Tdawson(at)avidyne.com Guest
Posted: Mon Aug 14, 2006 8:33 pm Post subject: 'Y' for SCAT ducting |
Where was a source for a ducting 'Y' splitter for use to split airflow from the engine baffles to direct towards the heater boxes (reference tunnel temps)
Can't seem to find it at Spruce, but you never know what they are going to call some stuff . . .
TDT
40025
Tim(at)MyRV10.com Guest
Posted: Mon Aug 14, 2006 9:12 pm Post subject: 'Y' for SCAT ducting |
I think the 2" Y tube is: 08-04100
I think I myself will try to find a way to get a 2" tube with a
1" or 1.25" branch off it instead. I hate to think that I'd be
bypassing a huge percentage of the air, because I don't want
the heat muff to get too hot. If anyone knows a place that welds
aluminum things like the Y tube, pass the info on...I'd like
to get a custom pair of Y's done. One to feed a fuel pump
cooling shroud, and one to do additional blast cooling.
Tim Dawson-Townsend wrote:
| Quote: | Where was a source for a ducting 'Y' splitter for use to split airflow from the engine baffles to direct towards the heater boxes (reference tunnel temps)
TDT
40025
dav1111(at)cox.net Guest
Posted: Mon Aug 14, 2006 11:29 pm Post subject: 'Y' for SCAT ducting |
I obtained mine from Van's. Item number VENT DL-Y at $19.00. I attached it
directly to the riveted on scat tube flange at the back of the baffle
directing the Y down towards the heater boxes and the primary run down to
the right side heat muff.
Russ Daves
N710RV Flying
flysrv10(at)gmail.com Guest
Posted: Tue Aug 15, 2006 2:35 am Post subject: 'Y' for SCAT ducting |
At Vans. I am expecting mine today.
Do not archive.
TDT
40025<winmail.dat>
Posted: Tue Aug 15, 2006 2:41 am Post subject: 'Y' for SCAT ducting |
Did you do this on both vents? What is the result and how hot is it where you normally fly?
On Aug 15, 2006, at 3:28 AM, Russell Daves wrote:
[quote]--> RV10-List message posted by: "Russell Daves" <dav1111(at)cox.net (dav1111(at)cox.net)>
I obtained mine from Van's. Item number VENT DL-Y at $19.00. I attached it directly to the riveted on scat tube flange at the back of the baffle directing the Y down towards the heater boxes and the primary run down to the right side heat muff.
Russ Daves
N710RV Flying
Posted: Tue Aug 15, 2006 9:55 am Post subject: 'Y' for SCAT ducting |
I did one Y vent off the back baffle scat tube flange. I didn't run a hose down to the heater boxes, only aimed the open Y of the Y Vent towards the firewall right above the heater boxes.
I am in Lubbock, Texas 3200 msl and daytime temps have been 95-100.
Best regards,
Russ Daves
N710RV Flying
mritter509(at)msn.com Guest
Posted: Tue Aug 15, 2006 10:58 am Post subject: 'Y' for SCAT ducting |
Pardon this, but I need to test my hotmail settings.
Mark
[quote]From: "Russell Daves" <dav1111(at)cox.net>
Subject: Re: RE: 'Y' for SCAT ducting
Date: Tue, 15 Aug 2006 12:08:06 -0500
Best regards,
Russ Daves
N710RV Flying
Posted: Tue Aug 15, 2006 11:28 am Post subject: 'Y' for SCAT ducting |
Russ,
Did you put a scat tube on the outlet side of the heat muff to dump the heat
overbroad?
Mark
Best regards,
Russ Daves
N710RV Flying
Posted: Tue Aug 15, 2006 2:33 pm Post subject: 'Y' for SCAT ducting |
Dear Mark & all the RV-10 crowd:
I added the Y vent off the back baffle scat tube flange. I ran scat tube
from the straight exit of the Y vent down to the heat muff and then from the
heat muff to one of the heater vents. I aimed the open Y of the Y Vent
towards the firewall right above the heater boxes. On the left side forward
baffle scat tube flange I ran scat tube from it back to the other heat muff
and then from the heat muff to the other heater vent.
In case somebody hasn't read my other postings about the heater vent
corrective actions they were as follows:
I installed a gasket between the firewall and the heater vents. I installed
RTV around the heater vent opening and door (put wax paper between the RTV
and door) and using the door opening vent cables on the panel closed the
door openings on the heater vents fully closed. After setup of the RTV I
removed the wax paper which now allows the door to seal real good. I then
put RTV all around the outside of the heater boxes and the firewall.
I insulated the inside firewall with foil backed insulation and installed
foil backed insulation on the bottom of the tunnel floor, and 1/2"
soundproofing between the floor panels and the bottom skin.
To date the forward part of the tunnel gets warm but not to hot to lean my
bare leg up against the tunnel (no carpet or covering on either the floor of
the tunnel yet, just bare metal).
