jhasbrouck(at)woh.rr.com Guest
Posted: Sun Aug 13, 2006 5:41 pm Post subject: Riveting forward side skins? |
I've searched the archives with no luck for the answer. How do you buck the three rivets associated with the 1042B clip in the aft end of the lower fuse channel? Looks like I'll need something narrower than what I have to get in there. Suggestions would be appreciated. Did you use the modified elevator bucking bar in the channels for the rest of those rivets? Thanks
John Hasbrouck
#40264
Deems Davis
Posted: Sun Aug 13, 2006 8:20 pm Post subject: Riveting forward side skins? |
John, I had the same question when I got to this point. I ended up
modifying the elevator bucking bar (link to pic attached)
http://deemsrv10.com/album/Sec%2029%20Fuse%20Side%20Skins/slides/DSC02624.html
I puzzled over how to cut the bar, but used a high speed electric
grinder with a metal cut-off wheel, went pretty quickly, Filed it
smooth,and dressed it with the scotchbrite.
Deems Davis # 406
Fuse/Finish/Panel
John Hasbrouck wrote:
| Quote: | I've searched the archives with no luck for the answer. How do you
John Hasbrouck
#40264
Posted: Mon Aug 14, 2006 4:21 am Post subject: Riveting forward side skins? |
Thanks Deems, a picture's worth a thousand words!
