sfdarton(at)yahoo.com Guest
Posted: Fri Jan 20, 2006 7:39 am Post subject: Leading edge splice strip |
To all completed wing builders,
I just clecoed the outboard leading edge onto the main
spar. The aft most rivet shop head of the aft nut
plate is resting on the spar cap and will rub. It
deflects the end of the splice outward about the
thickness of the shop head. Should I make a double
flush rivet to eliminate the shop head for this
interference area? Did any one else have this issue if
so how did you resolve it?
Steve wings 40212
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
jhasbrouck(at)woh.rr.com Guest
Posted: Fri Jan 20, 2006 9:04 am Post subject: Leading edge splice strip |
Steve,
I had same problem and simply set the rivet in the nutplate a little more
to flatten the shop head.
John Hasbrouck
#40264
toaster73(at)earthlink.ne Guest
Posted: Fri Jan 20, 2006 5:29 pm Post subject: Leading edge splice strip |
Ditto - I smushed the shop head right on down - its just a nut plate.
Chris Lucas
#40072
Posted: Fri Jan 20, 2006 8:38 pm Post subject: Leading edge splice strip |
Thanks Guys!
That is what I'll do.
Steve
just a nut plate.
Chris Lucas
#40072
