ericparlow(at)hotmail.com Guest
Posted: Tue Aug 29, 2006 4:03 pm Post subject: Wiring diagram software |
What software is available to make wiring diagrams at a reasonable cost?
Eric Parlow
RV-10 Avionics
earl_schroeder(at)juno.co Guest
Posted: Tue Aug 29, 2006 7:12 pm Post subject: Wiring diagram software |
Try this for starters:
http://www.matronics.com/searching/ws_script_short.cgi
Eric Parlow
RV-10 Avionics
brian-av(at)lloyd.com Guest
Posted: Tue Aug 29, 2006 8:15 pm Post subject: Wiring diagram software |
On Aug 29, 2006, at 5:01 PM, Eric Parlow wrote:
cost?
How about an engineering notebook and a Sharpie.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
nuckollsr(at)cox.net Guest
Posted: Wed Aug 30, 2006 4:12 am Post subject: Wiring diagram software |
At 03:10 AM 8/30/2006 +0000, you wrote:
If one wishes to take advantage of the AutoCAD wirebook
drawings downloadable from our website at:
http://aeroelectric.com/PPS
you can acquire any version of TurboCAD v7.0 or higher
like item 270022950768 on
http://ebay.com
Browse through the directories in the link to our
website and you'll find AutoCAD .dwg files that probably
contain 98% of your proposed wirebook already drawn up
for you.
All you need to do is import, edit to your needs, save
and print the page per system drawings needed for your
project.
Here's the list of commands that cover 99% of all my
AutoCAD actions:
AR, *ARRAY
B, *BLOCK
WB, *WRITEBLOCK
BR, *BREAK
CI, *CIRCLE
C, *CHANGE
CH, *CHAMFER
CO, *COPY
D, *DIMSTYLE
DI, *DIST
DO, *DONUT
DT, *DTEXT
E, *ERASE
ED, *DDEDIT
EL, *ELLIPSE
XT, *EXTEND
EXIT, *QUIT
F, *FILLET
H, *HATCH
I, *INSERT
L, *LINE
LA, *LAYER
LI, *LIST
LT, *LINETYPE
M, *MOVE
MI, *MIRROR
OF, *OFFSET
OS, *OSNAP
P, *PAN
PE, *PEDIT
PL, *PLINE
PG, *POLYGON
P, *PURGE
R, *REDRAW
RG, *REGEN
RT, *RECTANGLE
REN *RENAME
RO, *ROTATE
S, *STRETCH
SC, *SCALE
SCR, *SCRIPT
T, *TRIM
V, *VIEW
XP, *EXPLODE
Z, *ZOOM
AutoCAD, TurboCAD and others are capable of
responding to hundreds of commands . . . ALL of
which are described in the well rounded tutorial.
However, if one acquires a proficiency in the
short-list cited above, I believe you'll find
that a $low$ copy of TurboCAD will be exceedingly
useful not only for your wirebook tasks . . . but
lots of drawing tasks for other projects. It's
a good resource and skill to acquire.
rv-9a-online(at)telus.net Guest
Posted: Sat Sep 02, 2006 7:07 pm Post subject: Wiring diagram software |
How about free, with a complete design already done that you can edit as
you want?
See http://vx-aviation.com/page_3.html
All of the details are available there to download what you want.
Vern Little
Eric Parlow wrote:
Eric Parlow
RV-10 Avionics
Hopperdhh(at)aol.com Guest
Posted: Sun Sep 03, 2006 4:41 am Post subject: Wiring diagram software |
Vern,
Thanks for making this available. I already had ExpressPCB, so I downloaded your schematic and symbols for future use.
Dan Hopper
RV-7A
In a message dated 9/2/2006 11:10:05 P.M. Eastern Daylight Time, rv-9a-online(at)telus.net writes:
| Quote: | --> AeroElectric-List message posted by: Vern Little <rv-9a-online(at)telus.net>
you want?
Vern Little
Eric Parlow wrote:
| Quote: | --> AeroElectric-List message posted by: "Eric Parlow"
Eric Parlow
RV-10 Avionics
= Use lities Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> nbsp; - NEW MATRONICS LIST WIKI -
_-= ; p; - List Contribution Web Site ; =========================
Posted: Sun Sep 03, 2006 6:11 am Post subject: Wiring diagram software |
Vern,
Thanks, Exactly what I was looking for.
Your site is very helpful and I appreciate you making the program available.
ERic--
RV-10
Avionics
