rv73hl(at)comcast.net Guest
Posted: Sun Oct 15, 2006 4:23 am Post subject: Correct Oil for 912UL |
When using 100LL exclusively in your 912UL, what oil would you recommend?
Howard
john(at)leptron.com Guest
Posted: Sun Oct 15, 2006 6:11 am Post subject: Correct Oil for 912UL |
Pro Honda HP4M 10W40 semi-synthetic oil with Moly, 1 Litre
Formulated for high heat, 4-stroke motorcycle racing applications only. If the bike is used for high performance riding and it will be operating at or near redline for extended periods of time, this is your oil. HP4M with Moly is a blend for synthetic and petroleum base stocks. The synthetic portion is very effective, in high heat applications, at reducing oxidization, evaporation, and viscosity loss. It also contains molybdenum (moly), a very slippery substance. The moly contributes to less friction and heat in high temperature situations, therefore allowing the motor to rev easier, creating more horsepower! So if horsepower is your goal; HP4M is your oil.
Howard,
This is the oil rotax suggested years ago and I have been using for 700 hours, the petroleum portion of the oil holds the lead in av gas in suspension. The synthetic portions protect against the high temps and holds on the parts during short term storage. The moly in this mix is the required product for the gear box.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Howard
Sent: Sunday, October 15, 2006 6:21 AM
Subject: Correct Oil for 912UL
Howard
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234567890123
