hdwysong(at)gmail.com Guest
Posted: Thu Aug 31, 2006 10:59 am Post subject: downside of manual battery disconnects? |
Does anyone have any experience with the manual battery
disconnects that the hot rod folks use?
Has anyone heard any issues with corrosion or failures or
horror stories floating around about these things?
Are certain brands better than others?
Are any (for whatever reason) more suitable for aircraft use
than others?
Thanks for the insight!
D
chaztuna(at)adelphia.net Guest
Posted: Thu Aug 31, 2006 1:43 pm Post subject: downside of manual battery disconnects? |
---- D Wysong <hdwysong(at)gmail.com> wrote:
than others?
D
D
I would suggest getting a brand name unit. The German made Hella brand is very good quality. You can find them at your local marine supply store.
Charlie Kuss
nuckollsr(at)cox.net Guest
Posted: Fri Sep 01, 2006 3:49 am Post subject: downside of manual battery disconnects? |
At 02:03 PM 8/31/2006 -0500, you wrote:
Does anyone have any experience with the manual battery disconnects that
Piper Tri-Pacers and Pacers of the 1950's had manual
battery master -AND- starter switches in them. While
they limited the options for location (had to have fat-wire
control devices in reach of pilot - and generally NOT on the
panel) they functioned as intended.
| Quote: | Has anyone heard any issues with corrosion or failures or horror stories
Everything corrodes. Most switches in service die of
environmental issues . . . not from service stresses.
| Quote: | Are certain brands better than others?
The use of these devices is so small a part of the
constellation of choices as to make any significant
field comparisons of devices difficult if not impossible
| Quote: | Are any (for whatever reason) more suitable for aircraft use than others?
Airplanes are not terribly unique . . . especially if one
crafts a failure tolerant design. Suppose your battery
switch DOES crap . . . so what? If you're wired like a
Tripacer, then your panel is black. If you're wired like
Z-11, it's no big deal. Take a peak at:
http://harborfreight.com and search for item 92688-1VGA
< with experiment. >
< --Lawrence M. Krauss >
FLYaDIVE(at)aol.com Guest
Posted: Sat Sep 02, 2006 4:11 am Post subject: downside of manual battery disconnects? |
In a message dated 8/31/06 5:31:02 PM Eastern Daylight Time,
hdwysong(at)gmail.com writes:
| Quote: | Does anyone have any experience with the manual battery
than others?
D
D:
I am not familiar with the Hot Rod system but I am very familiar with the
Boat system. I have designed a dual battery system around a very robust and easy
to use A - B Battery switch. Corrosion should not be an issue since it is
enclosed and designed to work around salt water.
Go to your local chandlery and see what they offer.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
