BobbyPaulk(at)comcast.net Guest
Posted: Sat Apr 18, 2015 2:46 pm Post subject: Fuel Pressure |
List
Today was the first flight on the Jabiru 3300 since my off field landing back in December ( due to both ignition coils being wiped out ).
I noticed the fuel pressure had dropped from 1.8 ~ 2.1 to 1.4 plus or minus. I have my low pressure alarm set at 1.8 so I kept getting an alarm unless I kept the electric boost pump on.
The engine has not been run since the first of December 2014. Question: Should I be concerned about the 1/2 lb. pressure drop or is it a case of TMI ( too much information ).
I know of at least two guys that do not even have a fuel pressure gauge.
Anyone have any idea how long the engine driven fuel pump is good for. It has 236 hours on it but it is at least 8 years old.
By the way I noticed my maximum RPM on take off went from 2600 to 2720 just before rotation speed. I attribute that to the new Rotek E-mag and the newer Honda ignition coil.
Bobby ( age 76 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 236 hrs.
zeprep251(at)aol.com Guest
Posted: Sat Apr 18, 2015 5:11 pm Post subject: Fuel Pressure |
Have 930 hrs on original pump, no pressure gauge, but turning 3100 on take off.
On Apr 18, 2015, at 6:43 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
[quote]List
Bobby ( age 76 )
Zodiac 601 XL "B"
uEngine-List"">http://www.matronics.com/Navigator?JabiruEngine-List
//forums.matronics.com
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Fri Apr 24, 2015 8:41 am Post subject: Re: Fuel Pressure |
Bobby,
For what it's worth, my fuel pressure varies from 1.5 to 3.5 PSIA on my Dynon EMS charts. This includes both electric pump on and off. There is a lot of variation, likely from the 40 psi transducer trying to read in the extreme low of its range. My low fuel pressure limit is set at 1.5 PSIA so it rarely chirps. I would think that a sudden step change is something to look into, but if my limit was set at 1.8 PSIA, the alarm would be going off all the time.
Dave
_________________ David Gallagher
Cincinnati, OH area |
BARRY CHECK 6
Posted: Fri Apr 24, 2015 5:32 pm Post subject: Fuel Pressure |
Are you sure it is PSIA?
Pressures you would read would be in PSIG!
So if you are really reading PSIA you are way too low... About 13.2 PSI low.
Barry
On Fri, Apr 24, 2015 at 12:41 PM, DaveG601XL <david.m.gallagher(at)ge.com (david.m.gallagher(at)ge.com)> wrote:
[quote]--> JabiruEngine-List message posted by: "DaveG601XL" <david.m.gallagher(at)ge.com (david.m.gallagher(at)ge.com)>
Bobby,
Dave
David Gallagher
Zodiac 601 XL-B: flying, 280+ hours now
Next project under construction: Finish my father's Aircamper
http://forums.matronics.com/viewtopic.php?p=441231#441231
ne-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
">http://forums.matronics.com
le, List Admin.
