Posted: Wed Oct 04, 2006 5:52 am Post subject: grounding .... was Priming in a confined space |
Rick wrote:
John,
So what is the procedure THIS year....ground wire connected to ground first or aircraft first. It seemed the first point connect would change every year. FWIW, a headphone jack makes a nice grounding point in the exterior.
Rick S.
40185
The headphone jack is a great idea Rick!!! Wish I'd thought of that!!!
When refueling, just wear your headset (you'll need a long headset
extender cord) and take the ground clamp next to the pump and clip it on
your earring (or nose ring whichever you have ...... but no lip rings
.... you'll hate that 'metallic' taste). This will work a whole lot
better if you play your favorite music while you're fueling. Depending
on how much fuel you need, you might be able to get through two songs
before you hop back in the airplane!!!
Linn
