jsflan(at)valornet.com Guest
Posted: Thu Sep 14, 2006 3:33 am Post subject: N-number |
With the Mark III about fit to fly, I am about to initiate the LSA registration process, hopefully simply and without too much fed flak. I am told by the airport manager here that this can be done on-line.
Someone on the list earlier mentioned selection of an N number and a site on line where those Kolb numbers already taken can be found, to keep from filing what might be a duplicate number application.
I would appreciate finding out how to carry this process through and any other tips to ease completion. Example, whether first joining EAA or AOPA is a necessity or simplifies this process.
Also would like to know if my many repairs to date and tweaking problems qualifies this as Experimental Amateur built and can go under my name as builder since the provenance is obscure and whether that is an advantage or asking for trouble later.
Should the Mark III be put in Special Light-Sport Aircraft or Experimental Light-Sport Aircraft? I would think Experimental.
Thanks for any help with zipping through this process. I just want to be left alone to fly without worrying about the shadow of ramp-check Gestapo.
jsf
Steve Boetto
Posted: Thu Sep 14, 2006 4:18 am Post subject: N-number |
A few years ago Bruce Chestnut, Pres of TNK, wrote a nice guide on the full process. It is available at TNK. Call Travis. EAA is also a good source.
steve
jindoguy(at)gmail.com Guest
Posted: Thu Sep 14, 2006 4:27 am Post subject: N-number |
John, You can go to http://www.faa.gov/. Along the right side of the page is Top Requests and the third item down is Aircraft Registration. About 2/3 of the way down the Aircraft Registration page in N numbers. From that page you can search for available numbers and reserve them online. The list may include numbers that have been reserved, but not issued yet and if you pick one of them you will be told in about three weeks, sorry it's taken.
You might be able to get your aircraft through the experimental amatuer built registration, it depends on whether you get a pencil whipper for a DAR. If you get a good DAR, he'll probably smell a rat when there isn't sufficient paperwork, i.e. receipts for parts, or a lengthy builder's log to support your claim that you built it. It will be up to him whether you get a repairman's certificate or not. If he won't give it, your stuck trying to find an A & P to get your annuals done. I'm assuming you don't have an approved i.e. type certificated engine and prop so you'll get a 40 hour phase one fly off period.
If you go the E-LSA route, S-LSA isn't an option, you or anyone else who buys your aircraft down the road can go take the 16 hour class and get your Repairman Inspection certificate for THAT AIRCRAFT ONLY. If you get another aircraft someday, you'll have to take the class again. When the DAR comes out and inspects your aircraft you will only get a 5 hour phase 1 testing period to fly off.
You can get a packet from EAA for $17.95 that has all the forms you need or you can call Rainbow Aviation Services at 530-824-0644 and get all the forms in their packet for $5.00. The RAS packet is LSA friendly and will probably make it easier.
Rick
On 9/14/06, john s. flannery <jsflan(at)valornet.com (jsflan(at)valornet.com)> wrote:[quote] With the Mark III about fit to fly, I am about to initiate the LSA registration process, hopefully simply and without too much fed flak. I am told by the airport manager here that this can be done on-line.
jsf
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
rlaird
Posted: Thu Sep 14, 2006 6:05 am Post subject: N-number |
On 9/14/06, Richard Girard <jindoguy(at)gmail.com> wrote:
Quote: | If you go the E-LSA route, S-LSA isn't an option, you or anyone else who
Rick --
I took the 16 hour class... our instructor said that the class
certificate was valid for any aircraft we owned in that type (fixed
wing). We take the certificate and the airworthiness certificate do
the FSDO, and they issue a Repairman Certificate for you for that
plane. If you get another fixed-wing plane, then take IT'S
airworthiness down the FSDO, and you get a R.C. for that plane, and so
on.
-- Robert
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Roger Lee
Posted: Thu Sep 14, 2006 6:26 am Post subject: Re: N-number |
Hi Rick,
You can go right to the FAA site . Then it will guide you to the "reserve an N number" section. You can pick your own number. If it is in use or reserved it will tell you and you can pick another. The cost to reserve your own N number is $10. It's a piece of cake. I have done it 3 times.
You can only register your Kolb as an ELSA. SLSA is for factory built and approved aircraft from FAA. My new FD CT is SLSA. The ELSA will allow you to take the 16 Hr. course. Then you get the Local FSDO to sign your application form and presto you can do your own condition inspections. So long as you own the plane you can put as many aircraft on that ticket as you want. There is no limit, but you must own the plane. If you sell it then you have them remove you from that certificate. When you buy another ELSA then you can be put back on a condition inspection certificate again. You do not have to take the course again. If you have any questions EAA will be happy to set you in the right direction, ask for Joe. I have done all of this and have not had any issues.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
dhkey(at)msn.com Guest
Posted: Thu Sep 14, 2006 8:09 am Post subject: N-number |
Robert,
I was told for each airplane you'll need to retake the class, the class was
only good for one plane.
David
Quote: | From: "Robert Laird" <rlaird(at)cavediver.com>
Reply-To: kolb-list(at)matronics.com
Subject: Re: N-number
Date: Thu, 14 Sep 2006 09:04:27 -0500
>your
>another
Rick --
on.
-- Robert
Posted: Thu Sep 14, 2006 11:15 am Post subject: N-number |
Thanks for the good information posted on N-number and Aircraft Registration generally from many quarters.
A few hours ago, I found a potentially deadly situation in the red renovation.
Replacing the old seatbelts, I was about to cut off one of the red overspray painted belts. I flicked the head of this rivet, it came free and that was it. That seatbelt on the pilot's side had ONE pop rivet attaching it (and me) to the airframe. The other belt on pilot's side was 100 percent better. Two pop rivets...!
I would dearly like to find that person who set me up for potential life loss. So if you are purchasing a Kolb from anyone, please go over it with a fine-toothed comb and with the eyes of a couple of other people.
jsf
not for posting.
Description: |
Filesize: |
75.58 KB |
Viewed: |
409 Time(s) |
Roger Lee
Posted: Thu Sep 14, 2006 12:12 pm Post subject: Re: N-number |
You only have to take the class once. You then can add or subtract what ever planes you own on or off the certificate. Call EAA they will be glad to give you all the info you want. I liked the class. It was informative. I changed a few things on my Kolb when I got home.
Tucson, Az.
Cell 520-349-7056 |
Thom Riddle
Posted: Fri Sep 15, 2006 5:35 am Post subject: N-number |
David,
I suspect the confusion is as follows. The Repairman's Certificate that
the builder of an aircraft registered as an Experimental Amateur-Built
aircraft earns, is for ONLY that airplane, and no class is required for
this. As others have stated the Repairman's Certificate that an E-LSA
owner can get after taking and passing the 16 hour class is good for
any and all E-LSAs that he owns as long as they are in the same type of
aircraft that the class taken was addressing.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
by0ung(at)brigham.net Guest
Posted: Fri Sep 15, 2006 6:42 am Post subject: N-number |
make it easier.
Call your local fsdo office,,,, they sent me out a package for free.
boyd
