Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 26321 Location: Livermore CA USA
Posted: Tue Aug 29, 2006 10:54 am Post subject: XA-D210 and XA-D211 Pinouts |
At 05:13 AM 8/29/2006 Tuesday, you wrote:
Quote: | --> XDP4000X-List message posted by: Christopher Scoles <crscoles(at)yahoo.com>
Hi everyone. I am new to your list. I thought I would introduce myself. My name is Chris. I have had a Sony ES 910 for years and am now finally starting to build out the system. I recently picked up an XDP-210EQ. I looked for a 4000 for a while, but they seem to be very hard to come by. My first question is regarding the XA-D210/211 adaptor. I have been trying to pick one up for a while. There were two on ebay just recently, but I lost out on both auctions. Anyway, I been through your archives researching alternatives to the adaptor. I was specifically looking for the actual pinout for the plug. I know there are three different channels, VCC, Data, and Ground. What I couldn't find is which ring on the plug is which? The reason I ask is because, I found this converter, http://cgi.ebay.com/Audio-Authority-977T-977TPO-Digital-Converter_W0QQitemZ5805001032QQihZ008QQcategoryZ14968QQssPageNameZWD1VQQrdZ1QQcmdZViewItem. I believe it will work if you
could get a cable with the correct plug configuration on the head unit end. Any thoughts, opinions, or help would be appreciated. Thanks.
Chris |
Hi Chris,
These guys might have one (scroll to the bottom of the page):
http://www.mcs-direct.co.uk/acatalog/Sony_Accessories.html
Also, the German Amazon.de seems to list it:
http://www.amazon.de/gp/product/B00006OAHH/028-1978638-1838131?v=glance&n=562066
And here as well:
http://www.edbpriser.dk/Listprices.asp?ID=147035
I took a look at the schematics on the CDX-C90 today and found a little information on the pinout for the XA-D210/D211. I've included a snippet of the schematic below that details the specific information related to the XA-D210/D211.
Looks like Pin1=VCC (+5v), Pin2=Data, and Pin3=Grd. This probably means, that for the XA-D210, the TIP is +5v, the next in ring is DATA, and the shoulder is Ground (connection closest to the plastic).
You should verify this with a Volt meter and optionally a oscilloscope.
As far as a digital to toslink converter, you might also want to take a look at your local Radio Shack. They used to have a number of devices for converting. Seems like they were around $20.
Best of luck!
[img]cid:.0[/img]
| - The Matronics XDP4000X-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?XDP4000X-List |
Description: |
Filesize: |
126.64 KB |
Viewed: |
1259 Time(s) |
Description: |
Filesize: |
68.63 KB |
Viewed: |
1097 Time(s) |
_________________ Matt Dralle
crscoles(at)yahoo.com Guest
Posted: Tue Aug 29, 2006 12:11 pm Post subject: XA-D210 and XA-D211 Pinouts |
Thanks Matt,
I contacted MCS a while ago, they don't ship outside the UK. I have no idea about the Danish company. My girlfriend lives in Germany, so I will probably go that route if I can't figure something out.
The reason I chose the Audio Authority one was because it was the only one that runs off 12v DC. Everything else seems to be 6V-9V. I figured it would be fairly easy to wire it to turn on with the head unit instead of finding a cigarette lighter power adapter or something of that sort.
Posted: Tue Aug 29, 2006 12:17 pm Post subject: XA-D210 and XA-D211 Pinouts |
6-9v is actually what you want. You've already got 5v coming from the C90 for powering the XA-D211. That should be sufficient to power the other devices. That way you don't have to mess with extra power and how to turn it on and off.
Matt
At 01:09 PM 8/29/2006 Tuesday, you wrote:
[quote]Thanks Matt,
Posted: Wed Aug 30, 2006 9:58 am Post subject: XA-D210 and XA-D211 Pinouts |
Well, this just became a moot point. I found an XA-D210 on ebay. So, I am all set.
But, because the discussion was interesting, I will continue my line of thought. I had thought of using the 5V out of the plug, but that seemed a little more complicated to get at. 12V tends to be very easy to find in the car. I could have ran a wire from the 12V turn on wire or power antenna lead. I think that would have been easier than trying to concoct a way to get the 5V off that plug.
Chris
