nuckollsr(at)cox.net Guest
Posted: Thu Sep 28, 2006 6:18 am Post subject: Whelen Strobes Blowing Fuses |
At 09:28 PM 9/12/2006 -0400, you wrote:
<pbraswell(at)alterthought.com>
Easy enough to do! I'll give it a whirl and see what happens. And to
answer your question, yes the strobe work fine when it is working.
Thanks!
Peter
Peter, what have you discovered since we last talked
about the blowing fuse problem?
pbraswell(at)alterthought Guest
Posted: Thu Sep 28, 2006 6:49 am Post subject: Whelen Strobes Blowing Fuses |
Hey Bob! Thanks for wanting the follow up!
I went flying the other night with a 15amp fuse as per your recommendation.
Prior to blasting off, I cycled the strobes a few times with no problems.
When I got back down the strobes were still flashing so I think that got it!
And can I say how GREAT it is to have a flying airplane!!!?? I flew until
the sun was just dipping below the horizon. The night was dead calm and my
home airport is a great little 3200' foot sod strip. All that (and the
flashing strobes) made for a very picturesque approach and landing!!!
Doesn't get much better than that!
Thanks!
Peter
Posted: Thu Sep 28, 2006 5:37 pm Post subject: Whelen Strobes Blowing Fuses |
At 10:43 AM 9/28/2006 -0400, you wrote:
Okay, this experiment says that you're not suffering from
a hard fault but more likely an average energy (perhaps
punctuated with once-per-flash peak) draw that slowly
weakens the fuse. It would be REALLY cool to get some
current traces off your system.
You're okay with leaving the 15A fuse in place and
I wouldn't worry about up-sizing the wire. If you ever
come through Wichita, I'd love to put hook some
test equipment to your airplane.
Posted: Thu Sep 28, 2006 5:53 pm Post subject: Whelen Strobes Blowing Fuses |
Thanks! You got it! I'll make it a point to stop should I get out that
far!
Peter
