Michel
Posted: Mon Oct 16, 2006 9:30 am Post subject: Windmilling. WAS: sadly a kitfox is down glide.... |
On Oct 16, 2006, at 2:54 PM, Noel Loveys wrote:
| Quote: | The wind milling prop has more resistance to the air. The least is a
feathered still prop. An unfeathered still prop is in the middle.
And it is the same for a yacht, Noel. When I stop my engine, after
hoisting the sails, I keep it in gear to prevent the prop to windmill
.. or, should I say: watermill!
Michel
Float Flyr
Posted: Mon Oct 16, 2006 4:56 pm Post subject: Windmilling. WAS: sadly a kitfox is down glide.... |
I take it you don't have one of those fancy folding props. I often wondered
if they would work in reverse. My little boat has an outboard with an
outboard kicker. The lift went on my main engine this summer so I never got
past the door of the boathouse.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 16, 2006 8:33 pm Post subject: Windmilling. WAS: sadly a kitfox is down glide.... |
The folding props do work in reverse, but need lots of revs for the
centrifugal force to open the blades. Used to crew on off shore racing
boats.
Lowell
