Posted: Sun Jan 11, 2015 3:43 pm Post subject: Stern post and ribs |
A question for the assembled wisdom.
The port side of the stern post has to be cut back as does the outer skin. As I understand it the stern post on the port side glues to the foam.
From the manual it appears that one should glue first and then cut back....but it looks easier to cut first and then glue.
Any thoughts?
Will
William Daniell
LONGPORT
+57 310 295 0744
jglazener
Joined: 14 Apr 2010 Posts: 76 Location: Schoonhoven, Netherlands
Posted: Mon Jan 12, 2015 7:34 am Post subject: Re: Stern post and ribs |
William,
Have a look at:
http://europaowners.org/main.php?g2_itemId=100716
Would be happy to provide further details, on or offline.
Regards, Jeroen
_________________ Jeroen
http://www.europaowners.org/main.php?g2_itemId=44165 |
Posted: Mon Jan 12, 2015 7:48 am Post subject: Stern post and ribs |
that helps. I see you cut back the port side and then bonded which was my concern (as opposed to bonding and then cutting back.
thanks again
Willl
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Jan 12, 2015 at 10:34 AM, jglazener <j.glazener(at)planet.nl (j.glazener(at)planet.nl)> wrote:
[quote]--> Europa-List message posted by: "jglazener" <j.glazener(at)planet.nl (j.glazener(at)planet.nl)>
William,
Have a look at:
Regards, Jeroen
Jeroen
http://forums.matronics.com/viewtopic.php?p=436883#436883
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
-Matt Dralle, List Admin.
pa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
FORUMS -
