dlm46007(at)cox.net Guest
Posted: Sat Aug 12, 2006 4:29 pm Post subject: Van's Manifold pressure kit |
Anybody bought that kit? besides the hose what else0 is in it? I am using the GRT EIS as the engine monitor and the tube to their MAP0 transducer is about .125" ID. I have not been able to find a connector between0 the AN807 bulkhead adaptor which is set up for .25"0 ID.
Tim(at)MyRV10.com Guest
Posted: Sat Aug 12, 2006 5:17 pm Post subject: Van's Manifold pressure kit |
That's what the kit has. The hose, and a special bulkhead adapter set
for small tubing.
David McNeill wrote:
| Quote: | Anybody bought that kit? besides the hose what else is in it? I am using
the GRT EIS as the engine monitor and the tube to their MAP transducer
is about .125" ID. I have not been able to find a connector between the
AN807 bulkhead adaptor which is set up for .25" ID.
jesse(at)itecusa.org Guest
Posted: Sun Aug 13, 2006 2:41 pm Post subject: Van's Manifold pressure kit |
We just used the small tubing, then stuck that into a plastic tube into a larger tube like the pitot line, and that into a tube that fit into the MAP sensor. We held them together with silicone.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Saturday, August 12, 2006 8:27 PM
Subject: Van's Manifold pressure kit
Anybody bought that kit? besides the hose what else is in it? I am using the GRT EIS as the engine monitor and the tube to their MAP transducer is about .125" ID. I have not been able to find a connector between the AN807 bulkhead adaptor which is set up for .25" ID.
