CJohnston(at)popsound.com Guest
Posted: Tue Aug 15, 2006 2:46 pm Post subject: spray ceramic heat barrier |
Hey all -
Just thought I'd pass along a bit of info... I'm at the point in the
fuse that I'm trying to head off any heat issues (you all know what I
mean) and I ran across this stuff.
http://www.lizardskin.com
I just got off the phone with the guy, and it seems like this stuff will
be helpful. It's not cheap though...$189 a gallon. Heat rejection,
moderate fire protection, insulation. Sounds pretty good. Also,
according to the guy, the weight of the product after drying is 3lbs per
gallon. Pretty good. Also, he says that it will stick fine to epoxy
primer, and stays pliable, no cracking etc. I've ordered a gallon, and
I'm going to test it out a bit and see if it lives up to all the hype.
Oh - don't go ordering the sound control formula - I think the guy said
that stuff weighs somewhere around 13lbs per gallon!
cj
#40401
fuse
finished rolling my fuse skins!! Only had to reorder one
pascalreid(at)verizon.net Guest
Posted: Tue Aug 15, 2006 3:47 pm Post subject: spray ceramic heat barrier |
let us know when the day comes that you test this. Looks like a nice
solution.
Thx
