russ(at)wernerworld.com Guest
Posted: Mon Jul 31, 2006 9:25 am Post subject: Further thread on airborne weather services! |
My experience is that it works ok on the ground, but good luck getting a decent signal while flying.
I can never seem to get one above 2000 feet.
Russ
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
cjensen(at)dts9000.com Guest
Posted: Mon Jul 31, 2006 10:59 am Post subject: Further thread on airborne weather services! |
The problem with cell phones in the air0 isn't distance from the tower (you can be right over it 2000 agl and not get0 reception) but the angle of the transmitted beam. Cell towers are designed0 and constructed to issue the beam in a flat, horizontal pattern...after all,0 that's where most people walking around are--on the ground. Once at 10000 agl or above, reception is hit-n-miss, with a bias toward the0 latter.
Chuck
-----Original0 Message-----
From: owner-rocket-list-server(at)matronics.com0 [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of0 GeneHCO(at)aol.com
Sent: Monday, July 31, 2006 2:36 PM
To:0 rocket-list(at)matronics.com
Subject: Re: Further thread on0 airborne weather services!
| Quote: | I have the same Cingular cell phone Pilot- My0 Cast weather experience as Russ. OK on the ground; unreliable signal0 in the air.
Gene Holcomb
bluebird266(at)dslextreme Guest
Posted: Mon Jul 31, 2006 7:55 pm Post subject: Further thread on airborne weather services! |
At 10:25 AM 7/31/2006, you wrote:
Forget it Les it won't work
harry
[quote]My experience is that it works ok on the ground, but good luck getting a decent signal while flying.
Russ
Winnick645(at)cs.com Guest
Posted: Tue Aug 01, 2006 12:37 pm Post subject: Further thread on airborne weather services! |
I installed a Garmin 396 with XM weather in my F-1. If you have the room I would highly recommend it. It is a great product. Subscription is $600/year plus the cost of the 396 but you also get a great GPS, terrain avoidance, and the potential for traffic avoidance when used in conjunction with the appropriate transponder.
Rich
n395v
