tomhanaway
Posted: Sun Aug 13, 2006 4:47 am Post subject: First post-51% rule-private build w/ QB kit |
Hi all,
I'm one of those lurkers that's been thinking about this for three years and am ready to pull the trigger. I apologize if this has been answered before but my search didn't turn up an answer.
Recent discussion of the 51% rule has raised some concerns. I don't pretend to understand the politics behind it but I read the primary direction as towards commercial/multi-unit builders.
My question is (and perhaps I should mail a letter to Van's also) is:
If I build a RV-10 as follows, will I have stayed within the 51% homebuilt rule?
1 Empennage- build at Alexander Tech Center to learn skills (my work under supervision and guidance).
2. Wings and fuselage-quick build kit by myself
3. engine and avionics-installed myself
4. cabin/seat upholstery-outsourced (if necessary, I could do this but it doesn't excite me).
5. painting-outsourced (I definitely don't have the skills or resources for this).
My intent is to build this for myself. Pleasure of building probably greater than pleasure of flying. Will not be selling plane in any sort of foreseeable future.
Is the consensus that I'm in the clear on this or am I treading dangerously close to not meeting the 51% rule? Any suggestions for pursuing a definitive answer prior to ordering stages of kit?
Thanks in advance,
Tom Hanaway
Boynton Beach, FL
Tim(at)MyRV10.com Guest
Posted: Sun Aug 13, 2006 5:21 am Post subject: First post-51% rule-private build w/ QB kit |
I don't see this as a problem for you at all. Any true, legitimate
builder assist like Alexander Tech Center shouldn't be in violation, and
the fact that you're personally there doing the work is what matters.
I think Van's has official approval of the QB wings and fuse under the
51% rule. You can check, but I think this will pass. There's a lot
left undone.
Interior, Panel, and Paint don't even count towards the requirements
at least by the rules that I've heard of...unless something major
just changed. So those won't be any problem. I can't remember if
the engine does or doesn't, but you definitely aren't required to
assemble the engine yourself, and considering you're going to install
it yourself, you're fine there too.
So what you're considering seems to be fine. Unless something
drastic changes, I can't see how you'd have any problem.
do not achive
tomhanaway wrote:
<tomhanaway(at)adelphia.net>
Hi all, I'm one of those lurkers that's been thinking about this for
homebuilt rule? 1 Empennage- build at Alexander Tech Center to learn
skills (my work under supervision and guidance). 2. Wings and
fuselage-quick build kit by myself 3. engine and avionics-installed
myself 4. cabin/seat upholstery-outsourced (if necessary, I could do
this but it doesn't excite me). 5. painting-outsourced (I definitely
Thanks in advance, Tom Hanaway Boynton Beach, FL
jjessen
Posted: Sun Aug 13, 2006 5:49 am Post subject: First post-51% rule-private build w/ QB kit |
Tom,
As I understand it, but I'm not an authority on the topic, Van's is within
the 51% rule, even if you were to buy all quick build components. The
paint, upholstery, fire wall forward (engine, etc) and building the panel
are not counted in the 51% rule. So, as you described what you're up to,
the only question would be Alexander's. I would check with both Van's and
Alexander's. I would think that the latter would have taken this into
account when setting up their program. If it's supervision only, then go
have fun! My guess is you'll be fine.
John Jessen
#40328
tomhanaway
Posted: Sun Aug 13, 2006 9:19 am Post subject: Re: First post-51% rule-private build w/ QB kit |
Thanks for the feedback. Alexander's confirms by telephone and on the website that they meet/observe the 51% standard. Nice to hear that painting and interior upholstery aren't part of the standard.
Tom H.
speckter(at)comcast.net Guest
Posted: Sun Aug 13, 2006 9:20 am Post subject: First post-51% rule-private build w/ QB kit |
You are definitely in compliance. Not even close. Have fun and go for i.
Gary
pascalreid(at)verizon.net Guest
Posted: Sun Aug 13, 2006 4:28 pm Post subject: First post-51% rule-private build w/ QB kit |
| Quote: | the only question would be Alexander's.
Builder assistance is certainly within the rule- Alexander's qualify as
Builder asssitance since the builder isn't assisting them but actually is
the builder getting the assistance.
Lancair does this for months for their builders (and significantly more
expensive at that too!)
Tom;
Best of success with this building- you are more than fine.
