jchang10
Posted: Thu Dec 25, 2014 9:00 am Post subject: G3i Supercharging |
http://www.g3ignition.com/Supercharging.html
All i wanted from santa was this supercharging kit but instead i got an
ugly sweater.
Lately, i was bemoaning that i had never heard of a supercharging or
turbo kit. I just now googled for it, and lo and behold there it is. I
had never heard of this option before. It sure sounds pretty great. In
fact, it sounds too good to be true. It's actually designed for a stock
540, which we all have. I just cant believe i had never heard of this
before. Anybody have it?!
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
Lenny Iszak
Posted: Fri Dec 26, 2014 8:03 pm Post subject: Re: G3i Supercharging |
A few of us have the G3i electronic ignition but I don't know of anyone with the supercharger.
The ignition has been working great and the support from Thomas is awesome.
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Deems Davis
Posted: Fri Dec 26, 2014 8:27 pm Post subject: G3i Supercharging |
it looks like it's  + 40lbs exactly where the RV10 doesn;t need any additional weight.
On Fri, Dec 26, 2014 at 9:03 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
[quote]--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Lenny
N311LZ
http://forums.matronics.com/viewtopic.php?p=436300#436300
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
     -Matt Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
jmjones2000(at)mindspring Guest
Posted: Fri Dec 26, 2014 11:07 pm Post subject: G3i Supercharging |
Jae,
I can tell you that it turns the 540 into a beast! I know Tom personally and have seen his starduster fly with the supercharger. He is an incredible engineer, and and his workmanship is second to none. He has flown it to Oshkosh and done many air shows with it as well. It is a very slick setup that works nicely. His G3i ignition is also very well thought out.
Be sure to look at http://www.forcedaeromotive.com/ also. It is a different option altogether and the components they use for their kits can be purchased on the open market for cheaper than they offer on the website.
Good Luck
Justin
| Quote: | On Dec 25, 2014, at 7:55 AM, Jae Chang <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)> wrote:
--> RV10-List message posted by: Jae Chang <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)>http://www.g3ignition.com/Supercharging.htmlAll i wanted from santa was this supercharging kit but instead i got an ugly sweater. :(Lately, i was bemoaning that i had never heard of a supercharging or turbo kit. I just now googled for it, and lo and behold there it is. I had never heard of this option before. It sure sounds pretty great. In fact, it sounds too good to be true. It's actually designed for a stock 540, which we all have. I just cant believe i had never heard of this before. Anybody have it?!Jae-- #40533 RV-10First flight 10/19/2011Phase 1 Done 11/26/2011do not archive
Kellym
Posted: Sat Dec 27, 2014 6:50 am Post subject: G3i Supercharging |
All of which raises the question of what would one accomplish with this
on an RV-10?
Van's has stated a very clear design flutter speed and has documented
that achieving more than 195 horsepower (75%) at altitudes from 12,000
on up will cause the RV-10 to exceed that design flutter speed. It
already gets to within 20 mph of that design flutter speed with 75%
power at low altitude and light wt or full power at gross. So either
someone has to figure out what structural changes are needed for the
control surfaces to raise that design flutter speed or risk shedding
those control surfaces. Perhaps more than 1500 fpm climb or takeoff roll
under 1000 ft isn't good enough? Maybe we just need to find a source for
JATO bottle and a way to mount it?
Or is it just a better aircraft if we spend more money on more hardware?
Perhaps the Tim Allen effect?
On 12/27/2014 12:04 AM, Justin Jones wrote:
| Quote: | Jae,
website.
Good Luck
Justin
> <mailto:jc-matronics_rv10(at)jline.com>> wrote:
> <jc-matronics_rv10(at)jline.com <mailto:jc-matronics_rv10(at)jline.com>>
> an ugly sweater.
> Jae
> #40533 RV-10
> do not archive
KCHD |
pilotdds(at)aol.com Guest
Posted: Sat Dec 27, 2014 8:44 am Post subject: G3i Supercharging |
I find it intriguing but not worth the tradeoffs .I have owned a mooney 231 a turbo 210 and comander 112 that I turbonormalized with an rcm turbo.These were very useful for two things-high density altitude takeoffs and topping weather.Flying at flight level 22-24 was uncrowded and allowed flight above icing and weather levels, many times between northeastern oregon and central california.Having said that,at this stage of my flying career the stock rv-10 is a near perfect airplane,except for the nosegear ad.The law of unintended consequences -not just flutter,but things like fuel consumpion and w&b issues will come into play-but it is an experimental.
jchang10
Posted: Sat Dec 27, 2014 2:49 pm Post subject: G3i Supercharging |
Personally, i would love to stay closer to 200 knots at altitude, which
is within design limits. More speed or altitude certainly isn't for
everyone. However, i would think having some options would be nice for
those who might have specific needs for it. For instance Beech Bonanzas
can have normalized, turbocharged, turbonormalized and maybe
supercharged engines. Cirrus has had turbocharging available for some
time, so they are probably filling a demand that is out there. I would
think having some options would be attractive to some. It just seems the
-10 is an oddball for not having similar options. As a cirrus or bonanza
owner, it's nice that they have an upgrade path, even if that means
selling their current normalized airplane for a TN or TC one.
I know there are several other mods for the -10 to gain a few extra
knots by spending plenty of additional money and time as well. This
supercharging option however gives potentially 100's of HP gain.
Someone created a turbine -10 but it's arguably impractical in our
airframe, at least for me.
I'm sure someone able to take on the supercharging upgrade could figure
out the CofG issues. Lightweight composite prop?
Jae
#40533 RV-10
jchang10
Posted: Sat Dec 27, 2014 3:03 pm Post subject: G3i Supercharging |
hi Justin, thanks for the info. I will have to see if i can rendezvous with Tom some day to check out his setup. Maybe we can convince him to do a setup in a -10!!! He will be more comfy in a -10 than in the Starduster when going to Oshkosh, too!
Cool. Thanks for the link to the forced airmotive site. That looks interesting. They have addressed CofG issues by installing gear on the back of the engine instead of on the front. Interesting that their pricing seems quite a bit more than G3i's on the face of it.
Jae
On 12/26/2014 11:04 PM, Justin Jones wrote:
[quote] Jae,
Good Luck
Justin
Kellym
Posted: Sat Dec 27, 2014 4:30 pm Post subject: G3i Supercharging |
230 mph 0kts, which is Van's design limit. You do not want to be
cruising within 5kts of risking losing a control surface.
The planes that have turbo-normalizing, etc. did the aero engineering to
move the harmonic frequency to speeds they might encounter.
Vans chose not to for whatever reasons.
On 12/27/2014 3:45 PM, Jae Chang wrote:
which is within design limits. More speed or altitude certainly isn't
for everyone. However, i would think having some options would be nice
for those who might have specific needs for it. For instance Beech
Bonanzas can have normalized, turbocharged, turbonormalized and maybe
the -10 is an oddball for not having similar options. As a cirrus or
bonanza owner, it's nice that they have an upgrade path, even if that
means selling their current normalized airplane for a TN or TC one.
figure out the CofG issues. Lightweight composite prop?
Jae
KCHD |
Rocketman1988
Posted: Sun Dec 28, 2014 4:40 pm Post subject: Re: G3i Supercharging |
I always wonder about these folks that think you can just add a 100 or more horsepower to an airframe and figure there will be no issues...
Seems to me that they didn't ask themselves what their mission profile was before they chose the -10. If you want to fly in the flight levels at speeds greater than 200 KTAS, then the -10 is probably not the aircraft for your mission.
Why try and make it something it is not? Especially when it could very well cost you your life...
