bigginsking
Joined: 25 Sep 2012 Posts: 27 Location: San Diego, California
Posted: Mon Jan 05, 2015 8:03 am Post subject: Injector Cleaning |
Lycoming instructions are here:
http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201275C%20%2809-23-2008%29/Cleaning%20Fuel%20Injector%20Nozzles.pdf
I cleaned mine after 1000 hrs of operation and my fuel burn dropped by 0.5 gph when running lean of peak.
Gradually they got worse at atomizing the fuel and I wasn't able to run as lean.
Its easy enough to do that I'll probably do it at each annual.
1 hr is a bit long for the hoppes, 20 minutes is recommended, at $30 ultrasonic cleaner might be worthwhile also:
http://www.amazon.com/Professional-Ultrasonic-Jewelry-Eyeglass-Cleaning/dp/B001DKDAVW
N84WJ, RV-8, 1097 hrs
RV-8.blogspot.com
1. 11:22 AM - Cleaning fuel injectors (Charles Brame)
2. 11:49 AM - Re: Cleaning fuel injectors (vanremog(at)aol.com (vanremog(at)aol.com))
3. 02:13 PM - Re: Cleaning fuel injectors ()
4. 03:46 PM - Re: Cleaning fuel injectors (Bill Gill)
5. 03:51 PM - Re: Cleaning fuel injectors (Lyle Peterson)
6. 04:59 PM - Re: Cleaning fuel injectors (Charles Kuss)
7. 04:59 PM - Re: Cleaning fuel injectors (Charles Kuss)
________________________________ Message 1 _____________________________________
Time: 11:22:20 AM PST US
From: Charles Brame <ChasB(at)satx.rr.com (ChasB(at)satx.rr.com)>
Subject: Cleaning fuel injectors
I have an Air Flow Performance fuel injection system on my Lycoming O-320. The
AFP manual recommends cleaning the fuel injectors every 100 hours. Other than
soaking in Hoppes #9, no detailed instructions are given for cleaning the injectors.
What is the best, approved, method for cleaning fuel injectors?
Charlie Brame
RV-6A N11CB
San Antonio
_________________ Bill Judge
N84WJ, RV-8 |
JohnInReno
Posted: Mon Jan 05, 2015 11:07 am Post subject: Injector Cleaning |
Any idea on a recommended solution to use in an ultrasonic? I have seen admonitions against using volatile solutions like Hoppe's #9 or MEK but no information on what should be used. I use an ultrasonic for cleaning rifle cartridges and the solution is intended for brass but I don't know if it would be ok for injectors.
john
RV9A
On 1/5/2015 8:02 AM, Bill Judge wrote:
[quote] Lycoming instructions are here:
RV-8.blogspot.com
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
vanremog(at)aol.com Guest
