Michel
Posted: Wed Oct 11, 2006 10:04 am Post subject: Kitfox-List:Stall speed |
On Oct 11, 2006, at 4:53 PM, jareds wrote:
| Quote: | I've been plagued for years with my fox on why i have such a high
stall speed.
Me too, Jared. I start to feel the stall at 48 MPH, and begins to go
down at 45. But when checking with the GPS, my instrument shows always
an excess of about 5 MPH, even with the static port installed where
Skystar recommended it. Then I think: Okay, it's called Indicated Air
Speed. As long as I know where, on the instrument, I stall; who cares
about the real speed?
Cheers,
Michel
Lynn Matteson
Posted: Wed Oct 11, 2006 11:05 am Post subject: Kitfox-List:Stall speed |
Mine stalls at 45, 40, and 35 mph, clean, 1/2, and full flaps
respectively, IAS. In my case, 1/2 is 10°, and full is 20°.
Lynn
Kitfox IV Speedster...Jabiru 2200
On Wednesday, October 11, 2006, at 02:04 PM, Michel Verheughe wrote:
> stall speed.
Cheers,
Michel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Wed Oct 11, 2006 11:42 am Post subject: Kitfox-List:Stall speed |
On Oct 11, 2006, at 9:07 PM, Lynn Matteson wrote:
| Quote: | Mine stalls at 45, 40, and 35 mph, clean, 1/2, and full flaps
Wow! What a big difference with flaps, Lynn! What is your max. flaps
angle setting? Mine is only 10 degrees.
Cheers,
Michel
jareds(at)verizon.net Guest
Posted: Wed Oct 11, 2006 7:02 pm Post subject: Kitfox-List:Stall speed |
Every time i have someone else in the plane tasked with watching the GPS
speed ... they end up white knuckled on the .."oh sh(at)#$ handle"
Landings always freak out new riders. I think my IAS is prob a bit high
also but still runs much faster at landing than it should be. Also
takes a bit more runway than it should but just not sure why my fox is
different than others. May need to check the weight again but last
check it was around 630lbs so well within everyone elses posted wts??
Still flyin though but some close calls occasionally and would be nice
to have some more lee way.
> stall speed.
Cheers,
Michel
roncarolnikko(at)hotmail. Guest
Posted: Wed Oct 11, 2006 8:08 pm Post subject: Kitfox-List:Stall speed |
Funny thing the stall speeds. I have been doing the v speeds in the VW
Speedster and can stall between -5 kts and 75 depending on power and angle
of attack. Just a little power and I can stall at 45kts, full power goes
to a negative number and I quit before I overloaded my oil breather due to
rear location. I can get an accelerated stall up to 75 kts without power.
Perhaps the angle of the engine to airframe varies between installations.
Flaps? Oh yea more testing. Still messing with it at 21 hours total time.
Ron NB Ore
| Quote: | From: Lynn Matteson <lynnmatt(at)jps.net>
Subject: Re: Kitfox-List:Stall speed
Date: Wed, 11 Oct 2006 15:07:46 -0400
Mine stalls at 45, 40, and 35 mph, clean, 1/2, and full flaps respectively,
Lynn
>>I've been plagued for years with my fox on why i have such a high stall
>>speed.
>Me too, Jared. I start to feel the stall at 48 MPH, and begins to go down
>at 45. But when checking with the GPS, my instrument shows always an
>excess of about 5 MPH, even with the static port installed where Skystar
>recommended it. Then I think: Okay, it's called Indicated Air Speed. As
>long as I know where, on the instrument, I stall; who cares about the real
>speed?
>Cheers,
>Michel
Search—Your way, your world, right now!
http://imagine-windowslive.com/minisites/searchlaunch/?locale=en-us&FORM=WLMTAG
occom
Posted: Thu Oct 12, 2006 2:36 am Post subject: Kitfox-List:Stall speed |
Posted: Thu Oct 12, 2006 6:40 am Post subject: Kitfox-List:Stall speed |
Wasn't a tailslide, but hanging on the prop almost. Probably part prop
blast interferance. The biggest thing I've found is with my low redrive
prop speed it helps to idle my prop up to 700 rpm on landings. Ron
[quote]From: "Dave G." <occom(at)ns.sympatico.ca>
Date: Thu, 12 Oct 2006 07:35:32 -0300
Lynn Matteson
Posted: Thu Oct 12, 2006 5:19 pm Post subject: Kitfox-List:Stall speed |
My flaps are maxed out at the 20° setting, Michel....and I couldn't get
much more if I wanted to, without removing the center console, and
doing some creative adjusting of linkages.
Lynn
On Wednesday, October 11, 2006, at 03:42 PM, Michel Verheughe wrote:
Cheers,
Michel
N369LM |
Michel
Posted: Fri Oct 13, 2006 9:44 am Post subject: Kitfox-List:Stall speed |
On Oct 13, 2006, at 3:20 AM, Lynn Matteson wrote:
| Quote: | My flaps are maxed out at the 20° setting, Michel....
Thanks, Lynn. You have a model IV, I have a model 3; different wing and
flaperon airfoil. But I think I should increase mine ... carefully.
Cheers,
Michel
dave
Posted: Fri Oct 13, 2006 10:12 am Post subject: Kitfox-List:Stall speed |
Michel,
The Model 1, 2 and 3 used totally different flapperon mixer controls and
you have no differential . There is a possiblity of aileron reversal "I
think" on the PRE IV models. But maybe someone else could comment.
I have a model IV and i have over 30 down deflection. I know how to use
flaps and they are an excellent attribute to my Model IV with over 20
degree down on Take offs .
That being said , over 20 degrees is pretty well useless on landings.
I am open for comments but please don't tell me they are unsafe this way .
Full flaps over 20 degrees are totally safe if you know how to use them .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Michel
Posted: Fri Oct 13, 2006 1:24 pm Post subject: Kitfox-List:Stall speed |
Hello Dave,
On Oct 13, 2006, at 8:12 PM, Dave wrote:
| Quote: | The Model 1, 2 and 3 used totally different flapperon mixer
controls and you have no differential . There is a possiblity of
aileron reversal "I think" on the PRE IV models. But maybe
Yes, my Kitfox 3 pilot manual says that I should not exceed 23 degrees
flaps because it may reverse aileron. The 10 MPH difference between 0
and 20 degrees from Lynn, makes me think that I might try to increase
my 10 degrees to e.g. 15, well beyond the dangerous edge of 23.
Cheers,
Michel
wliles(at)bayou.com Guest
Posted: Sat Oct 14, 2006 5:28 am Post subject: Kitfox-List:Stall speed |
The original aileron/flap mixer control system of the Fox I, II, and III
and all Avids till the Magnum had only minor differential with 0 flaps
that went to neutral at about 10deg and became reversed differential
past that. At large flap deployments, beyond 20 deg, it became possible
for the down deployed aileron to stall. This effectively results in
control reversal and usually occured in the pattern. Even if the
flapperon didn't stall control response became pretty poor, dangerously
so with gusting winds. Not a good thing at low altitude and low speed.
For this reason Dean Wilson recommended that flaps be limited to 15deg
max. Denny allowed some of the early model Foxes to go to 20+, I think
maybe 25deg. This did result in some accidents in early versions. If
you have a FOX I, II, or III I think 20 deg is the absolute max you
should ever use and you would be happier with the airplanes manners if
you limit it to 10 to 15 deg. That gives a useful increase in lift
without a degradation in control response. I know Tootie Mae flies
beautifully with 10deg. I don't use flaps to increase drag, that's what
a slip is for.
Jerry Liles
Dave wrote:
Michel,
use flaps and they are an excellent attribute to my Model IV with
over 20 degree down on Take offs .
way . Full flaps over 20 degrees are totally safe if you know how to
use them .
Dave
dave
Posted: Sat Oct 14, 2006 6:00 am Post subject: Kitfox-List:Stall speed |
Jerry, Thanks that is bascially what I thought on the I,II, and III
models but the IV I find work well for extra lift over 20 degrees adn up to
30 or more.
I will try to measure this weekend what I actually get.
Dave
