dave
Posted: Sun Oct 22, 2006 5:12 pm Post subject: Tailwheel aka Nosewheels |
Lowell ,
For arguments sake I have the same 6 inch solid tailwheels on the nose gear
of my Amphibs. I think Gary Walsh has the same ones. I operated off of
grass and they take a pounding as there little cushioning from the solid
wheels.
As far as bearings go - well lets see what they get -- Grass, dirt, sand,
water,sand dirt water,river slime,algae,sand,dirt,mud, dirt,water, sand
ETC !!!
And they still ticking ,,,,,,,, I never greased them since in installed 2
years ago .Plus they sit in snow as well .
For the record I am going to go full pneumatic wheels when I find one that
fits the odd sizing for those floats.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Oct 22, 2006 8:52 pm Post subject: Tailwheel aka Nosewheels |
Far be it to me to get into an argument about tail wheel bearings. I just
posted my experience primarily to express frustration in the 5/8" rather
than the 1/2" axle measurement in the ACS supplied bearings and give a
heads-up to anyone planning a bearing replacement.
However, based on my experience with mine which were probably 70% hard
surface and 30% otherwise and about 3 years old, with your usage you will
have 0, read zero, lubricant in your bearings and they are failing as we
speak.
On mine the entire interior of the wheel hub was coated with black gunk
presumably the original lubricant which somehow exited the bearings and
deposited itself there, and there was actually dirt - not congealed oil or
grease - on the inner surfaces of the bearings in clumps. These bearings
are not sealed despite the Stainless steel shield. Everything you expose
them to is being used as lubricant whether it be dirt, sand or water. They
will fail, if not catastrophically, they will become noisy, indicating
bearing failure. Jack up the front of your float and spin them. If after
two years in the environment you describe they spin silently, we will all
have witnessed a miracle. Failed bearings on a tailwheel could be an
annoyance. Failed bearings on a nose wheel just might provide an amazing
adventure, but to each his own, I guess.
Frankly, I love this list especially when someone reports factual
information and there are predictable responses from people who are
opinionating, bragging, or just guessing, as to why the real life experience
is a bunch of you know what.
Lowell
dave
Posted: Mon Oct 23, 2006 2:14 am Post subject: Tailwheel aka Nosewheels |
Lowell,
Yes I will has the floats in the shop soon and will inspect the bearings and
I will take some pics etc of the bearings.
Also I will add that time the wheels are actually in use on the ground that
if would take many miles of usage before a failure was likely. Although the
wheels are tiny and spin very fast at 40 mph it is only for short spurts
of under 10 seconds on take off and landing about the same at over 40 mph
plus the minute or two of taxing at a slower speed. A good example of
bearing failure is boat trailers. Look at the older ones with those small
tires and it summer you use to see them on the side of the freeways allot
but not with slower turning larger wheels you see allot less. But these are
traveling at high speeds for a long time before they fail. Un- lubricated
bearing will fail in time, no doubt about that.
I find when on wheels that the spindle on the tailwheel needs greasing more
than anything. The tailwheel pivot gets stiff and hard to turn until it
gets a few pumps from grease gun.
Dave
