boscoaircraft(at)hotmail. Guest
roncarolnikko(at)hotmail. Guest
Posted: Mon Sep 18, 2006 8:04 pm Post subject: anyone using Matco MC-4 and MC-5 brakes? |
Jerry I had to clearance my peddles where the clevis connected to the master
cyl. The cylinders need to extend all the way in both deflections of the
rudder. Mine bound in ceartain positions. Ron NB Ore
The next generation of Search—say hello!
http://imagine-windowslive.com/minisites/searchlaunch/?locale=en-us&FORM=WLMTAG
lcfitt(at)sbcglobal.net Guest
Posted: Tue Sep 19, 2006 6:17 am Post subject: anyone using Matco MC-4 and MC-5 brakes? |
Jerry,
The early Matco's when the passenger brakes were also installed used to lock
up in the event pressure was applied to both sides simultaneously. To
unlock, they had to be bled at the caliper. Don't know if this is the
problem.
Lowell
ppeerenbo(at)charter.net Guest
Posted: Tue Sep 19, 2006 2:28 pm Post subject: anyone using Matco MC-4 and MC-5 brakes? |
I have my passenger brakes removed, however matco has a simple fix for this
problem, when talked to them at Oshkosh.
Paul N102DG
Malcolmbru(at)aol.com Guest
Posted: Tue Sep 19, 2006 4:57 pm Post subject: anyone using Matco MC-4 and MC-5 brakes? |
my breaks dont say matco byt look just like brakes them anu idea what kind they are ?
sales(at)6440autoparts.co Guest
Posted: Wed Sep 20, 2006 7:48 am Post subject: anyone using Matco MC-4 and MC-5 brakes? |
Did they say what the simple fix was ?
Randy
dave(at)cfisher.com Guest
Posted: Wed Sep 20, 2006 8:00 am Post subject: anyone using Matco MC-4 and MC-5 brakes? |
I found this info
http://www.carttonic.com/files/file_download.php?fi_id=38522
Service bulletin For MC-1 Pressure Lock
Service Bulletin for MC-1 Pressure Lock Potential in Dual Cylinder
Installation
Glenn Horne
Posted: Wed Sep 20, 2006 8:27 am Post subject: anyone using Matco MC-4 and MC-5 brakes? |
Make sure that the master cylinders extend to full open.
Had the same problem. Had to shorten the shaft on both
master cylinders. Matco will tell you that they have to open all the
way or you will have a lock.
Glenn Horne Suffolk, Va
Model II 682
Posted: Wed Sep 20, 2006 3:58 pm Post subject: anyone using Matco MC-4 and MC-5 brakes? |
Thanks for the info. They did seem to have this problem when my kid was
taking lessons. The instructor was probably hitting the brakes at the same
time. I'm going to try using new MC-5's on the left side only. No need for
brakes on the right side. Thanks, Jerry Poe
[quote]From: "Dave" <dave(at)cfisher.com>
Subject: Re: anyone using Matco MC-4 and MC-5 brakes?
Date: Wed, 20 Sep 2006 12:00:02 -0400
I found this info
Installation
