Posted: Mon Feb 09, 2015 9:53 am Post subject: NavWorx ADS600B integration to Garmin based panel -> the sag |
Folks,
Here's another update since getting the details on implementing the "Extended" mode from the NavWorx folks:
I was able to get the SL70 configured for the "Extended" mode per their instructions. The extended mode data did not interfere with passing altitude data to the MX20 as currently connected.
Their additional requirements are causing some interoperability issues.... The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud - which the SL70 is capable of delivering. The 9600 baud setting is not compatible with the MX20 - which only allows 1200 baud communications. I have a note in to NavWorx to see if they are going to allow 1200 baud in the future...I'm not the only one with this issue!
As a potential workaround, I looked at the documentation for my GNC420W. It indicates that it is capable of transmitting the altitude data to the MX20 along with the existing connection that provides lat/long. I tried that too - it doesn't work. I have a note in to Garmin to see if there is a configuration setting that I missed or if there was a printing error.
If all else fails - throw money at it.....I can replace the installed altitude encoder with one that has a 1200 baud serial port as well as the Gray code.
I'm starting to see why everyone is screaming about the cost vs benefit of ADS-B in the first place.....
Ralph
Posted: Mon Feb 09, 2015 10:55 am Post subject: NavWorx ADS600B integration to Garmin based panel -> the sag |
An update from NavWorx - they support 1200 baud communications.
Should solve all of the issues I am experiencing!
