Firewall Passthroughs - Redux
kearney
PostPosted: Mon Apr 06, 2015 3:52 pm    Post subject: Firewall Passthroughs - Redux Reply with quote
Hi
Quite some time ago I posted a query regarding firewall pass throughs for control cables.
Here is what I used from ACS: https://www.aircraftspruce.com/catalog/appages/6000metalgrommets.php?clickkey=729558
There weren't easy to find on the ACS website but they work just great. The pix is a bit misleading - three will fit within the spacing of the firewall insert. I had to clock the middle insert so it would ft but that was quite easy to do,.
If you use these, be sure to get the right size "ball" insert for your control cables.
Cheers
Les
