Ceashman(at)aol.com Guest
Posted: Thu Sep 21, 2006 2:12 am Post subject: Fuel System Rotax 912UL(to Howard) |
Hello again Howard.
I said:
Pull the prop through a couple of times (only to the left-direction of normal spin).
I would like to clarify this.
When hand pulling the prop, do not rotate the prop in the opposite direction that it normally travels.
I remember reading that; rotating the engine backwards will screw up some of the internal system, I don't know what though!
Sorry for the inconvenience, Eric.
dcsfoto
Posted: Thu Sep 21, 2006 5:05 am Post subject: Re: Fuel System Rotax 912UL(to Howard) |
one reason to rotate prop is to pressure crankcase and force oil into the tank.
rotate in wrong direction it will draw oil into crankcase
that is what I was told by Rotax
