith
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Wed Jan 11, 2006 6:52 pm Post subject: Need help with HVLP gun |
Bob, you will need to thin the primer or get a different nozzle that has a
larger orifice.
Bret Smith
Mineral Bluff, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
Daniel.Snow(at)wancdf.com Guest
Posted: Thu Jan 12, 2006 5:17 am Post subject: Need help with HVLP gun |
Bob, I have a similar setup and called AFS when I had the same problem. They instructed me to do two very important things: 1) Increase air pressure such that you maintain the required air pressure at the gun with the trigger pulled continuously. That may mean turning the pressure up to 50-60 psi at the tank.
2) Thin, thin, thin. I don't have a viscosity cup, so the guy at AFS told me to thin it up to about 2 parts paint to 1 part water.
Of course you probably already know to just barely fog the pieces with the first pass, wait 3-5 minutes and lightly spray in the perpendicular direction, wait 3-5 minutes and lightly spray, etc.
I don't have the numbers here at work, so I suggest you call AFS. The owner is very friendly and willing to spend time explaining how to use his products.
Good luck.
Daniel Snow
RV-9A wings finished, waiting for slow-build fuse
Jacksonville, AL
Time: 04:10:54 PM PST US
Subject: Need help with HVLP gun
paint).
Thanks much,
Bob Smith
LarryRosen
Posted: Mon Jan 16, 2006 8:43 am Post subject: Need help with HVLP gun |
Here
<http://purplesagetradingpost.com/sumner/techinfo/HVLPspraygun.html> is
a link to some HPLV spray gun set up tips. It is for Harbor Freight
HPLV spray guns, but it may help.
Larry Rosen
RV-10 #40356
<http://lrosen.nerv10.com>
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
