collinc(at)alltel.net Guest
Posted: Tue Sep 19, 2006 4:16 am Post subject: charging system problems |
Hi,
I am new to this list, but I am seeking some help with a charging system problem on my "Bearhawk".
Let me try to describe the problem as best I can. I am using a Van's 35 amp alt. a VR-371 voltage/over-voltage protector, and a Electronics International (VA-1) guage installed in the alt lead. Also using a Odyssey 680 battery.
The problem is this: Everything seems to work just fine until maybe 10-15 minutes into the flight when the discharge light on the VA-1 comes on. I can reset the system by recyling the field breaker and everything goes back to normal--charging again. This will last maybe another 10-15 minutes and the whole process repeats itself. I have checked all my conections, replaced the battery, and now am beginning to suspect the alternator or even the regulator. But I need some advice before I go replacing stuff that doesn't need replacing. (been there done that before!)
Any advice would be appreciated,
Collin
nuckollsr(at)cox.net Guest
Posted: Tue Sep 19, 2006 5:07 am Post subject: charging system problems |
680 battery.
If your system needs "reset", then the symptoms suggest
that the OV protection system in your voltage regulator
is being tripped. This becomes a problem of deducing whether
a real OV condition existed -or- the circuit is being nuisance
tripped.
It's a rational component of troubleshooting to suspect
any component. But it's much better to do measurements
to determine the physics behind the difficulty before embarking
on a swaptronics excursion where one can only hope to pick
the right component . . . with the attendant risk that NONE
of the components replaced will fix the problem.
What are your bus voltages when the system is operating
normally? I'm curious as to how you integrated the VR-371
voltage regulator with a Van's alterantor. I was under the
impression that Van's sold only internally regulated machines.
Let's do the detective work before you pull out any hardware.
FLYaDIVE(at)aol.com Guest
Posted: Tue Sep 19, 2006 7:29 am Post subject: charging system problems |
In a message dated 9/19/06 8:26:09 AM Eastern Daylight Time,
collinc(at)alltel.net writes:
amp
Quote: | alt. a VR-371 voltage/over-voltage protector, and a Electronics
680 battery.
can
Quote: | reset the system by recyling the field breaker and everything goes back to
the
Quote: | battery, and now am beginning to suspect the alternator or even the
regulator.
Quote: | But I need some advice before I go replacing stuff that doesn't need
Collin
Collin:
Keeping things simple ... You did not mention what plane the alternator is in?
But, from your explanation since TIME is function of failure I would also
surmise that TEMPERATURE is a function of failure.
Do you have a cooling tube blowing on the alternator? I have found on two
RV-6's with the SAME alternator that COOLING is a MUST! I installed a smooth
flowing cooling tube and have NOT seen the tripping problem in years. Also, a
bit of cool air blowing on the front bearing goes a long way to longevity of
the alternator.
Now, after you cool things off, then start electron chasing.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
collin
Posted: Tue Sep 19, 2006 12:19 pm Post subject: Re: charging system problems |
The Van's 35 amp alt requires a regulator. (at least according to their website:
ES 14184 W/O FAN: A small lightweight alternator that develops a maximum of 35 amperes (12 volt DC) and is usually enough for most RV's. This unit requires the use of an external voltage regulator.
I don't know what the amp load is on the bus bar. I will try to check on my next flight. I am still in the test phase of a new aircraft and there are a lot ot things to pay attention to.
Collin
Posted: Tue Sep 19, 2006 7:34 pm Post subject: charging system problems |
680 battery.
Okay. Understand that the alternator you have is
externally regulated. I wasn't aware that Van's
was offering one. I acquired the envelope and spec
drawing for the voltage regulator. You can get a
copy at:
http://www.aeroelectric.com/Mfgr_Data/Regulators/Electrosystems/VR371.pdf
I'm disappointed that the data sheet doesn't tell
us anything useful about the OV protection features.
They've cited DO-160C, Section 16, Category B
which makes no sense at all. DO-160 does not apply
to the generation and control of DC power systems.
Mil-STD-704 does.
So we can deduce nothing about the trip dynamics
of their OV protection system from the data supplied.
I'm tracking down an acceptance test procedure from
an overhaul shop to see if there's more to be learned.
In the mean time, since you DO have access to the
alternator's field voltage, there's a troubleshooting
guide in Note 8 of:
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
Getting some numbers about system performance
as described in the procedure will help us help
you figure out where the electrons fell into
the mud.
