rexjan(at)bigpond.com Guest
Posted: Wed Sep 20, 2006 7:16 pm Post subject: Undercarriage |
Hi ! Lowell.
You miss one point in your opinion below. Unless I am sadly mistaken the track on the Grove gear is about a foot wider. While this is not to do with the plane being squirrelly it will help when you get in that situation to not ground loop it. This is because the tail needs to move further across before it takes over and you can't any longer prevent the loop. In other words the weight takes over from behind to come around to the front. Sorry I'm not good at explaining this but I think everyone knows what I'm talking about.
Rex
Australia.
There is nothing inherently squirrely with the tube gear. I had both. (For
those wondering, I changed out because I was having a hard time finding the
ground early on and was concerned with structural damage due to the limit
cables on the grear bulkhead. I know of guys that do not have the limit
cables for that reason.) Lots of posts on the list address opinions and
lots of the posts have opinions based on quite limited experience.
If you find your gear squirrely, it will be due to misaligned wheels. This
topic has been discussed in depth nearly every year or so. Toed in wheels
will result in squirrely ground handling. Parallel tracking or slightly
towed out will be fine. If you are landing well and then go squirrely, you
might try checking wheel alignment.
Just before we started the "Model, Engine" survey there was a long thread on
tri vs. tw gear. With lots of discussion about equally divided between nose
gear and tail wheel guys. The immediate implication to me was that lots of
guys had opted to go nose wheel - lots of list traffic in favor. The survey
showed that tail wheel is extremely predominant for those responding at
about 10:1. Those numbers suggest that tail wheel is not too difficult to
master by average pilots.
I suspect that if we added spring vs. bungee to the survey, my guess would
be that a majority of guys still fly with the tube gear with none
complaining. Neither is inherently better than the other. You can find a
mis-alligned spring that will be just as squirrely as a mis-aligned tube.
That is why they sell the angled shims to correct for misallignment on the
spring gear.
I have heard of other negatives on the spring gear besides wt. They are
shorter giving a more shallow angel of attack and quick off the ground is
not as good as with the tube gear. There have been comments recently about
taller tube gear for enhanced short field performance I hear that elsewhere
also.
In short it is all related to the mission of your airplane and personal
preferences. No one's preference is any better than any other's
preference - it is all just opinion. And this is just my opinion.
Lowell
lcfitt(at)sbcglobal.net Guest
Posted: Fri Sep 22, 2006 9:20 am Post subject: Undercarriage |
Thanks Rex, Unfortuantely, I am not experienced in ground loops, tube or
aluminum , but I suspect the wider stance would help.
Lowell
dave
Posted: Fri Sep 22, 2006 9:54 am Post subject: Undercarriage |
If you going to ground loop your Kitfox from pilot error then I guess that a
wider gear will allow for a little bit more pilot error but really I would
spend 1500 $ on some professional training and save the 15 or twenty pounds
of weight and you have got some skills that will make flying more fun and
safer as well as broadening your skills to take you to more places.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
taildragon(at)msn.com Guest
Posted: Fri Sep 22, 2006 2:08 pm Post subject: Undercarriage |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
Hi Lowell,
We could teach you ground loops in a few easy lessons. Lets use your airplane.
Roger
Posted: Fri Sep 22, 2006 3:56 pm Post subject: Undercarriage |
Hey, Rodger,
Might go for that. Let's get together.
Fox5flyer Guest
Posted: Sat Sep 23, 2006 4:25 am Post subject: Undercarriage |
With all due respect to those who have voiced their input on this
subject, I'd just like to add my two bits (which is all that it's
worth) to this. This spring gear/tube gear thread has been off and
on for as long as I can remember on this list and I seriously doubt
that there will ever be a consensus as to which is better.
In my opinion, having had both, it's a trade off. Currently I have
the spring gear, but only because it came with the kit. The spring
gear is significantly heavier. Mine, with all hardware, wheels,
tires, brake calipers was almost exactly 75lbs. I've seen people go
to great lengths to save just a few grams of weight on various things
to keep the weight down, yet add a bunch more "pounds" and $$$$ to
add the spring gear. I've never felt my S5 with spring gear was
easier to handle than my old Model II with tube gear was. Both
tracked straight and handled cross winds just fine. Where the big
difference was (other than weight) was when I'd misjudge my full
stall landing and drop it in from a few feet up. The tube gear would
really bounce where the spring gear tends to just soak it up
smoothly. That's about the only difference I've ever been able to
note. I have the "tall" spring gear that was produced on the early
S5s. The gear legs are longer and skinnier than the later models
were.
If you feel your Fox is squirrely then, in my opinion, you need to
focus more on your gear alignment than things like tire pressure,
bungies, or the type of gear you have. A little toe-in can cause a
good handling airplane to be a handful.
So, I guess one just considers priorities, dollars, weight, and the
experiences of others to make a decision on it. Oh, there's also the
factor of bungie replacement every couple years, but I never felt it
was a big deal. I always made my own and the install didn't take
very long.
Deke
WebMail Express+ - http://www.i-star.com Internet Access from $7.95
tc9008(at)aol.com Guest
Posted: Sat Sep 23, 2006 5:30 am Post subject: Undercarriage |
How does the toe end adjust ?
Travis
Posted: Sat Sep 23, 2006 9:04 am Post subject: Undercarriage |
Deke,
Your thoughts are mine exactly. I had trouble with neither as far as
landing is concerned, or taxiing for that matter. The article in the Kitfox
Times about gear alignment came as I was building, so that was checked and
adjusted before the first flight.
It is true, for me at least, that the things I read on this list often
serves as motivation in considering my airplanes configuration. It was
about the time I was seriously dropping it in on almost every landing that a
post came in regarding a hard landing where the limit cables collapsed the
bungee bulkhead resulting in a weld in replacement, new fabric etc. I am in
Aerothane and the latter didn't seem fun, so I went in the direction of
ridding myself of the limit cables - aluminum gear. I have friends that
simply cut out the limit cables and went without them. It is hard for me to
accept those little cables fastened with nicopress fittings being strong
enough to collapse the bulkhead, but it did and they can. That became a
motivation for me to spend the bucks and accept the weight penalty.
Lowell
