dfmoeller
Posted: Mon Jan 05, 2015 1:49 pm Post subject: Firewall Paint |
What are peoples thoughts on painting the galvanized firewall? What paint, surface prep, etc? Let me know. I'm at that point in my build where I need to paint it if its getting painted!
Doug
carlossa52(at)gmail.com Guest
Posted: Mon Jan 05, 2015 3:09 pm Post subject: Firewall Paint |
Hello, Doug
You are going to get one opinion per builder...
I had mine powder coated. I probably posted a picture in zenith.aero.
Carlos
On 5 January 2015 at 16:49, dfmoeller <dfmoeller(at)att.net (dfmoeller(at)att.net)> wrote:
[quote]--> Zenith-List message posted by: "dfmoeller" <dfmoeller(at)att.net (dfmoeller(at)att.net)>
Doug
http://forums.matronics.com/viewtopic.php?p=436663#436663
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
th-List" target="_blank">http://www.matronics.com/Navigator?Zenith-List
BARRY CHECK 6
Posted: Mon Jan 05, 2015 6:27 pm Post subject: Firewall Paint |
Doug:
You have a real problem there...
A galvanized surface creates an oxidation that prevents rust and paints from getting a foot hold.
You could lightly scuff the surface. Then wash it down immediately with MEK. Followed by an immediate coating of self etching epoxy primer. Then a sealing coat of some other epoxy paint. How long will this paint job last? I don't know.
OR you could lightly scuff the surface. Then wash it down with MEK. Then give it a spray coat of COLD GALVANIZE spray paint. Only available color - Gray. How long will this paint job last? I don't know.
What should have happened would be - Scrap the galvanized steel and replace it with a 300 series stainless steel (302 or 304). And don't paint it. This way you have corrosion protection and a fancy shinny firewall, that will not need painting ever.
Barry
On Mon, Jan 5, 2015 at 4:49 PM, dfmoeller <dfmoeller(at)att.net (dfmoeller(at)att.net)> wrote:
Doug
le, List Admin.
">http://forums.matronics.com
mcr01steiner(at)mac.com Guest
Posted: Tue Jan 06, 2015 2:39 am Post subject: Firewall Paint |
Doug
How about using an intumescent paint ?
http://contegointernational.com/industries/aerospace-aviation/
Christoph Steiner
BARRY CHECK 6
Posted: Tue Jan 06, 2015 8:40 am Post subject: Firewall Paint |
Why Chris?
1 - The firewall is already metal.
2 - You are not going to get any better fire protection than the metal.
3 - The problem is not fire proofing - It is ADHERENCE to the metal.
4 - You would have to do experiments to prove out the temperature range of the paint and the operation conditions.
5 - Since there is an expansion to this paint - Would the expansion cause a loss of bonding?
6 - What happens to the paint AFTER it expands? Does it return 100% back to its original size and bond strength? Which reflects back to Item #3.
Too many variables. The K.I.S.S. M.E. part of this build has already passed. What has to be addressed now is Adherence - Corrosion Protection and Looks.
Barry
On Tue, Jan 6, 2015 at 5:38 AM, Christoph Steiner <mcr01steiner(at)mac.com (mcr01steiner(at)mac.com)> wrote:
[quote]--> Zenith-List message posted by: Christoph Steiner <mcr01steiner(at)mac.com (mcr01steiner(at)mac.com)>
> Doug
Christoph Steiner
le, List Admin.
ding(at)tbscc.com Guest
Posted: Tue Jan 06, 2015 9:32 am Post subject: Firewall Paint |
Doug,
I myself would choose not to paint the firewall
at all. The environment is quite protected from anything corrosive, unless
you firewall mount the battery, which would require special consideration. I
expect the galvanizing will look decent for a long time as is, certainly
much better than curls of peeling paint, which I consider very possible if
not likely.
Lynn Dingfelder Corry, PA. 601XL-b Corvair
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue Jan 06, 2015 12:21 pm Post subject: Re: Firewall Paint |
I didn't paint the firewall, just the aluminum pieces that attach to it. The side facing into the cockpit is covered with an aluminized firewall blanket.
Tim
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
paulrod36(at)msn.com Guest
Posted: Tue Jan 06, 2015 2:58 pm Post subject: Firewall Paint |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hey, Barry---I have long understood the meaning of k.I.S.S. (understood, but generally not followed,) but what does the addition of M.E. stand for?
Chris--- Don't bother to paint the firewall; it's not worth the effort.
Paul R.
BARRY CHECK 6
Posted: Thu Jan 08, 2015 11:01 am Post subject: Firewall Paint |
Paul:
The way I learned it some 50+ years ago was:
Keep It Simple Stupid - Make it Easy.
I guess the 'it' part never made it into the anachronism... Maybe that was just a part of Keeping it Simple
Barry
, Jan 6, 2015 at 5:58 PM, <paulrod36(at)msn.com (paulrod36(at)msn.com)> wrote:
[quote] Hey, Barry---I have long understood the meaning of k.I.S.S. (understood, but generally not followed,) but what does the addition of M.E. stand for?
Paul R.
bryanmaxmartin(at)yahoo.c Guest
Posted: Thu Jan 08, 2015 1:29 pm Post subject: Firewall Paint |
Leave it bare. It won’t rust, there’s no paint that might burn off and it’s easier to inspect for cracks and such.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
| Quote: | On Jan 5, 2015, at 4:49 PM, dfmoeller <dfmoeller(at)att.net> wrote:
Doug
Posted: Thu Jan 08, 2015 1:32 pm Post subject: Firewall Paint |
I didn’t paint anything on the engine side. I glued an insulating blanket on the cabin side to help keep the heat and noise out.
Bryan Martin
N61BM, CH 601 XL,
Doug
Posted: Thu Jan 08, 2015 2:45 pm Post subject: Firewall Paint |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Got it. If I ever make anything simple, I'll use that. Thangya, thangya verr mush.....
