billmileski
Posted: Wed Sep 27, 2006 11:30 am Post subject: Rotax 912S starter relay diode |
Hi,
Does anyone know if the Rotax 912 series starter relay has a built-in shunt diode?
I am considering adding a diode across my starter switch, but then I came across an application note from Tyco, regarding shunt diodes across their relays. Apparently a zener in series with a diode is better, to allow the relay to develop some EMF, otherwise the opening dynamics can be somewhat thwarted. If so, the starter relay can actually be more likely to fail to open, and/or life can be shortened. Interesting read at http://relays.tycoelectronics.com/appnotes/app_pdfs/13c3264.pdf
Anyway, first thing's first. Anyone know if the 912's starter relay has a built-in shunt protection system of any sort?
Bill Mileski
nuckollsr(at)cox.net Guest
Posted: Thu Sep 28, 2006 4:37 am Post subject: Rotax 912S starter relay diode |
At 12:30 PM 9/27/2006 -0700, you wrote:
Hi,
shunt diode?
Don't know. If you've got access to a 'scope, it's
easy to find out. Even easier to add a diode just for
grins. Two diodes doesn't hurt a thing, no diodes
is hard on starter switches.
| Quote: | I am considering adding a diode across my starter switch,
Not across the switch, across the contactor coil. See
http://aeroelectric.com/articles/spikecatcher.pdf
> . . . but then I came across an application note from Tyco, regarding
shunt diodes across their relays. Apparently a zener in series >with a
opening dynamics can be somewhat thwarted. If so, the starter >relay can
at >http://relays.tycoelectronics.com/appnotes/app_pdfs/13c3264.pdf
This document is an excellent example of poor decisions
made on poor science. The title: "Coil Suppression Can
Reduce Relay Life" certainly gets your attention. The
writer goes to some effort to explain how coil suppression
can have a profound effect on RELAY RELEASE TIME which
is easy to demonstrate and explain. Then in the last
5 paragraphs on page one, launches into some assertions
about the effects of a slowed decay of the magnetic field
on contact separation speeds but no demonstrations or
even a mathematical modeling of the event to support
the assertions.
This discussion came up on the List some months ago.
I've excerpted portions of that discussion below:
| Quote: | Coil Suppression:
MOVs are considered to be better than diodes, although they have higher
impedance. But MOVs typically have a limited lifetime.
The lifetime issue controls when the MOV is stressed
repeatedly to its maximum rated energy levels . . . in
coil spike suppression, the energies are tiny by comparison
and life-limits do not become an issue.
| Quote: | Diodes are not the best method today. Not even the second-, third-, or
fourth- best method. But in the 1960's they were the way to go.
<snip>
Measurements on my bench have failed to demonstrate
the suggestion.
A number of papers have been cited over the years, some
written by some folks who work for big name companies
like Tyco-Amp, Teledyne, etc. wherein authors have suggested
that the readily observable effects of plain diodes on
opening delay (no big deal in 99.99% of applications)
directly translates to slower contact spreading velocity
(extended arcing during contact break).
Two separate conditions are in play. (1) slower rate
of decay in the relay or contactor's coil current and (2)
rate of decay in the magnetic attraction force as the
moveable armature begins to separate from its seated
position within the device. The diode has a profound
effect on (1) but a small effect on (2).
Most of the papers I've read accurately observed
and discussed (1) and even did some measurements but
then went on to improperly assume that similar effects
would be noted for (2) as well.
The trace at:
http://www.aeroelectric.com/Pictures/Curves/704-1DelayNoDiode.gif
Shows contact OPENING DELAY of an S704-1 plastic high
current relay when no diode was present across the coil
and the coil current was being interrupted by the "perfect
switch". Note the expected coil spike on channel 2 and the
opening delay of about 2.5 mS. You can see the
arcing across spreading contacts if you look carefully
at the falling trace on channel 1.
http://www.aeroelectric.com/Pictures/Curves/704-1DelayWithDiode.gif
This trace shows what happens when we use the plain-vanilla
diode across the coil. Yes, OPENING DELAY goes up by a factor
of 500% to about 12.5 mS.
Now, let's go take a close look at the arcing phenomenon noted
in the two traces above . . .
http://www.aeroelectric.com/Pictures/Curves/704-1OpeningTimeNoDiode.gif
. . . with no diode, a series of about 10 measurements produced
an opening time (ARC DURATION) that averaged 210 uS. In the
next trace . . .
http://www.aeroelectric.com/Pictures/Curves/704-1OpeningTimeWithDiode.gif
. . . the diode was put back on and we see an average of
230 uS ARC DURATION for an increase of about 10%
I did similar experiments with other relays and did not
formalize the data gathering but got similar results.
Bottom line is that the use of the lowly diode for coil
spike suppression does not deserve relegation to the dust
bins of electronic history as a 5th-rate spike suppression
technique. Unfortunately, some big names working for big
companies have stubbed their toes on significant but error
driven assumptions.
The repeatable experiment has demonstrated otherwise.
Continued use of diodes as suggested in the 'Connection
and on many drawings posted to the website is not a
recipe for failure. Substitution of a more "modern"
technique will produce no observable effect on the
service life of your relays and contactors.
Demonstrable differences for contact spreading velocity
and potential to arc for diodes versus any other choice
are tiny. Relay and switch lives in industrial parlance
is stated in the tens of thousands of cycles. There are
few switches and relays in our airplanes that will get even
1,000 cycles in the lifetime of the airplane. Nonetheless,
we suffer significant switch and contactor failures . . .
mostly for environmental stresses over long periods of time . . .
commonly known as old age.
There's nothing inherently BAD about coil suppression
techniques other than plain diodes but nothing overwhelmingly
good about them either.
Bottom line is use what ever technique suits your fancy
but don't discount the lowly diode based on the assertions
of folks who demonstrate one effect and then extrapolate
a second effect without supporting data. Further, be
especially wary of papers like the one cited above where
prestige of either people or the companies they work for
is the motivating force to do or not to do any particular
thing.
I've sat across the table many times with folks from
big name companies attempting to deduce root cause of
failures for their products on our products. When the
problem is finally solved, it's all too often that we
end up knowing more about the supplier's product than
they do.
billmileski
Posted: Thu Sep 28, 2006 12:07 pm Post subject: Re: Rotax 912S starter relay diode |
Thanks for the info, and the pdf reminding me that what I really wanted was a diode across the coil, not the switch. And I'll use a scope as you suggested if no protection seems to be already in place.
Bill
