nuckollsr(at)cox.net Guest
Posted: Wed Jul 19, 2006 8:01 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Thanks to the diligence of Jim McCulley we've tried a
modification to SD-8 alternator installations that
appears to be a good solution for getting the SD-8
to self excite. See revision L to Figure Z-25
at:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdf/Z25L.pdf
The Autocad version is at:
http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z24-25L.dwg
It's also been added to Appendix Z which steps the chapter up
to Revison J at:
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
See Note 25 and Figure Z-25
When I get time, I'll update all the other z-figures that use
an SD-8 to include the self-excitation feature.
Thanks again Jim!
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
< with experiment. >
< --Lawrence M. Krauss >
Bob McC
Posted: Wed Jul 19, 2006 9:23 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Thanks Bob (and Jim) - - - BUT - - - according to this modified version of
Z-25 the battery still needs to be in "good functioning condition" in order
to energize the S704-1 relay thus connecting the now self excited SD-8 to
the rest of the electrical system to utilize its output. If the battery is
of sufficient capacity to do this why couldn't we have used this same
capacity to excite the SD-8. What did we gain by its self excitation?? What
am I missing?? I would think an additional modification to Z-25 would be
required to actually make use of this self excitation. No ??
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
Posted: Thu Jul 20, 2006 4:41 am Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Good eye! I was so focused on the SD-8 I dropped the ball
on the system integration. The drawings have been corrected
to add steering didoes so that the disconnect relay will pull in
from either battery or alternator voltage -AND- (in most cases)
still have benefit of the battery to trip the OV crowbar.
At 01:16 AM 7/20/2006 -0400, you wrote:
<robert.mccallum2(at)sympatico.ca>
Bob McC
rv9jim(at)juno.com Guest
Posted: Thu Jul 20, 2006 10:20 am Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Bob,
I just down loaded the drawing I found the dual diodes at the
coil of the relay. Is this the way to energize the coil with the SD8 on
line only?
Jim Nelson
Posted: Thu Jul 20, 2006 5:15 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
At 02:16 PM 7/20/2006 -0400, you wrote:
Bob,
line only?
It provides coil excitation for when ONLY the SD-8 is running
but also provides a path from the battery when it's on line
for providing the high current, short duration source necessary
for crowbar ov protection.
I've got a new LV/OV monitoring system coming onto the 'Connections
pages in the next few weeks that will provide an alternative to the
schematic published. In the mean time, the drawing provided works
too.
mcculleyja(at)starpower.n Guest
Posted: Fri Jul 21, 2006 1:00 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Bob,
Thanks to you for putting together this final product. I am happy that
you were pleased with my help in conducting the experiment.
I'm puzzled, however, by the values of the resistors you listed on the
updated Z-25 drawing. In my message of 5/6/2006, I reported that I found
it necessary to use 15k ohm resistance in series with the added diodes
to avoid the voltage across the capacitor rising above 16 volts while
the SD-8 was not switched onto the buss during maximum RPM.
Also, in my 6/19/2006 message the operating data was acquired while
using 15k resistance in series with the diodes and 3k resistance across
the capacitor. The overall performance and reliability of coming on-line
under all realistic RPM conditions seemed ideal--or did I miss something?
Did you find the lower resistance values of 3k and 1k, respectively,
necessary for overall better functioning? Just curious.
Jim McCulley
<nuckollsr(at)cox.net>
at:
to Revison J at:
Thanks again Jim!
http://wiki.matronics.com
Posted: Fri Jul 21, 2006 7:55 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
At 04:32 PM 7/21/2006 -0400, you wrote:
<mcculleyja(at)starpower.net>
Bob,
Thanks to you for putting together this final product. I am happy that you
it necessary to use 15k ohm resistance in series with the added diodes to
avoid the voltage across the capacitor rising above 16 volts while the
The two resistors form a voltage divider. The voltage across
the capacitor in a totally uncontrolled condition will be a function
of the alternator's pk=pk output at the time. Totally unloaded and
at cruise RPM, I seep to recall that the alternator's output was
on the order of
Also, you mentioned using a 1KuF capacitor. The rule of thumb for
capacitors in this application is 1Kuf per ampere of system
capacity. so 10KuF is the recommended minimum and larger doesn't
hurt anything. I maintained the same ratio (3:1) for the resistor
values in an effort to bring the source impedance of the voltage
divider down to speed things up with the larger capacitor size.
| Quote: | Also, in my 6/19/2006 message the operating data was acquired while using
15k resistance in series with the diodes and 3k resistance across the
capacitor. The overall performance and reliability of coming on-line under
Nope, your experiments were entirely valid. We're just
fine tuning the recipe . . .
| Quote: | Did you find the lower resistance values of 3k and 1k, respectively,
. . . 99.9% sure the lower values are a good move based on common
sense and understanding of how the "fix" works. I'd like
to send you a set of components to install permanently both
to photograph for some installation instructions and to validate
the final design.
I've also forwarded the data on our effort to Tim (at) B&C. He'll
be working with their supplier of the regulator. All of the
components we've added could probably go INSIDE the regulator.
I think we've got a working configuration but we're not yet
arrived at the elegant solution.
Posted: Sat Jul 22, 2006 6:29 am Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Bob,
I've noted a few questions within your following response below:
Jim
> Bob,
> found it necessary to use 15k ohm resistance in series with the added
> diodes to avoid the voltage across the capacitor rising above 16 volts
> while the SD-8 was not switched onto the buss during maximum RPM.
on the order of
What is missing in the above sentence after the word "of"?
Yes, I tested the extremes of capacitance as well as resistance values
by using cockpit adjustable pots, as you had suggested in an earlier
comment. It was from these tests that I concluded the values of 15k and
3k resistors were good at all operating conditions. The capacitance
value is quite acceptable over a large range, but 1kmf is definitely
below the lowest acceptable value.
> across the capacitor. The overall performance and reliability of
> coming on-line under all realistic RPM conditions seemed ideal--or did
> I miss something?
the final design.
Is it possible that B&C would be interested and better equipped to
verify the optimum component values and physical layout via motorized
bench testing wherein the conditions can be better stabilized and
controlled than is the case during either engine ground runs or
in-flight testing as I did? For instance, I noted an apparent variable
in results that I suspect was related to changing component temperatures
over time. This may not be a significant variable but did make
repeatability of data somewhat less than ideal.
jgswartout(at)earthlink.n Guest
Posted: Sat Jul 22, 2006 3:12 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
So, is the "L" version, dated 7-18-06, accessible via the first link in your
7-20-06 post, the right one for now? If not, please direct me to the
corrected drawing. Thanks Bob.
John
Posted: Sat Jul 22, 2006 6:33 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
At 07:01 PM 7/22/2006 -0400, you wrote:
<jgswartout(at)earthlink.net>
Yes. I updated the "L" version and left the link alone.
Posted: Tue Jul 25, 2006 8:05 pm Post subject: SD-8 ALTERNATOR MOD FOR SELF EXCITATION |
Is it possible that B&C would be interested and better equipped to verify
the optimum component values and physical layout via motorized bench
testing wherein the conditions can be better stabilized and controlled
than is the case during either engine ground runs or in-flight testing as
I did? For instance, I noted an apparent variable in results that I
suspect was related to changing component temperatures over time. This may
not be a significant variable but did make repeatability of data somewhat
less than ideal.
Absolutely! That's why I've forwarded the data to Tim at B&C.
I presently have no working relationship with B&C so this
activity is being offered to them as advisory data as opposed
to a directed development effort.
