nuckollsr(at)cox.net Guest
Posted: Sun Sep 03, 2006 8:18 am Post subject: The alternator drive stand . . . |
I took a short trip yesterday in 'ol blue (a truck I inherited from
Dad) to take a look at the alternator drive stand I spoke of last
week. What a magnificent machine! Motor controlled variable speed
drive, well instrumented, self contained system simulator with
batteries, really beefy carbon pile load. Minimal barn-bird-crap
and rust. Best yet, mounted on casters.
Now the down side . . . it's fitted with a 10 hp, 440v three-phase
motor. I've been digging through the catalogs for reasonable
replacements that will run from the electron-pipe that comes into
my house.
I think I've identified a 5 hp, 240v single phase with the right
shaft diameter . . . and it's only $400 plus another $100 shipping.
When you're talking this size of motor, they start getting HEAVY!
I've made an agreement with the current owner to take over his
project with the proviso that he has access to it as needed and
that if I decide to get rid of it, he has first crack at it at
the "brother-in-law" price. Sounds like a deal to me.
I may well have this puppy up and running in my shop before
the end of the year.
< with experiment. >
< --Lawrence M. Krauss >
rparigor(at)SUFFOLK.LIB.N Guest
Posted: Sun Sep 03, 2006 11:01 am Post subject: The alternator drive stand . . . |
Hello Bob
"Now the down side . . . it's fitted with a 10 hp, 440v three-phase motor.
I've been digging through the catalogs for reasonable replacements that
will run from the electron-pipe that comes into my house."
Hello Bob
Did you check to see if you can rewire the 440v motor for 220/240?
If you can, you could run it on 220v single phase and use a capacitor or
means of getting it turning to run it on single phase. Of course if you
get any garden variety of 3 phase motors 2 or more hp if you leave it run
as a phase converter, it will allow a start with reasonable torque. The
more 3 phase motors running on single phase, the stronger the third leg.
I have a 7.5hp and 3hp (physical motor) phase converter in my garage. Home
owners will not cover if 3 phase in house by power company. The way I did
it is have phase converters plugged into a giant 220 outlet. This makes
the Ins. Co. happy, they consider it an appliance.
Then I have output plumbed into a 3 phase panel and conduit to machines.
One machine I run is a Monarch EE which has a 5HP motor that turns a DC
generator. They do hocus pocus where they manage to get very good low
speed torque, and is fully controllable. That is the way they did it in
1941.
Anyway the Monarch motor was wired for 440 and I converted it to 220. One
minor problem is since you are halving the voltage, you will draw more
amps. The heaters used for internal breakers were too powerful, i needed
to change them out. Another malady is the third leg is not absolute clean,
I had some relay chatter, by switching to another leg that cured the
problem.
Working great since 1987. There has been a few times through the years
where I needed a lot of power. The 7.5 hp and the 5hp Monarch running
together is a little less powerful than pure 3 phase. I ran my 2hp
Bridgport and 2hp sander to aid the third leg. When really loading down
the motor, you could hear that it was happier with the 2 other machines
running.
Good luck!
Ron Parigoris
BTW I have do it yourself articles for making a friction drive (with aux 1
phase motor) or a phase shift capacitor with timer relay to get 3 phase
generator going. My 7.5 hp has a timer relay, but once running you need to
throw a switch, or else bad things happen when you shut down. The 3hp has
a simple push button, push it and once running let it go. I like the
push-button better!
Posted: Sun Sep 03, 2006 2:29 pm Post subject: The alternator drive stand . . . |
At 06:59 PM 9/3/2006 +0000, you wrote:
Hello Bob
Hello Bob
I believe it can. I considered the phase converter approach. I have
a number of articles in my archives that speak to use of
an unloaded 3-phase motor and array of capacitors. One such
article is available at:
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
B&C uses this technique for their machine shop in Newton.
I've never gotten my hands dirty on one of these systems. I note
in the article that the converter motor should be equal to or larger
than the largest motor in the downstream system. This calls for
another 10 h.p. motor, the attendant capacitors, labor to assemble
and space to house.
After wrestling with the notion, it seemed a lower cost of ownership
solution to simply replace the existing motor with a single-phase
device albeit a smaller one. The existing motor is quite clean. I might
be able to recoup some conversion costs by selling the old motor. But
then if I kept it, I'd have a phase-converter motor available for any
future adventures into 3-phase tools. That's all I need, a 100 pound prime
piece of junque for my inventory of needful things!
| Quote: | Working great since 1987. There has been a few times through the years
running.
Yeah, your experience re-enforces the notion that the converter
motor needs to be a real pig for best performance. I'll poke around
some of the local motor houses and surplus yards. If I could get
a boss-hog 3-phase motor really cheap . . .
| Quote: | BTW I have do it yourself articles for making a friction drive (with aux 1
push-button better!
I've seen converters where the builder simply couples a small
motor to the phase converter machine and leaves it mechanically
engaged and powered during normal operations. I don't see how it
would 'hurt' anything . . . but again, I suspect one would want to
time delay application of power to the idler motor for a second or
two while the starter-motor gets things in motion. Thanks for the
feedback.
Posted: Sun Sep 03, 2006 4:09 pm Post subject: The alternator drive stand . . . |
Hello Bob
I am not certain how your spinemthealternator machine works.
Could you not just use the 10 HP motor as the phase converter?
In other words, start up your 10 hp motor with no load from the alternator
till the 10 hp gets going, then bring on the BTU output for alternator
load.
Dart throw the 10HP motor on single phase should be at least 5 hp?? Again
start adding 3 phase motors in parallel and output from 5HP will increase.
The concept of a phase converter is simple, but essential you need to get
a 3 phase motor spinning and then run it on single phase.
If you don't need to start your 10 hp motor from dead, you may not need
another motor at all.
Principal is simple, somehow you need to get the 3 phase motor spinning
before you add single phase or it will sit there "Stupid" and hummmmm.
We discusses an aux motor to get it going, or temp. putting a phase shift
capacitor to get it going, I will suggest you try your machine with the
simplest (famous last words) by wrapping a rope around the shaft and
giving it a good pull then adding single phase power.
Lets say you need to test a 100 amp alternator, at 28V, that's 2800 watts
or ~ 1/3 of 10HP.
If you like results, go for the capacitor.
Good Luck
Ron P.
ulflyer(at)verizon.net Guest
Posted: Sun Sep 03, 2006 6:15 pm Post subject: The alternator drive stand . . . |
If I recall right there's a way of using a single phase motor to turn
a 3 phase to output three power. Machinist use this as cheap 3 phase
converter when they need 3 phase for three shop at home where 3 phase
is not available or cost prohibitive.
jerb
At 11:15 AM 9/3/2006, you wrote:
<nuckollsr(at)cox.net>
my house.
Posted: Sun Sep 03, 2006 6:24 pm Post subject: The alternator drive stand . . . |
At 12:05 AM 9/4/2006 +0000, you wrote:
Hello Bob
load.
No, single phase motors that use some form of magnetic resistor-inductive,
or capacitor-inductive phase shifting achieve what appears to the rotor
as a spinning magnetic field. Three phase motors assume there's three
120-degree shifted sources of energy that don't need to do any "fool'n".
The result is an extremely efficient motor that works without reactance in
the electrics or shaded poles in the magnetics.
| Quote: | The concept of a phase converter is simple, but essential you need to get
| Quote: | If you don't need to start your 10 hp motor from dead, you may not need
3-phase motors that are very lightly loaded (gyro motors are a good
example) will run acceptably well from a single phase supply when
augmented with some external resistances and reactances. Years
ago, I designed a single phase inverter and companion phase shift
networks to spin up military surplus, 3-phase attitude gyros.
The "fooler" supply took about 3x as long for the motor to reach
running speed on power-up . . . and the top speed was about 10%
slower than design speed compared with a true 3-phase supply
- but satisfactory.
| Quote: | Principal is simple, somehow you need to get the 3 phase motor spinning
True of single phase motors that have lost their start-up circuit
but 3-phase motors don't have the shading/shifting necessary for
single phase running.
| Quote: | We discusses an aux motor to get it going, or temp. putting a phase shift
If it runs at all, it will be exceedingly lacking in power. The
article I cited is an excellent example of a technique that
gets you a majority of the motor's rated capability. Passive phase
shift networks fall far short of this.
Posted: Sun Sep 03, 2006 6:31 pm Post subject: The alternator drive stand . . . |
At 09:10 PM 10/3/2006 -0500, you wrote:
If I recall right there's a way of using a single phase motor to turn a 3
converter when they need 3 phase for three shop at home where 3 phase is
jerb
No, an auxiliary 3-phase motor as shown in:
retasker(at)optonline.net Guest
Posted: Sun Sep 03, 2006 7:35 pm Post subject: The alternator drive stand . . . |
FYI.
McMaster Carr has a 5HP 230V single phase for $350 and a 5HP three phase
(if you want to set up a phase converter with a new motor) for $230.
Dick Tasker
my house.
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Posted: Sun Sep 03, 2006 10:10 pm Post subject: The alternator drive stand . . . |
Hello Bob
I think point of my last post got lost. I was suggesting to forget about a
phase convertor all together and run your 10hp motor on single phase.
You did not answer if you need to start the 10HP motor with a load on it
(alternator)?
If not then why not run your 10hp motor on a single phase?
According to your article a 3 phase motor run on 1 phase should produce
2/3 rated capacity. That is 6 plus hp.
I am suggesting if 6 plus hp is an acceptable power, and you can start up
the 3 phase motor with little load (alternator not producing) then forget
about a roto phase converter all together, and just run your 10 hp motor
at 2/3 rated hp.
I suggested to try it with a rope pull for a test, if it works well, then
on your 10hp motor install a capacitor to phase shift on start up only.
No question that running a 10 hp motor on single phase and producing ~ 6
hp will not be the most efficient 6 hp single phase motor in the world.
I doubt the extra energy you will consume will have much a net monetary
loss.
This is a fairly simple test, get 220 single phase to your 10hp motor,
rope pull it and add the 220 power. You should have a 6hp motor. You
mention if it runs at all??? This is exact what a roto phase is, just
running a 3 phase motor on single phase. Now if you added another 10 hp
motor to the running one, the second one could start from dead and produce
more than 2/3 rated power, but if 6 hp is enough.....
Ron Parigoris
Posted: Mon Sep 04, 2006 4:16 am Post subject: The alternator drive stand . . . |
At 11:32 PM 9/3/2006 -0400, you wrote:
<retasker(at)optonline.net>
FYI.
Dick Tasker
Thanks! I'll check it out. I'm shaft-size critical for this
task. Half of the speed changer mechanism mounts directly on
the motor shaft so that feature has bounded my choices to
some degree. Appreciate the heads-up!
Posted: Mon Sep 04, 2006 4:29 pm Post subject: The alternator drive stand . . . |
my house.
New versions of 3phase converters ain't as expensive as the old days ( &
ship a lot cheaper):
http://www1.mscdirect.com/CGI/N2DRVSH
Should be a lot easier to install, too.
I wish I had known this before I had 3phase run to my house & hangar.
Charlie
Posted: Mon Sep 04, 2006 6:13 pm Post subject: The alternator drive stand . . . |
Charlie
Great data point! Thanks. I'll look into this technology.
Posted: Mon Sep 04, 2006 6:41 pm Post subject: The alternator drive stand . . . |
Good info Charlie. Did some surfing on the
static converter topic and picked up some
good information. Thanks for the heads-up!
