zackrv8
Posted: Thu Aug 17, 2006 6:19 pm Post subject: MVP-50 Fuel Flow Transducer |
If anyone is going to use the MVP-50 from Electronis Intl like I am, you might save yourself some time and NOT install the fuel-flow transducer bracket in the tunnel.
EI does NOT use the FlowScan transducer. They use their own that they designed. They do not want it mounted "rigid." They want it mounted on a flex line just before the fuel goes into the divider. They told me they reason for that is that they want fuel "PUSHED" into the Transducer and not possibly "PULLED" by the engine fuel pump.
Zack
_________________ RV8 #80125
RV10 # 40512 |
