Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Wed Oct 11, 2006 12:14 pm Post subject: Smart Glow Fuses |
Mark,
I can’t answer your questions, but this is from Van’s description of the panel of the prototype RV-12:
“The six small slots on the left side are plug-in fuses — cool little units that light up when they blow.”
They don’t say anything more about them, but to see the story on the RV-12 panel, see http://vansaircraft.com/public/rv-12int2.htm
or the latest issue of RVator.
Terry
Anyone using or know if these Smart Glow Fuses are useful, and whether they will fit the fuseblocks B&C/Steinair sell? (They appear to be ATC/ATO type but not too clear from website) Googling didn't find much info...
http://www.bavauto.com/lview.asp?imgfile=assets/imglib500/smartglowfuse.jpg
Available from http://www.bavauto.com/shop.asp
TIA - Mark do not archive
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567890123
sales(at)6440autoparts.co Guest
Posted: Wed Oct 11, 2006 12:32 pm Post subject: Smart Glow Fuses |
Here is the Smart Glow Fuse website http://www.smartglow.com/smart_fuse.html Looks like they have all sizes to choose from.
frank.hinde(at)hp.com Guest
Posted: Wed Oct 11, 2006 1:01 pm Post subject: Smart Glow Fuses |
I saw these in my local autoparts store....Looks like they are standard
ATC fuses.
Frank
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Terry
Watson
Sent: Wednesday, October 11, 2006 1:13 PM
Subject: RE: Smart Glow Fuses
Mark,
I can't answer your questions, but this is from Van's description of the
"The six small slots on the left side are plug-in fuses - cool little
units that light up when they blow."
They don't say anything more about them, but to see the story on the
Terry
info...
Mark Phillips in TN
Posted: Wed Oct 11, 2006 8:35 pm Post subject: Smart Glow Fuses |
Thanks to all for the replys on the Smart fuses- will digest and conclude...
Mark do not archive
_________________ From The PossumWorks... |
klehman(at)albedo.net Guest
Posted: Thu Oct 12, 2006 4:14 am Post subject: Smart Glow Fuses |
The last time these things were discussed someone mentioned that they
don't provide much advantage. You are most likely to be looking at the
fuse block if you already know that something isn't working and
hopefully your fuses are labelled. Also since they do pass a small
amount of current they can make for some strange voltage readings if you
do any testing while they are illuminated.
Ken L.
Fiveonepw(at)aol.com wrote:
| Quote: | Thanks to all for the replys on the Smart fuses- will digest and
conclude...
Mark do not archive
hdwysong(at)gmail.com Guest
Posted: Thu Oct 12, 2006 11:04 am Post subject: Smart Glow Fuses |
Hello Mark -
We're using the "glow" fuses with the black Bussmann blocks.
They fit just like the standard ATC/ATO fuses. The only
difference is that they stick up a bit higher because of the
little "light" on top.
Waytek Inc. (www.waytekwire.com) is a good supplier for
them, too. They also have breakers that fit into the
ATC/ATO slots. Has anyone tried these?
D
