Posted: Sat Apr 04, 2015 1:34 pm Post subject: Ring mount to subframe question |
I am mounting the rotax ring mount to the engine mounting frame using the M10x110 hex head bolts.
The issue is that the M10 bolts have quite a lot of slop in the rotax ring mount, my guess is that the rotax ring mount holes are about 1/2 to 1 mm larger than the bolts.
Is this normal?
The bolts fit perfectly in the Europa engine mounting frame.
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
Posted: Sat Apr 04, 2015 6:10 pm Post subject: Ring mount to subframe question |
Yup....the rotax ring mount has an 11mm hole and the engine mounting frame is 10mm.
Can anyone help?
Will On Apr 4, 2015 4:37 PM, "William Daniell" <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:[quote]I am mounting the rotax ring mount to the engine mounting frame using the M10x110 hex head bolts.
Is this normal?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
| [b]
tonyrenshaw268(at)gmail.c Guest
Posted: Sat Apr 04, 2015 7:10 pm Post subject: Ring mount to subframe question |
Gidday Will,
Have you inserted the short steel reinforcements in the fuselage engine frame, because if you have the wall thickness has now increased dramatically, and the attachment forces now are also shared by the bolts holding them in situ, as I vaguely recall. I'd be surprised if you couldn't open them out.
Tony Renshaw
On 5 Apr 2015, at 4:09 am, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Can anyone help?
Will On Apr 4, 2015 4:37 PM, "William Daniell" <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote: | Quote: | I am mounting the rotax ring mount to the engine mounting frame using the M10x110 hex head bolts.
Is this normal?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
a-List"">http://www.matronics.com/Navigator?Europa-List
Posted: Sun Apr 05, 2015 2:41 am Post subject: Ring mount to subframe question |
Tony
Sadly thats not the problem...its the rotax supplied ring mount (suspension frame in rotax parlance) which has 11mm holes and should have 10mm holes...
I thinking I got the wrong part number...maybe there are two different frames...
Will On Apr 4, 2015 10:12 PM, "Tony Renshaw" <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:[quote]Gidday Will,
Tony Renshaw
Can anyone help?
Is this normal?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
neveyre(at)aol.com Guest
Posted: Sun Apr 05, 2015 11:48 am Post subject: Ring mount to subframe question |
Hi Will,
That is correct, the holes in the Rotax ring mount are 11mm, 10mm in the Europa mount, and 10mm bolts......... not clever ? I put a thin 10mm steel washer between the Europa mount and the Rotax ring mount, prevents the ring mount from getting chafed. Put grease or thick oil on the bolt shank, they are not plated ?
Nev.
Posted: Sun Apr 05, 2015 10:14 pm Post subject: Ring mount to subframe question |
Posted: Tue Apr 07, 2015 4:13 am Post subject: Ring mount to subframe question |
Just for the general information of the group I spoke to Bud yesterday on the subject.
I measured everything again and definitely we have 10mm bolts going though a 11mm hole on the rotax ring mount (suspension frame).
He said that it's OK per design to put the 10MM bolt into the 11mm hole on the ring mount and he has 10 year old aircraft with no signs of fretting to prove it.
I guess it goes against every instinct - or at least my instincts - but there it is.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Sat, Apr 4, 2015 at 4:33 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Is this normal?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
| [b]
