dlm46007(at)cox.net Guest
Posted: Tue Aug 15, 2006 6:25 am Post subject: fuel lube |
A lifetime supply is available in a can from Aircraft Spruce. One pound will last you through all the aircraft you will ever build.
NYTerminat(at)aol.com Guest
Posted: Tue Aug 15, 2006 8:14 am Post subject: fuel lube |
I didn't see it in their catalogue, do you have a part number? I had used some that I borrowed from an A&P to seal the fuel sender in another plane and I wanted to get some for myself.
In a message dated 8/15/2006 10:33:15 A.M. Eastern Daylight Time, dlm46007(at)cox.net writes:
| Quote: | A lifetime supply is available in a can from Aircraft Spruce. One pound will last you through all the aircraft you will ever build.
Jack.Phillips(at)cardinal Guest
Posted: Tue Aug 15, 2006 8:57 am Post subject: fuel lube |
Aircraft Spruce part number 09-25200. Sealube. $20.80 for a 1 lb can, which as someone said will be a lifetime supply. I used it liberally on the last airplane I built and maybe used a couple of tablespoons.
Jack Phillips
#40610
Posted: Tue Aug 15, 2006 1:11 pm Post subject: fuel lube |
Thanks Jack, the confusion is there are other products that sound like the same thing such as EZ turn lubricant"EZ Turn is the functional equivalent of fuel lube" P/N 09-00306
In a message dated 8/15/2006 1:12:22 P.M. Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes:
Jack Phillips
#40610 |
