		sshook(at)cox.net Guest
				 Posted: Thu Sep 21, 2006 9:53 am    Post subject: Question about Tanks |
				Fellow Builders,
 I have a dilemma, here is the synopsis…
 I am currently working on the Left Tank and I have already drilled my Z brackets (thank you Dan for the easy way of doing it).  I have clecoed together the Tank and the rear baffle to the tank.  When I put the tank on the spar, there is a gap between the tank skin and top main skin.  The gap looks like its somewhere between 1/32 and 1/16.  I will see if I can get an exact measurement tonight, I am also going to attach the bottom main skin and see how that looks before I move forward.
 I can also see where the holes that will be dimpled for the screws along the top of the spar are not exactly lined up with the hole in the nutplates (probably a distance equal to that gap I am talking about).  The bottom tank attach holes look like they are lined up fine.
 Also, the leading edge of the tank seems to sit about the thickness of the skin higher than the leading edge (just at the forward most portion where the tank and L/E meet).  Other than that, there is no gap along the seam between the tank and L/E.
 Any suggestions or insight will be greatly appreciated…Thank you
 Scott & Jenni
 RV-7A N696JS
 Working on left tank     [quote][b]
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		dan(at)rvproject.com Guest
		Brad Oliver
				 Posted: Thu Sep 21, 2006 10:39 am    Post subject: Question about Tanks |
				Scott,
 Does the bottom picture on this page look familiar?
 http://www.rv7factory.com/log/060110.html
 I asked around too, and I discovered that this was a fairly common
 issue.  At the suggestion of another builder I was able to help the fit
 somewhat by taking the nose of each of the tank ribs to the deburring
 wheel to improve their roundness (is that a word?).  In other words, by
 smoothing out the noses of the ribs a little more, I was able to
 slightly improve their fit into the skin.
 I also used some ratcheting cargo straps to snug the tank skin to the
 wing, and I was able to get the screw holes in the skin to align with
 the holes in the spar without too much pressure.  This really helped
 with the alignment of the tank skin to LE skin correct prior to
 drilling the W-423 joiner plates.  You can see the straps on the wings
 here... http://www.rv7factory.com/log/060114.html
 Good luck!
 Brad Oliver
 Livermore, CA | RV-7
 www.RV7Factory.com
 [quote] ------
				 Posted: Thu Sep 21, 2006 10:40 am    Post subject: Question about Tanks |
				When I do that I can close the gap where the main skin meets, I am concerned thought about stressing the skin when the tanks are mounted for good.  Also nothing seems to help the slight gap near the point of the leading edge.
 From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway
  Sent: Thursday, September 21, 2006 11:26
  To: rv7-list(at)matronics.com
  Subject: Re: Question about Tanks
 Push down harder on the tank.  I know that sounds too simple, but try it.
 )_( Dan
 RV-7 N714D
 www.rvproject.com / www.weathermeister.com
				 Posted: Thu Sep 21, 2006 11:02 am    Post subject: Question about Tanks |
				Scott R. Shook wrote:
  	  | Quote: | 	 		   Fellow Builders,
  Scott & Jenni
  RV-7A N696JS
 Did you have any trouble getting clecos through the tank skin into the
 back baffle? Did all the clecos holding the skin to the ribs go in
 smoothly & remain perpendicular to the skin around them? (not likely
 ) Have you built & installed the outboard leading edges yet? Did you see
 the same problem there?
 If the rib flanges are standing up even a little it can push the baffle
 back a bit (will get worse when you put the proseal in there). It's been
 a while, but I think I saw something similar when I built my tanks, &
 leading edges, as well. I think I used ratcheting strap clamps, aligned
 over some of the ribs, to put some pressure on the tank/leading edge.
 Use 2/4's or something similar to protect the trailing edge of the wing
 skins & rear spar.
 If moderate pressure on the straps pulls everything into alignment, try
 coaxing the LE rib flanges a bit, both around curved portions & the back
 flange.
 Charlie
				 Posted: Thu Sep 21, 2006 11:11 am    Post subject: Question about Tanks |
				Check to make sure your tank ribs are forced all  the way into the nose of the tank skin.  That's most likely what at least  part of the problem is.
  )_( Dan
  [quote]   ---
		smittysrv
		Bob Collins
  Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
				 Posted: Thu Sep 21, 2006 11:39 am    Post subject: Question about Tanks |
				I actually disco vered this little problem and provided the  solution to Van's some years ago.
  jack up the rear spar  and you'll hear it pop right  into place.
  there is a thread on the RV List some time ago where  someone ground down the bottom of his Z brackets. He didn't need to do that.  It's  the small sag in the middle that's causing your  problem.
  Bob
  st. Paul
 Sent: Thursday, September 21, 2006 1:26 PM
  )_( Dan
  RV-7 N714D
  [quote]   ---
  _________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
				 Posted: Thu Sep 21, 2006 11:57 am    Post subject: Question about Tanks |
				Actually the sag is not there, I have a jack screw in the center of the rear spar that brought everything nicely into place before I put the main skins on the skeleton.  I will however break out the fishing line again and make sure my spars have not moved since having the skins on and drilled.
 From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bob Collins
  Sent: Thursday, September 21, 2006 12:37
  Subject: RE: Question about Tanks
 Bob
 st. Paul
 )_( Dan
 RV-7 N714D
				 Posted: Thu Sep 21, 2006 12:14 pm    Post subject: Question about Tanks |
				Thank you everyone for all the help and suggestions.  I think my first order of business is to pull the tank, take it apart and re-check all my rib flanges and hole alignment (especially around the nose).  I did in fact have trouble “wrestling” the tank together.
 I know that before the ribs went in; the pre-punched holes were triple checked for straightness.  I cleco clamped my ruler to them and they were dead nuts on.
 We certainly appreciate all the advice and help everyone offers.
 Scott & Jenni
 RV-7A N696JS
 Working on Left Tank
 From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Scott R. Shook
  Sent: Thursday, September 21, 2006 10:53
  Subject: Question about Tanks
 Fellow Builders,
 Scott & Jenni
 RV-7A N696JS
 Working on left tank  01234567890123
		Bob Collins
				 Posted: Thu Sep 21, 2006 12:15 pm    Post subject: Question about Tanks |
				Yeah, so did I. But on the night went I couldn't get the  darned thing to come down properly, I gave it half a crank and heard a "pop" as  it fell into place. It's worth a try. it's worked for a lot of othr  folks.
  Bob
 Sent: Thursday, September 21, 2006 2:57 PM
 Bob
 st.  Paul
 )_(  Dan
 RV-7  N714D
St. Paul, Minn.
		Bob Collins
				 Posted: Thu Sep 21, 2006 12:17 pm    Post subject: Question about Tanks |
				Is your gap the same all the way around? Especially along  the splice joint? Or does it widen (or lessen) along the length of the tank or  leading edge?
  Bob
 Bob
 st.  Paul
 )_(  Dan
 RV-7  N714D
St. Paul, Minn.
		fstringham
				 Posted: Thu Sep 21, 2006 2:09 pm    Post subject: Question about Tanks |
				Scott
 It has been a while but I do remember I had a similar problem. I was able to
 get them to a 64th  gap. Was still determined to get them (aft edge tank to
 leading edge of top skin to meet. So I called Van's and got
 Ken................. he said , rather harshly, 'You don't want them to butt
 to each other". "Why" I asked. "Because the paint will crack along the seam
 line unless there is enoug room for the paint to fill the gap".  My plane
 isn't painted or flying yet so I can only take him at his word. I have found
 him always to be correct when I follow his advice. Plus I have found that
 many times I will take great pains to get everything nearly fiberglass
 smooth when clecoed only to have a bit of a shift during riveting. So get it
 close as possible with no stress and move on. Ain't it fun.
 Frank (at) SGU and SLC.....wiring RV7A
 [quote]From: "Scott R. Shook" <sshook(at)cox.net>
 Reply-To: rv7-list(at)matronics.com
 To: <rv7-list(at)matronics.com>
 Date: Thu, 21 Sep 2006 11:40:14 -0700
 concerned
    _____
 )_( Dan
 RV-7 N714D
