dcaofak(at)acsalaska.net Guest
Posted: Sat Oct 14, 2006 9:35 am Post subject: Aileron Differential |
Aileron differential on a stock Model III is about 1 1/2 to 1 REVERSE differential.
I found this when I was bored one weekend and modelled the aileron control system in a computer program.
I believe this was accepted by the factory so that you would not have to disconnect the aileron controls to fold the wings, that was a choice for convenient airplane storage and very rudder dependant flight characteristics.
I chose to redesign the aileron/flap control mechanism to provide the correct 2 : 1 aileron differential and it makes for a very pleasant flying aircraft (IMHO). I do have to disconnect the flaperon horns to fold the wings.
In the flap deployment area my redesign system can deploy too much flap, so much so that at near stall speeds there is almost no aileron control, I have of course limited my flap handle movement, this also allows the flap mechanism to 'reflex' a few degrees which helps with elevator trim.
I do not live in a Kitfox rich environment and the only one I've seen flying (from the outside) was a model II, one time, one takeoff. So I cannot compare my Fox's flying characteristics to any others.
It'll be interesting to hear other people's experiences.
John Stoner
KFIII, 582
Alaska
dave
Posted: Sat Oct 14, 2006 10:49 am Post subject: Aileron Differential |
John., I bet you find it nicer to fly now than before the mod ?
Dave
<<I chose to redesign the aileron/flap control mechanism to provide the correct 2 : 1 aileron differential and it makes for a very pleasant flying aircraft (IMHO). I do have to disconnect the flaperon horns to fold the wings.>>
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
jdmcbean(at)cableone.net Guest
Posted: Sat Oct 14, 2006 1:01 pm Post subject: Aileron Differential |
John,
The current mix ration is 2:1 from the Model IV through current Super Sport. You’ll be pleased.. We also have a retrofit kit to convert the Model III to the Model IV mixer assembly.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Dave
Sent: Saturday, October 14, 2006 12:48 PM
Subject: Re: Aileron Differential
Dave
[b]<<I chose to redesign the aileron/flap control mechanism to provide the correct 2 : 1 aileron differential and it makes for a very pleasant flying aircraft (IMHO). I do have to disconnect the flaperon horns to fold the wings.>>[/b]
----- Original Message -----
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Saturday, October 14, 2006 1:35 PM
Subject: Aileron Differential
John Stoner
KFIII, 582
Alaska [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - NEW MATRONICS WEB FORUMS - --> - NEW MATRONICS LIST WIKI - --> - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> <![if !supportEmptyParas]> <![endif]>[b]
Michel
Posted: Sat Oct 14, 2006 1:04 pm Post subject: Aileron Differential |
On Oct 14, 2006, at 7:35 PM, John wrote:
| Quote: | Aileron differential on a stock Model III is about 1 1/2 to 1 REVERSE
differential.
I am sorry, John, I don't understand what you mean. Could you explain,
please? Thank you.
Cheers,
Michel
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Sat Oct 14, 2006 3:13 pm Post subject: Aileron Differential |
John,
Will this retrofit kit work for models 1 & 2 as well? I couldn't find
any mention on your websites.
Rex
Colorado
jdmcbean wrote:
[quote] John,
Fly Safe !!
John & Debra McBean
208.337.5111
_www.kitfoxaircraft.com_
/"It's not how Fast... It's how Fun!"/
_________________ Rex
N740GP - M2/582
Colorado |
Posted: Sat Oct 14, 2006 6:39 pm Post subject: Aileron Differential |
| Quote: | | Michel,Aileron differential is when one aileron moves more degrees than the other when the control stick is deflected. Reverse differential is when the down aileron moves more than the up aileron. This conditioncreates more drag on the wing that is on the outside of the turningcircle, which requires a large rudder input to counteract. The correct differential is for the aileron on the inside of the turn to deflect more up than the aileron on the outside of the turn deflects down.This way the natural difference in drag on the wings makes the turn easier instead of more difficult. It should also be noted (to the best Aileron differential is when one aileron moves more degrees than the | 0 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 1 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 2 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 3 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 4 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 5 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 6 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 7 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 8 | Quote: | | Aileron differential is when one aileron moves more degrees than the | 9
runwayrex(at)juno.com Guest
Posted: Sat Oct 14, 2006 8:32 pm Post subject: Aileron Differential |
John McBean,
I would be interested in learning more about converting the Model 3 planes (and others) to the differential ailerons. Maybe you can post some of the info for us to read.?
Rex in Michigan
-- "jdmcbean" <jdmcbean(at)cableone.net> wrote:
John,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Fly Safe !!
John & Debra McBean
208.337.5111
Michel
Posted: Sun Oct 15, 2006 12:10 am Post subject: Aileron Differential |
On Oct 15, 2006, at 4:38 AM, John wrote:
| Quote: | Aileron differential is when one aileron moves more degrees than the
Thank you, John. I know the theory but I can't understand you saying: "
Model III is about 1 1/2 to 1 reverse differential."
I thought that Kitfoxes, prior to model IV, had no differential
aileron, i.e. they moved the same angle up and down, thus inducing some
adverse yaw. Trying to understand your sentence, I imagine that you are
saying: If the up aileron moves 10 degrees, then the down aileron moves
15 to 10 degrees; is that right?
This being said, I don't find the light adverse yaw of my Kitfox a
problem at all. In any case, the plane has to be flown with the pedals
at all time. The only time I really use the pedals in a turn is when
e.g. I do a very square traffic pattern, turning sharp by "throwing"
the plane in a 45 degrees bank, the "throwing" it back to level.
Last, while adverse yaw is of "no use" really, I wonder if it is not
desirable in a crosswind landing, when we keep the aileron up on the
weather side, while the lee side, with its aileron down adding extra
drag, works in preventing the plane to weathercock. Is this a fact or
just something I imagine?
Cheers,
Michel
dwight purdy
Posted: Sun Oct 15, 2006 6:27 am Post subject: Aileron Differential |
Micheal
I fly a model ll. I did not build it and learned to fly with the flap
handle full off. One day while checking the incident angle of the flaperons
I found that they were in a reflex position with the handle full down. I
started flying with the handle about 30% up and the plane is very
squirrelly as compared to full down. I like having to fly the plane. When
you give the controls to your passenger, he is all over the sky. Makes you
look like the MAN. HA HA.
Dwight
At 10:07 AM 10/15/2006 +0200, you wrote:
I thought that Kitfoxes, prior to model IV, had no differential aileron,
i.e. they moved the same angle up and down, thus inducing some adverse
yaw. Trying to understand your sentence, I imagine that you are saying: If
the up aileron moves 10 degrees, then the down aileron moves 15 to 10
This being said, I don't find the light adverse yaw of my Kitfox a problem
at all. In any case, the plane has to be flown with the pedals at all
time. The only time I really use the pedals in a turn is when e.g. I do a
very square traffic pattern, turning sharp by "throwing" the plane in a 45
weather side, while the lee side, with its aileron down adding extra drag,
works in preventing the plane to weathercock. Is this a fact or just
Cheers,
Michel
Checked by AVG Anti-Virus.
_________________ dwight
model II |
Michel
Posted: Sun Oct 15, 2006 10:46 am Post subject: Aileron Differential |
On Oct 15, 2006, at 4:25 PM, dwight purdy wrote:
| Quote: | I found that they were in a reflex position with the handle full down.
Here again, I am stumbling on words, Dwight; what is "reflex position?"
You see, with the "1.5 reverse differential" from John, I also have
problems to understand because, from what I can read from the builder's
manual (like you, I bought the plane completed) when the flaperons are
at the same angle on both sides, a spline extending the it's lower
surface, must meet the leading edge of the wing a few inches below.
Which it does, on my plane. My conclusion then is that the chord of the
flaperon is at a slightly higher AoA than the wing.
Now, if you then measure the angle the flaperon does with full stick
movement, it will be a greater angle down than up - compared to the
wing! Not maybe not to the initial reference, which is then the level
position.
Then I also read that some gliders have negative flaps setting. Hum, it
gets complicated!
Cheers,
Michel
dwight purdy
Posted: Sun Oct 15, 2006 1:22 pm Post subject: Aileron Differential |
Don't know if I am using the right word, I think reflex is when flaperons
are set at less angle of attack than the wing. In the case of kitfoxs
anything less than that magical set up the manual calls for.
Dwight
At 08:42 PM 10/15/2006 +0200, you wrote:
manual (like you, I bought the plane completed) when the flaperons are at
the same angle on both sides, a spline extending the it's lower surface,
must meet the leading edge of the wing a few inches below. Which it does,
on my plane. My conclusion then is that the chord of the flaperon is at a
movement, it will be a greater angle down than up - compared to the wing!
Not maybe not to the initial reference, which is then the level position.
gets complicated!
Cheers,
Michel
model II |
kitfox(at)bresnan.net Guest
Posted: Sun Oct 15, 2006 7:08 pm Post subject: Aileron Differential |
John , I would be very interested in your aileron control modification.
If I might ask you to send me some information .
DeWayne Clifford
Posted: Mon Oct 16, 2006 12:21 pm Post subject: Aileron Differential |
Michel,
The term 'reflex' flap position I used is the same as the 'negative' flap position you referred to on sailplanes.
Your detail discussion of aileron and rudder use in crosswind landings was very interesting, I had not considered these arguments before. Thank you.
DeWayne,
I would be more than happy to share my aileron design changes with anyone who is interested. In general I moved the mixer mechanism to an under the seat position and then ran push/pull tubes to the outer edges of the fuselage via bellcranks and then up to the aileron arms. This routing allowed a zipper duffel bag to be suspended behind the seat for light cargo where the old design occupied this space with the mixer mechanism. A little application of trigonometry, in particular the law of sines, to increase differential motion at each bellcrank and you can achieve any practical degree of differentiation you desire. This little excursion deeper into 'experimental' consumed over 100 hours of design, fabrication, and fuselage mods. I can take photos when I do my next annual conditon inspection if you would like to see them (about two months away).
John Stoner
KFIII, 582
Alaska
rliebmann(at)comcast.net Guest
Posted: Mon Oct 16, 2006 12:59 pm Post subject: Aileron Differential |
Hi John,
I would be grateful to get drawings and, later on pictures of your aileron push/pull tubing.Please keep me in the info loop..
Thanks Much, Ron N55KF rliebmann(at)comcast.net (rliebmann(at)comcast.net)
DO NOT ARCHIVE
mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Wed Oct 18, 2006 7:37 am Post subject: Aileron Differential |
John, you've done it now - you've got everyone's interest! Definitely put some photos, drawings, etc. of your revised linkage up. I would think the dropbox would be the best place, but that's up to you.
-Mark Scott
Elkton, MD
Hi John,
DO NOT ARCHIVE
_________________ Mark Scott
Winston-Salem, NC |
