aurbo(at)ak.net Guest
Posted: Sat Oct 07, 2006 7:59 am Post subject: new to this list |
Hello,
I have just completed the fuselage on the RV-9 I am building and am about to begin the process of putting in all things electric. I find myself overwhelmed with the vast unknown pool of knowledge and I just don't know where to jump in or begin.
I have the Aeroelectric book on order. I have talked with Bob.
Up until this point in the building process I have found pretty clear instructions for each step (ok, sometimes the plans and drawings were a little vague) but not for electric installation.
Is there a "cook book" to use to at least have a place to begin?
Mike Ice
Anchorage, Alaska
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sat Oct 07, 2006 9:43 am Post subject: new to this list |
Mike,
Van’s does sell a wiring harness for your RV-9. I bought one for my RV-8A but didn’t use it because I had so many things I wanted to do another way. But, it did come with “put this here and use this wire to connect it to that” instructions. You might want to get just the instructions for the wiring kit for the RV-9 to review.
Terry
RV-8A finishing
Seattle
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael T. Ice
Sent: Saturday, October 07, 2006 8:58 AM
Subject: new to this list
[b]Hello,[/b]
[b]I have just completed the fuselage on the RV-9 I am building and am about to begin the process of putting in all things electric. I find myself overwhelmed with the vast unknown pool of knowledge and I just don't know where to jump in or begin.[/b]
[b]I have the Aeroelectric book on order. I have talked with Bob. [/b]
[b]Up until this point in the building process I have found pretty clear instructions for each step (ok, sometimes the plans and drawings were a little vague) but not for electric installation. [/b]
[b]Is there a "cook book" to use to at least have a place to begin?[/b]
[b]Mike Ice[/b]
[b]Anchorage[/b][b], Alaska[/b]
Posted: Sat Oct 07, 2006 10:03 am Post subject: new to this list |
Hi Michael,
The book you ordered is the cookbook and place to begin. Once through
it, you'll feel a lot more confident about the approach.
In the order of things, you need to decide how you want to place your
buses, main lines, ground cable and contact relays. The rest is
sizing and finding the best methods for placing your wiring, plug
disconnects and putting wiring in for your selected electronics and
avionics.
This is a good site to post a question, but discussions get well past
the minutiae and it's hard to gage the relevant nature of some of the
issues. You will find the book is a centerline and very good reference
from which to make all those decisions. Don't worry about the
vast unknown, cause most of what you need is in the book or can be best
answered here by Bob Nuckolls.
Welcome,
Larry McFarland - 601HDS at www.macsmachine.com
Michael T. Ice wrote:
| Quote: | *Hello,*
*I have just completed the fuselage on the RV-9 I am building and am
don't know where to jump in or begin.*
*I have the Aeroelectric book on order. I have talked with Bob. *
*Up until this point in the building process I have found pretty clear
a little vague) but not for electric installation. *
*Is there a "cook book" to use to at least have a place to begin?*
*Mike Ice*
*Anchorage, Alaska*
fstringham
Posted: Sat Oct 07, 2006 11:51 am Post subject: new to this list |
Mike
You have the cook book on order...Aeroelectric....
I am there now and am in the learning process. First determine aircraft
mission. Determine budget. Design electrical system to meet aircraft mission
and budget. ASK QUESTIONS after your own research. Check out others
electrical plan. Submit your plan to others for suggestions. Order supplies.
Ask questions through the whole process. Don't get side tracked by the
intellectual joustings. Follow Bob's advice and you will not go wrong.
Frank (at) SGU and SLC wiring and other stufffffff....RV7A
| Quote: | From: "Michael T. Ice" <aurbo(at)ak.net>
Reply-To: aeroelectric-list(at)matronics.com
Date: Sat, 07 Oct 2006 07:57:36 -0800
Hello,
Mike Ice
Anchorage, Alaska
Posted: Sat Oct 07, 2006 12:54 pm Post subject: new to this list |
Frank and others,
Thanks for the prompt replies and advice. I will take it to heart and do as
you suggest. Don't worry about me getting caught up in the intellectual
jousting, I am way to busy.
Scottish Proverb:
Be happy while you're living, for you're a long time dead.
Mike Ice
N6030X(at)DaveMorris.com Guest
Posted: Sat Oct 07, 2006 4:57 pm Post subject: new to this list |
One thing you can start doing before you even get "The Book" is to
start making a list of all your electrically operated
equipment. Everything from strobe lights to fuel pumps to electronic
ignition systems, clocks, radios, etc.
Get the manufacturer's specs on each one and write down the "Current"
requirements for each. These will be stated in milliamps or
Amps. For radios, it may give one current requirement for receiving
and a different one for transmitting. Note that this is NOT the
"fuse size" or "breaker size" given. If they only give you the
electrical requirements in Watts, remember you can convert Amps =
Watts / Voltage.
Then sort your list by
a) things you MUST have on all the time in order to stay aloft
b) things you are required by FAR to have turned on at night-time
c) intermittent loads, such as strobe light maximums, radio
transmitter maximums, fuel pumps that run for a short time and then
turn off, etc. etc.
d) unusual loads that you may only require once in a blue moon, such
as landing lights, pitot heat, etc.
d) things that are luxury items, such as iPods, 2nd radios,
This will help you start understanding how you might want to divide
up the equipment onto the various buses you will be creating. It
will also help you start understanding the maximum size alternator
and battery you will need, what size wire to expect, fuse sizes, etc. etc.
The book will make this all clearer, but this will give you something
to start working on before the book arrives.
Dave Morris
At 10:57 AM 10/7/2006, you wrote:
| Quote: | Hello,
Mike Ice
Anchorage, Alaska
Posted: Sat Oct 07, 2006 9:26 pm Post subject: new to this list |
Dave,
Thanks for the great ideas. I have begun to make lists and your right it
gives me something to do which is a big help.
Mike
nuckollsr(at)cox.net Guest
Posted: Sun Oct 08, 2006 5:39 pm Post subject: new to this list |
Mike,
Welcome aboard! You've met a few folks on the List and
for the short term at least, I'll leave you in good
hands. I've got some pressing family matters that
will keep me out of circulation for a few days.
At 07:57 AM 10/7/2006 -0800, you wrote:
| Quote: | Hello,
Mike Ice
Anchorage, Alaska
Posted: Sun Oct 08, 2006 5:48 pm Post subject: new to this list |
At 09:25 PM 10/7/2006 -0800, you wrote:
Dave,
Mike
Check out the blank form at:
http://www.aeroelectric.com/articles/LoadAnalysis.pdf
You need one for EACH bus, typically main, e-bus and battery bus.
Work this in #2 pencil and use pink eraser for modifying the
work product. If you're handy with Excel, you might consider
downloading the spread sheets at:
http://www.aeroelectric.com/PPS/Load_Analysis
These are good examples and starting points for developing
a load analysis that describes what your dream machine
is going to look like. This is a good exercise to do BEFORE
you buy any hardware or start drilling holes in the panel.
The load analysis is a living document so get comfortable
with it (you'll be 95% DONE until a year after the airplane
flies).
Posted: Mon Oct 09, 2006 5:15 am Post subject: new to this list |
Bob,
Thanks. Family first. Besides I am in good hands as you say.
Mike
