Hello world...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Piper-List
jack.cunniff(at)gmail.com
PostPosted: Wed Jul 26, 2006 3:37 am    Post subject: Hello world... Reply with quote
Roll call, please?
-Jack Cunniff
'72 Arrow, Norwood, MA
Piper(at) reference from another email list
- The Matronics Piper-List Email Forum -
http://www.matronics.com/Navigator?Piper-List
jdingbaum(at)GMAIL.COM
PostPosted: Wed Jul 26, 2006 4:05 am    Post subject: Hello world... Reply with quote
On 7/26/06, Jack Cunniff <jack.cunniff(at)gmail.com (jack.cunniff(at)gmail.com)> wrote:
--> Piper-List message posted by: "Jack Cunniff" <jack.cunniff(at)gmail.com (jack.cunniff(at)gmail.com)>
Roll call, please?
-Jack Cunniff
Jeff Dingbaum
68 PA-28-180
NW Chicago suburbs
leaving for Oshkosh in the minivan in 15 minutes.
Jeff
jack.cunniff(at)GMAIL.COM
PostPosted: Wed Jul 26, 2006 4:16 am    Post subject: Hello world... Reply with quote
have fun, Jeff. We'll keep the home fires burning.
-Jack
On 7/26/06, Jeff Dingbaum <jdingbaum(at)gmail.com> wrote:
On 7/26/06, Jack Cunniff <jack.cunniff(at)gmail.com> wrote:
Roll call, please?
-Jack Cunniff
Jeff Dingbaum
68 PA-28-180
NW Chicago suburbs
Jeff
rbell(at)hpavet.com
PostPosted: Wed Jul 26, 2006 6:13 am    Post subject: Hello world... Reply with quote
Imagine running it to you here, Jack. I think your's is probably the second
post on this list this year.
Ron Bell
C-172 Ashland, VA
PostPosted: Wed Jul 26, 2006 12:11 pm    Post subject: Hello world... Reply with quote
Hey, Ron.
But as has been pointed out, even this type of chit-chat isn't
appropriate, re the charter for this listserv. I'll stay tuned, but I
think that it's not the right listserv for the conversations we
have...
(healthcare, politics, financial imperialism... oh, and Oshkosh are
the current topics on the "home" list... and it really doesn't belong
on the Matronics list, so we've got to take it elsewhere.)
Good to see you here, though!
-Jack
Ron Bell
C-172 Ashland, VA
rbell(at)hpavet.com
PostPosted: Wed Jul 26, 2006 1:29 pm    Post subject: Hello world... Reply with quote
Well, the matronics lists I've tracked all tend to be pretty focused,
although they get off track sometimes. Of course that's where the Do Not
Archive anywhere in the message comes in. To keep on topic, though, I think
I'll go flying tomorrow after work. Wink
Ron
ACROGUY(at)aol.com
PostPosted: Wed Jul 26, 2006 3:04 pm    Post subject: Hello world... Reply with quote
Gosh, some activity!
I'm flying a 1999 Saratoga with about 1300 hrs since new on the engine.  It tends to blow oil all over the belly.  We're going through a quart about every four hours.  Any ideas?
Jack Stovall
acroguy(at)aol.com
1pouch(at)sbcglobal.net
PostPosted: Wed Jul 26, 2006 3:18 pm    Post subject: Hello world... Reply with quote
don't fill it full . leave it down a quart and it should stop .
Jack Stovall
acroguy(at)aol.com
CHAD FELDPOUCH
FELDPOUCH AVIATION
PHONE: (618) 267-8035
FAX: (618) 283-7285
EMAIL: 1pouch(at)sbcglobal.net (1pouch(at)sbcglobal.net)
PostPosted: Wed Jul 26, 2006 3:23 pm    Post subject: Hello world... Reply with quote
Jack, is it possible the crankcase breather tube has slipped down the
firewall and into the slipstream, and has a higher negative pressure
than is required, sucking more oily vapor from the engine than it
should?
mind you, my Arrow has an oily belly, and the installation of an m20
air/oil separator hasn't solved the problem, but that was one of the
steps I took to troubleshoot the issue.
-Jack Cunniff
N4498T, Norwood, MA
Jack Stovall
acroguy(at)aol.com
rbell(at)hpavet.com
PostPosted: Wed Jul 26, 2006 6:13 pm    Post subject: Hello world... Reply with quote
Have you checked the breather tube?  If it is clogged or not located correctly it could possibly blow oil.  Also, do you fill it all the way up, or do you leave it down a quart or two?  A couple of questions to answer your question.
Wow, this is more activity than I've seen on this list in several years.
Ron Bell
CP-ASEL-IA, AGI
ACROGUY(at)aol.com
PostPosted: Wed Jul 26, 2006 6:36 pm    Post subject: Hello world... Reply with quote
Hey Guys,
Thanks for all the input!  It's a 12 quart system that we've started only putting 10 quarts into.  The problem it that it seems to be happy (not blowing any overboard) at 6.5 quarts. 6.5 quarts makes me waaaaay too nervous as that doesn't seem to be enough volume for adequate cooling. (Although the oil temp gauge shows well within the green arc)
The rubber oil vent lines were extended about four inches past the cowl opening on the bottom of the airplane so I cut them back flush......didn't work.
Again, thanks for the input.
Jack Stovall
ECLarsen81(at)aol.com
PostPosted: Wed Jul 26, 2006 8:22 pm    Post subject: Hello world... Reply with quote
Howdy,
 Ed Larsen
 Luscombe 8F, S-115
 Ypsi, MI
In a message dated 7/26/2006 7:38:35 AM Eastern Daylight Time, jack.cunniff(at)gmail.com writes:
Roll call, please?
-Jack Cunniff
Kellym
PostPosted: Wed Jul 26, 2006 8:47 pm    Post subject: Hello world... Reply with quote
Well, I'm the instigator that suggested some folks at a semi-failing
list move over here. I own a Mooney, have worked on a Cherokee or two,
and a few months ago conned the FAA into giving me an IA certif.
Ron
Kelly McMullen
KCHD
rbell(at)hpavet.com
PostPosted: Thu Jul 27, 2006 1:58 am    Post subject: Hello world... Reply with quote
Conned the FAA? Boy is that an understatement. You can't "CON" the FAA,
they only accept CASH!! <LOL>
Ron
jrccea(at)bellsouth.net
PostPosted: Thu Jul 27, 2006 4:52 am    Post subject: Hello world... Reply with quote
On small Continental engines, the Cub Club recommends silver soldering a tube extension into the oil breather elbow so that extends to the midline of the engine (2.75 inches for the Continental).  It works.  I don't know what the dimension would need to be for the Lycoming, nor do I know if there would be any interference or obstruction in the Lycoming.  Nor do I know how much trouble it might be to 337 it for the Lycoming.  On a C-85-12F, it cut the oil leakage by about 75%.
PostPosted: Thu Jul 27, 2006 5:10 am    Post subject: Hello world... Reply with quote
On 7/26/06, ACROGUY(at)aol.com (ACROGUY(at)aol.com) <ACROGUY(at)aol.com (ACROGUY(at)aol.com)> wrote:
Hey Guys,
work.
Jack Stovall
Jack, Mike Busch has an article on AvWeb on this topic... here's a small extract:
Blow-by is when combustion gasses pass from the combustion chamber into the crankcase, pressurizing the crank case. Oil residue is blown out the breather onto the belly. Blow-by generally is caused by worn or clogged rings, so it is a sign of more critical issues. Additionally, if the crankshaft front seal is worn the airstream can leak past the seal. This also can pressurize the crank case. The proper solution is first to assure that your rings are in decent condition with a compression test as well as a borescope exam. (Clogged rings can sometimes make for a decent compression test, so if you are using a quart of oil an hour and it is not primarily a leak, then your rings are shot regardless of a compression test. Don't fool yourself.) The next step is to be sure that oil breather lines are clear and routed properly, since many times these breather lines are never cleaned in decades and are often misrouted in the course of other maintenance. Proper routing is critical to proper operation of the breather. Given that the rings are OK, the breather lines are routed properly and the front seal is intact, using an air/oil separator is a controversial solution. If your engine is in good condition there should be no reason to need one. Be that as it may, the air/oil separator has a measure of popularity because it is an "easy" if not always successful fix to the symptom rather than a fix to the problem. Some users swear by them; others swear at them. It usually depends on the degree of blow-by you are attempting to control. It is also very installation-sensitive. If you decide to go this route, Aircraft Spruce can provide a selection of products here as well.
This was extracted from http://www.avweb.com/news/maint/192337-1.html
-Jack
ACROGUY(at)aol.com
PostPosted: Thu Jul 27, 2006 6:42 am    Post subject: Hello world... Reply with quote
In a message dated 7/27/2006 8:11:57 A.M. Central Daylight Time, jack.cunniff(at)GMAIL.COM writes:
Jack,
The oil loss rate is about 1 quart every 4-5 hours.  If it were 1 quart every hour, it would be top overhaul time for sure.
Jack
PostPosted: Thu Jul 27, 2006 7:43 am    Post subject: Hello world... Reply with quote
On 7/27/06, ACROGUY(at)aol.com (ACROGUY(at)aol.com) <ACROGUY(at)aol.com (ACROGUY(at)aol.com)> wrote:
In a message dated 7/27/2006 8:11:57 A.M. Central Daylight Time, jack.cunniff(at)GMAIL.COM (jack.cunniff(at)GMAIL.COM) writes:
Jack,
Jack
Hmmm. Well, with the hours you've got on the engine (1300 since new, and no mention of a top or other major work done), maybe this IS a signal that you've got more than a breather tube problem... but at the same time, it's not more than an inconvenience to wipe and buy more oil right now... but maybe a borescope exam wouldn't be a bad idea, if you want to spend a little more money on diagnostics. Warm fuzzies are priceless, even if you've got to spend to get 'em.
I'd say you should be looking at the breather tube first/again/more.
All these are wild guesses - I've got no experience with the 540; my IO360 is an entirely different animal.
Best of luck,
-Jack
PostPosted: Thu Jul 27, 2006 8:45 am    Post subject: Hello world... Reply with quote
I believe this rate is within Lycomings allowable rate of usage.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Piper-List All times are GMT - 8 Hours
