tamara_b(at)telus.net Guest
Posted: Mon Aug 07, 2006 9:42 pm Post subject: ACF50 in the air system |
Gentlemen,
did anybody out there
put ever ACF50 as a corrosion
treatment in the air system of a CJ?
It was recommended
to me by several AMEs
but I am still hesitant.
Elmar (C-FTKL)
a35plt(at)yahoo.com Guest
Posted: Tue Aug 08, 2006 6:50 am Post subject: ACF50 in the air system |
yes, I put ACF-50 in all the CJ's I maintain, both as
an airframe spray to prevent/ stop corrosion and also
in the air system. ACF-50 is a water displacer and
will help prevent the water trapped in your system
from corroding up components such as air tanks, check
valves, water separator, snot bottle, etc. just add it
like you would air tool oil when you service your air
system.
-Robert Starnes A&P
rvfltd(at)televar.com Guest
Posted: Tue Aug 08, 2006 8:33 am Post subject: ACF50 in the air system |
Guys,
Anything you put in the air system should be looked at very carefully. If
it contains chemicals that will cause the rubber seals in the system to
swell it will cause you a ton of grief. So proceed with caution. My advice
is that if you are hell bent to use something other than what the book calls
for you should at least test whatever you use by applying it to a seal and
watching it for 72 hours or so. I have no experience with ACF50 except to
spray it on the skin laps of my float plane, it may be just fine for use in
the air system, I really have no idea. I do know that in the past month I
have sent new seal to a bunch of guys who commented that all their seals
were loose and sloppy....all swollen up.
Always Yakin,
Doug Sapp
Posted: Fri Aug 11, 2006 7:55 am Post subject: ACF50 in the air system |
Yeah... Happens when you put a tad too much oil into the system.
Learned this the hard way.
Mark
