lcfitt(at)sbcglobal.net Guest
Posted: Sat Oct 21, 2006 1:12 pm Post subject: Tailwheel |
Several years ago I opted to change out to the Homebuilders Special dual
fork tailwheel. I got the immediate quieting that others have mentioned. I
also ordered the spare sealed bearing as the word was that the original
bearings were unsealed and un-lubeable.
Well, the unsealed part is true but the un-lubeable part is only partly
true. There is a grease fitting, but to force grease into the bearings you
would have to fill the entire hub cavity between the bearings - probably
about three or four ounces of grease. My guess is that with that much
lubricant in the hub and unsealed, you would eventually throw all that
grease onto the underside of the aft fuselage. Essentially, the original
equipment bearings are junk and the provision for lubrication is haphazard
at best - a real disappointment in an otherwise great tailwheel.
In short, I was getting more tail wheel noise than I was used to so I lifted
the tail and sure enough the bearings were shot. I removed the wheel and
bearings and pressed in the new ones and voila - the replacement bearings
from ACS were 5/8" ID whereas I needed 1/2" ID bearings as exact
replacements for the originals. So much for buying early and keeping them
on hand. If course I didn't check the ID against the axle until I had them
pressed into the hub - dumb me again.
Just a general heads-up here. ACS sold the bearing as an exact replacement
upgade. I know of others that have replaced them. What is your experience
with the replacement bearings? I have ordered new bearings from my favorite
bearing shop and they are a bit more expensive, but I know for sure what I
will be getting - dual contact sealed bearings, 1.375" OD X .5" ID with
retaining ring.
Lowell
temco(at)telusplanet.net Guest
Posted: Sat Oct 21, 2006 3:21 pm Post subject: Tailwheel |
Lowell
Couldn't you just go down to a commercial bearing supplier and give them the
OD and ID of the bearing you need and have them match up those dimensions
with a good industrial sealed, permanently lubed unit??
Just a thought
Ted
DO NOT ARCHIVE
henrysfork1(at)msn.com Guest
Posted: Sat Oct 21, 2006 6:24 pm Post subject: Tailwheel |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I also purchased the bearings from the local bearing shop for the same reason. I was lucky and figured it out before finding out the hard way.
Dee
will be getting - dual contact sealed bearings, 1.375" OD X 5" ID with
retaining ring.
Lowell
Do not p; Navigator Photoshare, and title=http://www.matronics.com/Navigator?Kitfox-List href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron=======================
bsp; available via title=http://forums.matronics.com/ -========================nbsp; Email List nbsp; generous bsp; title=http://www.matronics.com/contribution =================
Jim Shumaker
Posted: Sat Oct 21, 2006 10:02 pm Post subject: Tailwheel |
Lowell
I had the same experience with the bearing size. I just made a sleeve of 1/2 inch ID x 5/8 OD steel tubing over the axle. I also noted that the new bearings did not have a ridge around their outside circumference to trap the wheel between the bearings so in installed a couple of 1/2 inch fender washers on the axle also. Just like on a control arm with a ball and socket joint. My recollection is that the exact replacement statement came from a list member who recommended them and not from ACS.
Jim Shumaker
_________________ Jim Shumaker |
Lynn Matteson
Posted: Sun Oct 22, 2006 4:37 am Post subject: Tailwheel |
Hi Lowell-
I ordered one foot each of two different sizes of tubing stock from
Spruce, and used the one that fit the axle the best...it was p/n
03-03900, and it is in the catalog under 4130 seamless tubing, 5/8" OD.
The other tubing I ordered was under bushing stock #03-17100. They both
show as .065" wall, but the 03-03900 fits better to the axle. It seems
like I had to polish the axle slightly. I'm using this sleeve method
and I sent a piece of the same stock to Jimmie Blackwell, who is also
using it.
Yes, those bearings from Spruce, that come in the wheel, are junk,
suitable only for lawn carts etc. And if you order the "replacement
bearings" from Spruce, be aware that you get only ONE....yes, it says
"bearings" but bearings in this case is ONE.
Lynn
On Saturday, October 21, 2006, at 05:12 PM, Lowell Fitt wrote:
dual fork tailwheel. I got the immediate quieting that others have
mentioned. I also ordered the spare sealed bearing as the word was
that the original bearings were unsealed and un-lubeable.
partly true. There is a grease fitting, but to force grease into the
bearings you would have to fill the entire hub cavity between the
bearings - probably about three or four ounces of grease. My guess is
that with that much lubricant in the hub and unsealed, you would
eventually throw all that grease onto the underside of the aft
fuselage. Essentially, the original equipment bearings are junk and
the provision for lubrication is haphazard at best - a real
lifted the tail and sure enough the bearings were shot. I removed the
wheel and bearings and pressed in the new ones and voila - the
replacement bearings from ACS were 5/8" ID whereas I needed 1/2" ID
bearings as exact replacements for the originals. So much for buying
early and keeping them on hand. If course I didn't check the ID
against the axle until I had them pressed into the hub - dumb me > again.
replacement upgade. I know of others that have replaced them. What
is your experience with the replacement bearings? I have ordered new
bearings from my favorite bearing shop and they are a bit more
expensive, but I know for sure what I will be getting - dual contact
sealed bearings, 1.375" OD X .5" ID with retaining ring.
Lowell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sun Oct 22, 2006 6:47 am Post subject: Tailwheel |
Could do, Ted, but I have found a reliable web based company that has a
great site for bearing shopping and I have found virtually everything I have
ever needed there including The .75" ID X 1" OD ball bearings I used on the
control stick of my video camera mount.
There is a local group that does an annual unlimited pinewood derby race for
the dads of Cub Scouts. I have purchased 1/8" X 1/4" bearings for my one
pound full suspension current champion unlimited race car. This size
bearing comes in several configurations, sealed and unsealed and SS or
ceramic. For this application an unsealed bearing is best as all the lube
can be removed - lube adds a little rolling resistance and in a 20 foot
gravity run every bit helps.
With small bearings, my guess is that if they don't stock it, it would have
to be custom made. The typical no sales tax and here in less than a week.
Some times it takes that long to just find time to get into town and I dare
say the .75 X 1 bearing would have to have been special ordered.
Lowell
Posted: Sun Oct 22, 2006 7:12 am Post subject: Tailwheel |
Hi, Jim
I just checked the ACS catalogue and you are right, they don't use the
phrase exact replacement, but the catalog entry is in the same box as the
replacement wheels and says,
"These high quality bearings are superior to standard bearings furnished
with homebuilder tailwheels" I made an assumption that they were the same
bearings. Incidentally the ones ACS sent to me had a snap ring where the
flange was on the old ones. The side to side fit was exact and I made shims
like you did, but made mine of Delron.
Lowell
Guy Buchanan
Posted: Sun Oct 22, 2006 7:30 am Post subject: Tailwheel |
At 07:47 AM 10/22/2006, you wrote:
| Quote: | Could do, Ted, but I have found a reliable web based company that has a
C'mon Lowell. Don't be shy. What's the name?
Guy
Deceased K-IV 1200
A glider pilot too. |
Michel
Posted: Sun Oct 22, 2006 10:12 am Post subject: Tailwheel |
On Oct 21, 2006, at 11:12 PM, Lowell Fitt wrote:
| Quote: | Several years ago I opted to change out to the Homebuilders Special
Hello Lowell,
One and half year ago, I also changed my Maule tailwheel for a
Homebuilders Special, but not the dual fork, the single fork one. Like
you, I also read that the wheel bearing (not the swivel axle bearing)
couldn't be greased. When installing it, I noticed that there was a
grease nipple on both the swivel and the wheel axle. I tried to grease
both but the wheel one wouldn't accept grease.
.. then I went flying. I have now maybe 100 hours on that tailwheel.
Should I worry?
Cheers,
Michel
Posted: Sun Oct 22, 2006 10:47 am Post subject: Tailwheel |
The bearing Co is Boca Bearings - specializing in miniature bearings for
hobby and industry. http://www.bocabearings.com/
Lowell
Posted: Sun Oct 22, 2006 4:52 pm Post subject: Tailwheel |
Michel,
No. I wouldn't worry. The grease fitting feeds into the space beteen the
bearings - a cylinder shape 1-3/8" by 2 or so inches. It would take a lot
of grease before any would be forced into the bearings themselves. I
checked mine because it seemed the original noise from the hard rubber in
the Maule had returned. It was bearing noise that triggered the
replacement. I guess with the single fork, though, if both bearings failed
catastrophically the wheel could fall off, but in that case you would have a
tail skid. I think a reasonable pre flight would detect any problems.
Lowell
Guy Buchanan
Posted: Sun Oct 22, 2006 5:29 pm Post subject: Tailwheel |
At 10:46 AM 10/22/2006, you wrote:
Thanks Lowell.
Guy Buchanan
Deceased K-IV 1200
Michel
Posted: Mon Oct 23, 2006 1:24 am Post subject: Tailwheel |
| Quote: | From: Lowell Fitt [lcfitt(at)sbcglobal.net]
Thank you, Lowell. Do you think I should remove the wheel axle and inspect the bearings? Should I grease it when opened? Or can I leave it as it is?
Thanks in advance.
Cheers,
Michel
