kevpow(at)iinet.net.au Guest
Posted: Wed Aug 02, 2006 5:53 am Post subject: engine failure due to filters |
I was interested but not surprised to read about an0 early flight engine failure in the last few days.
Except that I ended in a field on the second flight0 it mirrors my experience exactly.
I put lots of fuel through before first flight0 ,cleaned the filters etc. When after the engine failure I inspected the0 filters there was nothing obviously visible to block both the0 filters.
When I posted the problem there were lots with a0 similar experience. It seems to be only in the early hours of flight that0 the blockages happen. I put a concertina filter in and have had no0 more problems.
My view , without proof , is that some form of fine0 film comes off the interior of the tank in the first few flights.
The problem seems to be specific to the Europa0 style tank not just to fibre glass aeroplanes.
No one has been killed yet . Is it possible0 to warn all builders now of this possibility and ban the small Europa supplied0 filters before someone is hurt.
Kevin Pownall 0 kevpow(at)iinet.net.au
jeff(at)rmmm.net Guest
Posted: Wed Aug 02, 2006 7:27 am Post subject: engine failure due to filters |
Kevin,
I have flown 27 hours off of N128LJ without a problem. I noticed a0
little debris collecting in the left filter so I have switched to the0
right side. I mounted the filters under a door in an arm rest between0
the seats. I can view them in flight if I want to. I will be changing0
them out soon but I don't think anything is wrong with the tanks. I0
believe their may be a fuel issue in some cases or area's. After the0
tanks were drilled we washed them out with a high pressure hose. No0
problems have been encountered yet.... as I'm Knocking on wood.
Jeff
RMMM
On Aug 2, 2006, at 8:45 AM, kevin pownall wrote:
| Quote: | I was interested but not surprised to read about an early flight0
Except that I ended in a field on the second flight it mirrors my0
experience exactly.
I put lots of fuel through before first flight ,cleaned the filters0
etc. When after the engine failure I inspected the filters there was0
nothing obviously visible to block both the filters.
When I posted the problem there were lots with a similar experience. 0
It seems to be only in the early hours of flight that the blockages0
happen. I put a concertina filter in and have had no more problems.
My view , without proof , is that some form of fine film comes off the0
The problem seems to be specific to the Europa style tank not just to0
No one has been killed yet . Is it possible to warn all builders now0
of this possibility and ban the small Europa supplied filters before0
someone is hurt.
Kevin Pownall kevpow(at)iinet.net.au
ksw(at)kenwhit.demon.co.u Guest
Posted: Wed Aug 02, 2006 10:04 am Post subject: engine failure due to filters |
In message <001a01c6b639$f55ef530$e0513bcb(at)HomeWS1>, kevin pownall
<kevpow(at)iinet.net.au> writes
| Quote: | I was interested but not surprised to read about an early flight engine
Except that I ended in a field on the second flight it mirrors my experience
exactly.
I put lots of fuel through before first flight ,cleaned the filters etc. When
after the engine failure I inspected the filters there was nothing obviously
When I posted the problem there were lots with a similar experience. It
seems to be only in the early hours of flight that the blockages happen. I
The problem seems to be specific to the Europa style tank not just to fibre
glass aeroplanes.
No one has been killed yet . Is it possible to warn all builders now of this
possibility and ban the small Europa supplied filters before someone is
hurt.
I believe you are right. I think the problem is related to the
polyethylene fuel tank. It is possible that the fuel can extract waxy
material from the polyethylene tank and more particularly any remaining
polyethylene swarf from the cutting of the access holes. The waxy
material could then coat the nylon filter elements. This series of
events is more likely to occur when the aircraft experiences temperature
cycles, hot testing and then cooling down in the hangar overnight. I
have mentioned this to Europa, but the reply has been that following the
Europa procedures this does not normally occur. All later tanks are
fluorine treated and this should reduce the extraction tendency.
However, there is not an easy solution. The present filters are easy to
inspect and relatively easy to clean. There is nowhere to put a more
conventional filter where it is realistically easy to clean and inspect.
The Andair mini-gascolator has very little more area than the Promax.
The larger gascolator is very difficult to dismantle and re-assemble. I
am no longer building a Europa, but if I were, I had been persuaded to
stay with the existing design, but I would clean the filters frequently
in the early stages. I would also fit a fuel pressure gauge and be
prepared to act quickly to change to the other tank outlet if the fuel
pressure dropped.
Ken Whiteley
Polyethylene Consultancy
josok-e(at)ukolo.fi Guest
Posted: Wed Aug 02, 2006 10:45 am Post subject: engine failure due to filters |
| Quote: | The Andair mini-gascolator has very little more area than the Promax.
Simple question then: Has anybody experienced similar fuel problems
without those automotive filters and a mounted gascolator?
Kind Regards,
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http:www.europaowners.org/kit600
mono xs, top on, gear in, tail wheel in, wings set, flapdrive in, tail
closed, tailwheel in, tail top in, blue stuff filled, sanded and primed,
fuel system in, doors done, windows in, sanding and filling the fuse and
wings.
Dave Miller
Posted: Wed Aug 02, 2006 11:02 am Post subject: engine failure due to filters |
After close to 500 hours Chris Staines recently had to make a precautionary landing, when his fuel pressure gauge reading dropped.
He has an Andair, but no fuel filters on his 914 mono.
The andair filter was covered in something that he described as a green slime, perhaps from a bad batch of mogas.
I'd used some of the same fuel but found no contamination in my Andair.
Dave
"Jos Okhuijsen" <josok-e(at)ukolo.fi>
Sent by: owner-europa-list-server(at)matronics.com
08/02/2006 02:44 PM
Please respond to europa-list
cc:
Subject: Re: engine failure due to filters
--> Europa-List message posted by: "Jos Okhuijsen" <josok-e(at)ukolo.fi>
Kind Regards,
Jos Okhuijsen
wings.
topglock(at)cox.net Guest
My own experience is much like Jeff's. I Used 1.5" metal filters, from the auto parts store for first flight, and pitched them at one hour. Replaced them with same type and pitched them at 25 hours, replacing with same and tossing at 50 hours. At 150 hours, I installed the Europa filters. Checked them at recent annual (200 hours) and they were fine. Cleaned them out and reinstalled. No problems at all.
I did note some restriction in the first two sets of auto filters, though not enough to cause any problems. After that, they are pretty much clean, upon regular 50 hour inspections...
Jeff - Baby Blue
200 hours
JEFF ROBERTS wrote: | Quote: | Kevin,
I have flown 27 hours off of N128LJ without a problem. I noticed a little debris collecting in the left filter so I have switched to the right side. I mounted the filters under a door in an arm rest between the seats. I can view them in flight if I want to. I will be changing them out soon but I don't think anything is wrong with the tanks. I believe their may be a fuel issue in some cases or area's. After the tanks were drilled we washed them out with a high pressure hose. No problems have been encountered yet.... as I'm Knocking on wood.
Jeff
RMMM
| Quote: | I was interested but not surprised to read about an early flight engine failure in the last few days.
Except that I ended in a field on the second flight it mirrors my experience exactly.
I put lots of fuel through before first flight ,cleaned the filters etc. When after the engine failure I inspected the filters there was nothing obviously visible to block both the filters.
When I posted the problem there were lots with a similar experience. It seems to be only in the early hours of flight that the blockages happen. I put a concertina filter in and have had no more problems.
My view , without proof , is that some form of fine film comes off the interior of the tank in the first few flights.
The problem seems to be specific to the Europa style tank not just to fibre glass aeroplanes.
No one has been killed yet . Is it possible to warn all builders now of this possibility and ban the small Europa supplied filters before someone is hurt.
Kevin Pownall kevpow(at)iinet.net.au (kevpow(at)iinet.net.au)
kheindl(at)msn.com Guest
Posted: Wed Aug 02, 2006 11:54 am Post subject: engine failure due to filters |
Can't say I have had any problem with the Andair gascolator. It is mounted
in the fuselage opening in front and next to the new steel springs. Easy to
access and the open position may help to cool the fuel.
Have never noticed tank residue. My trigear is no. 392.
Karl
| Quote: | From: "Jos Okhuijsen" <josok-e(at)ukolo.fi>
Reply-To: europa-list(at)matronics.com
Date: Wed, 02 Aug 2006 21:44:12 +0300
>The Andair mini-gascolator has very little more area than the Promax. The
Kind Regards,
Jos Okhuijsen
wings.
http://wiki.matronics.com
ami(at)mcfadyean.freeserv Guest
Posted: Wed Aug 02, 2006 12:30 pm Post subject: engine failure due to filters |
Can't say I have had any problem with the Flo-ezy filter (at least I think
that's how it's mis-spelt!),
which is similar to the automotive type but has a 100 micron screen
(although it started with a 25 micron screen) and "proper" AN fuel line
fittings, which makes removal easy.
The surface area is 20 sq.ins.
Occasional minor smudges of 'fuel fungi' are picked up, but nothing else
after 300 hours.
Duncan McF.
graeme(at)gcsmith.flyer.c Guest
Posted: Wed Aug 02, 2006 12:53 pm Post subject: engine failure due to filters |
Yes, I have an Andair mini-gascolator and suffered a partial power loss
requiring a forced landing (fortunately overhead the airfield) during
the 2 hr endurance flight which is part of the PFA flight test program.
This was after about 3.5 hrs total flight time. The mesh on the
gascolator did not appear to be totally clogged but had a kind of fine
gunk covering about half the area.
My fuel tank is one of the second design made around 1997. I never found
out what the gunk was, whether it came from the lining of the tank or
was introduced with the fuel.
The hope in replacing the Europa filters with the mini-gascolator was
that the gascolator bowl would be easily removable and so the filter
could be regularly inspected and cleaned, however this has proved not to
be the case due to the fact that the bowl seems to jam on during use,
and with the confined mounting space in the Europa, removing the bowl is
incredibly difficult, and sometimes impossible. On the day of the engine
failure, I was instructed by the test pilot (John Brownlow) to check the
fuel filters. Since I was unable to get the bowl off to check the
filter, I drained the contents of the gascolator into a sight glass and
checked that there was no water or sediment. It was all clear, but I
couldn't see that the filter was already clogged. I don't see the
gascolator as a improvement, although I don't like the Europa filters
either.
Fortunately, I have not had the same problem since, I am more rigorous
about filtering the fuel during refuelling, and cleaning the gascolator
filter at each refuelling despite the incredible hassle in trying to get
the ****ing thing off.
Graeme Smith
No 26
Jos Okhuijsen wrote:
--Kind Regards,
Jos Okhuijsen
primed, fuel system in, doors done, windows in, sanding and filling
the fuse and wings.
--This message has been scanned for viruses and
believed to be clean.
hagargs(at)earthlink.net Guest
Posted: Wed Aug 02, 2006 6:25 pm Post subject: engine failure due to filters |
I went through all the routines and thought I had it licked. Pressure
wash, gas flush, soap and water. Inspection through the hole I cut for the
fuel level transducer. Then using both pumps to run volumes of gas through
the system. I thought I had it pristine. Inspecting the filters had them
"looking good" However comparing a "clogged" filter against a new one only
revealed only a higher degree of opaquenees? Hence my assumption that what
is clogging the filter is the same color as the white element. I would
have been better off not being able to see anything getting a false sence
of security. So my fix is to get a disposable type filter at least 4 times
larger than the supplied units and change them regularly in early flying.
Making sure each one is right before each pump rather than at the outlet of
each side of the tank.
Steve
A143 N40SH
Flying and fixin'
Steve Hagar
| Quote: | [Original Message]
Date: 8/2/2006 8:36:18 AM
Kevin,
Jeff
RMMM
> experience exactly.
> someone is hurt.
nwcmc(at)tiscali.co.uk Guest
Posted: Fri Aug 04, 2006 12:24 pm Post subject: engine failure due to filters |
Having followed the air filter blockage discussion over the last few
years I would like to offer the following as a summary of what has been
learnt so far and what I think can be done to minimise the problem.
1. There are two main types of blockage.
a. That due to swarf from tank drilling.
b. That due to fuel impurities.
2. The swarf problem once solved, should not reoccur but even better not
to have it in the first place. This is not an easy task because it is
difficult to see and it tends to stick to the tank initially due to
static charge. To minimise the spread of any swarf, first place the tank
so any drilling is done from underneath. This stops the swarf falling
away from the hole. Drill slowly to avoid the swarf being thrown away
from the hole. When drilling is complete wipe the swarf around the hole
back through the hole with your finger. If holes are drilled in the top
of the tank for fuel quantity senders there is access to use a pipe on
the end of a vacuum cleaner hose to suck out any remaining swarf. As a
final measure the tank can be rinsed out with water. Before connecting
up the fuel piping forward of the firewall use the electrical pump to
empty the tank several times to catch any contamination before any
engine runs. This can also be combined with calibrating the tank
contents. Also check the filters/gascolator for contamination after each
engine run. Taxi checks will also help to shake the fuel around to
dislodge any remaining swarf.
3. Choice of filters or gascolators. The standard filters will not
collect much swarf before they block up. Larger filters help but a
gascolator is better still. A gascolator also provides an extra water
trap and the filter used in the Andair gascolator is fine enough to
prevent water passing through. Removing, emptying and cleaning/replacing
filters is more difficult with inline filters than gascolators. It is
also easier to incorporate gascolators into a rigid pipe system.
Remember that any rubber hose used should be replaced every 5 years.
Rigid pipework is lighter and a fit and forget system.
4. The only reported case of an Andair gascolator blocking is due to
fuel impurities sticking to the filter. The risk of this is minimised if
fuel is bought from sources with high turnover such as supermarket
filling stations. Another protection measure is to pour the fuel through
a 'Mr Funnel' funnel. This uses the same type of filter element as the
Andair gascolator so should prevent any contaminant getting through to
the gascolator.
5. Removing the gascolator bowl after each flight initially, reducing to
after each service once hours have been accumulated will show up if any
swarf has been missed. Different versions of the Andair gascolator have
different means of attaching the bowl. The bayonet fit version is the
most difficult to remove and refit due to the tight tolerances of the
parts and the seal. This is made easier with a smear of grease between
the parts in the region of the seal before refitting.
I hope this list of points is of help, particularly for those of you
still building. There may be some more tips others can add to this list.
Nigel Charles
peter.rees01(at)tiscali.c Guest
Posted: Fri Aug 04, 2006 1:14 pm Post subject: engine failure due to filters |
Nigel - Thanks for your words on engine failures - in the early days of us
flying it G-MFHI suffered a partial engine failure - the trouble was
isolated to the filter being clogged with fibers. I presume that these were
latent from when the AC was built - I guess at the time of the failure, the
filters were the original ones and the logbook had about 30 hours or so (we
didn't build the AC so can't say for sure but the logbooks show no record of
them being changed).
Some 150 hours later, we're still forced to change the filters very
regularly (we clean them about ever 5 flight hours!) - we're getting small
brown particles coming though and being trapped by the filters. We're at
something of a loss as to what these particles are - we've changed all of
the fuel pipes from the filters backwards. The only hose that hasn't been
touched since new is the filler hose.
Have you heard any instances of this hose breaking down and edpositing bits
into the fuel? Do you think that as a matter of course, given that this hose
is some 10 years old now, replace it. If so, any suggestions of the best
solution - Europa are unable to supply one and have no interest in doing so.
Any comments / suggestions would be most welcome.
Peter
Posted: Fri Aug 04, 2006 3:50 pm Post subject: engine failure due to filters |
Hi! Nigel
I'd also seek to remind everyone about the need to ensure that the exit
hole drillings through the tank connectors are expanded at their
intersection, a check which needs the finger filters removed and
replaced.
I also can confirm that I use a Mini Andair gascolator and find it to be
excellent and without fault, cleaning it's filter at every service
reveals only the most slight contamination.
On Peter Rees problem ......is the filler pipe on your aircraft the
original early one? There was a mandatory change of filler pipes and I
wonder if yours slipped the net?
Bob Harrison G-PTAG
VE3LVO(at)rac.ca Guest
Posted: Sat Aug 05, 2006 6:31 am Post subject: Engine failure due to filters |
Nigel,
Thanks for the timely and interesting run-down on the aspects of
tank and filter. This will not apply to 912 readesr but for us 914ers:
Would you think a continuous running of series/parallel fuel
pumps (with short circuits from output to return line) would forestall some
of this plugging before flight? Since we here have a mandatory engine-run
minimum perhaps we could do the above during that period and allay some of
the suggested gumming/swarf concern.
I have combined my 3/8inch alu tubing with a concentrated
plumbing compartment (in the second of 56 compartments below the extended
baggage section) where the filters are hinged above all so that they are (a)
easily and quickly inspected, and (b) by draining the Andair below, emptied
for dis-assembly and cleaning as required. I'm not sure it would meet with
anyone else's needs but my inspector has OK'd it. If I can master the
technique, will try to reduce photo size and send to anyone interested.
Cheers, and thanks again,
Ferg Kyle
Europa A064 914 Classic
PS: Superb set-up there and hugs for Kathy.
belinda(at)gloverb.freese Guest
Posted: Sat Aug 05, 2006 11:04 am Post subject: engine failure due to filters |
Peter,
I had the replacement Yellow date stamped black fuel pipe supplied F.O.C. by
Europa go exactly the same way as the non date stamped first one.
The aircraft had been filled with fuel (since there is no water trap)and
left standing for some weeks waiting on PFA paperwork and the fuel ate its
way through a full fuel pipe! I sent the original back to Europa for them to
examine but never got any feedback. When the second pipe did the same thing
and the fuel was again found on opening the cockpit, sat in the starboard
baggage bay, I decided that I would have to source my own pipe.
In both cases the pipe had embrittled and cracked right though where the
fuel sat in the lowest part of the pipe. On removal and cutting the pipe,
the inner fuel proof lining was loose and disintegrated. There were lots of
small rubber particles which forced me to flush the tank.
It sounds like you might have a similar problem.
Gary McKirdy
NSI Subaru 75hrs TT Crashed by previous owner (at)50hrs Re-built by me, just
Re-crashed by me, deciding on second re-build!+- 4000 build and rebuild hrs!
g-iani(at)ntlworld.com Guest
Posted: Mon Aug 07, 2006 1:21 am Post subject: engine failure due to filters |
Nigel Charles wrote
" The bayonet fit version is the most difficult to remove and refit due
to the tight tolerances of the parts and the seal. This is made easier
with a smear of grease between the parts in the region of the seal
before refitting."
Just one thing to add to Nigel's excellent summary. The Mini gascolator
(bayonet fit) can be a job to remove but this is due to the Viton "O"
ring being stretched. So fit a new vitron ring at the (cost of 1.65 GBP
each so get some spares) and your troubles are solved.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
