jim-bean(at)att.net Guest
Posted: Tue Aug 15, 2006 3:34 pm Post subject: Wandering Compass |
all,
I am experiencing large swings in the compass of my RV-8. It is a panel mount,
not vertical, from Vans. There is nothing really near it that carries
substantial current, just a G meter and the VOR indicator head. A Garmin 430 is
about 8 inches away. I have all of my fuses/breakers on the side panels so the
main panel has little on it with current flow. Could the rollover hoop be
magnitized? If it is, why doesn't the compass show a constant error rather than
swinging? Or could the (Chinese) compass just be junk?
Confused
Jim Bean
N99JA 37 hours.
n223rv(at)wolflakeairport Guest
Posted: Tue Aug 15, 2006 5:37 pm Post subject: Wandering Compass |
I have never seen a panel mounted compass that works in an RV. Mine
would never swing east, no matter what....
The only one I have ever seen work is above panel mount.
-Mike
sportav8r(at)gmail.com Guest
Posted: Tue Aug 15, 2006 7:01 pm Post subject: Wandering Compass |
My whiskey compass would swing crazily in response to control stick movements on the ground.. the pax stick was magnetized and too near the compass. A switch to aluminum tube for the right stick corrected this. I have no clue why Van supplies steel for this part when aluminum seems plenty robust for the task and is lighter and nonmagnetic. I plan to replace the pilot's stick with aluminum one day, if I can locate proper OD tubing - haven't bothered to look for it yet. Look after the ounces and the pounds take care of themselves...
-Stormy
On 8/15/06, jim-bean(at)att.net (jim-bean(at)att.net) <jim-bean(at)att.net (jim-bean(at)att.net)> wrote: [quote]--> RV-List message posted by: jim-bean(at)att.net (jim-bean(at)att.net)
all,
FLYaDIVE(at)aol.com Guest
Posted: Tue Aug 15, 2006 11:57 pm Post subject: Wandering Compass |
In a message dated 8/15/06 7:38:08 PM Eastern Daylight Time, jim-bean(at)att.net
writes:
| Quote: | all,
mount, not vertical, from Vans. There is nothing really near it that
carries
| Quote: | substantial current, just a G meter and the VOR indicator head. A Garmin
430
| Quote: | is about 8 inches away. I have all of my fuses/breakers on the side panels
so
| Quote: | the main panel has little on it with current flow. Could the rollover hoop
be
| Quote: | magnitized? If it is, why doesn't the compass show a constant error rather
than swinging? Or could the (Chinese) compass just be junk?
Confused
Jim Bean
N99JA 37 hours.
Jim:
The Chinese invented the compass, except way back then it was a South seeking
instead of North. Maybe it is trying to revert back to its ancestry?
A simple check for electromagnetic fields can be done by starting the engine,
then shut off the Master and ALL circuits. Then one item at a time turn it
on observe the compass and then turn it off.
Did the compass ever work correctly in the installation?
Does the "swings" maintain a constant error?
Have you ever adjusted the "Swing" of the compass?
Get a Good Boy Scout Compass and work it around the panel while going through
the power ON / Off steps. It will POINT to the problem area.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Wed Aug 16, 2006 12:48 am Post subject: Wandering Compass |
Jim,
See if you can get hold of 'growler' I think they are commonly used for
demagnetising starter armatures (SnapOn tools?). Plug it into the mains
and wave it over all the steel parts. This will make a huge difference
to the compass performance.
It might be a good idea to remove the compass (and any other
magnetically sensitive items) before degaussing the steel.
Doug Gray
On Tue, 2006-08-15 at 23:32 +0000, jim-bean(at)att.net wrote:
all,
Confused
Jim Bean
N99JA 37 hours.
krhooper(at)gmail.com Guest
Posted: Wed Aug 16, 2006 4:33 am Post subject: Wandering Compass |
An easy way to check for magnetized items is to use a non magnetized steel sewing needle suspended by a thread near all steel parts. If you need to remove a magnetic field, a Weller pistol type soldering gun will do the trick. Just pull the trigger and hold it near the object. It is best to make sure the needle is demagnetized before starting and after it touches any magnetic item.
Randy Hooper
On 8/16/06, Doug Gray <dgra1233(at)bigpond.net.au (dgra1233(at)bigpond.net.au)> wrote: [quote]--> RV-List message posted by: Doug Gray <dgra1233(at)bigpond.net.au (dgra1233(at)bigpond.net.au)>
Jim,
Doug Gray
On Tue, 2006-08-15 at 23:32 +0000, jim-bean(at)att.net (jim-bean(at)att.net) wrote:
| Quote: | --> RV-List message posted by: jim-bean(at)att.net (jim-bean(at)att.net)
all,
Posted: Wed Aug 16, 2006 4:54 am Post subject: Wandering Compass |
My compass gave me fits at frirst, due to magnetism in the pax side joystick. Replacing that piece with aluminum tube cured the compass' tendency to follow the joystick left and right. Not sure why the joysticks aren't aluminum anyhow; seems amply strong for the task and certainly lighter and nonmagnetic. What sort of control forces was Van engineering for when he did that, I wonder?
-Stormy
On 8/16/06, FLYaDIVE(at)aol.com (FLYaDIVE(at)aol.com) <FLYaDIVE(at)aol.com (FLYaDIVE(at)aol.com)> wrote: [quote]--> RV-List message posted by: FLYaDIVE(at)aol.com (FLYaDIVE(at)aol.com)
In a message dated 8/15/06 7:38:08 PM Eastern Daylight Time, jim-bean(at)att.net (jim-bean(at)att.net)
writes:
| Quote: | all,
carries
430
so
be
Confused
Jim Bean
N99JA 37 hours.
Jim:
the power ON / Off steps. It will POINT to the problem area. [quote][b]
khorton01(at)rogers.com Guest
Posted: Wed Aug 16, 2006 6:04 am Post subject: Wandering Compass |
It might be acceptable to replace the passenger stick with an
aluminum one, but I would be hesitant to do this for the pilot's
stick. An aluminum pilot's stick might be OK for normal flight
conditions, but there have been cases on RVs, and other aircraft,
where something jams the controls. In this case, the pilot may need
to exert a very high force on the stick to overcome the jam. If the
stick bends or breaks before the jam is overcome, then this leads to
an accident.
Kevin Horton
On 16-Aug-06, at 7:53 AM, Bill Boyd wrote:
| Quote: | My compass gave me fits at frirst, due to magnetism in the pax side
finn.lassen(at)verizon.ne Guest
Posted: Wed Aug 16, 2006 8:19 am Post subject: Wandering Compass |
My guess it's more a point of ease of fabrication. I mean the weldment
at the bottom.
Now you have too go and make it complicated, splitting the thing into
two: steel weldment at the bottom and alu stick at the top
Finn
-Stormy
Posted: Wed Aug 16, 2006 9:19 am Post subject: Wandering Compass |
Good thought, Kevin. My guess is something else in the "drive train" like a bellcrank would give way first, but that's purest speculation on my part. I have no desire to test the elevator or aileron linkages to failure just to see what gives first. The hardest force I've ever held on the controls in flight was the time my trim control deck left me stuck with inop elevator trim in the landing config and I was in takeoff and cruise mode. Fought that for 20 minutes with about 15 lbs?? of forward stick force before I gave up and returned to land and fix it at home rather that press on to the destination. There are no standard flight maneuvers I can think of that call for anywhere near that force in an RV. My arms were like jell-o when I landed, from isotonic muscle fatigue. Since I was using a stgeel joystick, I suppose that proves nothing to the present point
-Stormy
On 8/16/06, Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)> wrote:[quote] --> RV-List message posted by: Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)>
an accident.
Kevin Horton
[quote] My compass gave me fits at frirst, due to magnetism in the pax side
