Compressing Rubber Mounts
MJKTuck(at)cs.com
PostPosted: Sun Apr 19, 2015 2:23 pm    Post subject: Compressing Rubber Mounts Reply with quote
I'm busy rehanging the engine with fresh rubber mounts.
Is there an easier way of compressing the rubber mounts such that you
can get the threads of each bolt to show through enough to put the
washers and nut on?
When I installed the engine first time round I seem to remember
struggling with some kind of clamp but I can't remember what I did now.
I figured this must be a common problem so perhaps I've missed a trick.
Any help would be appreciated.
Martin Tuck
JonathanMilbank
PostPosted: Sun Apr 19, 2015 3:49 pm    Post subject: Re: Compressing Rubber Mounts Reply with quote
What compressing? I don't understand. Admittedly I have a Classic with a different engine cradle frame, but I can't conceive that the Lord mounts would be greatly different. Yes they are fiddly and difficult to assemble and keep from falling apart while trying to hang the engine bearer onto the undercarriage frame, but if the engine is suspended at a suitable angle using straps and a hoist, with slow careful manoeuvring it all comes together until enough thread pokes through to engage the nuts on the bolts.
The last time I did this (about the 5th time), I fastened little cable tie-wraps tightly around the bolt shanks after assembling the Lord mounts into the engine bearer. This helped to minimise the tendency of the Lord mount assemblies to disintegrate while manoeuvring.
Slowly and carefully seemed to work for me.
MJKTuck(at)cs.com
PostPosted: Sun Apr 19, 2015 6:27 pm    Post subject: Compressing Rubber Mounts Reply with quote
Thanks Jonathon,
The instructions say that the four AN5-40 mounting bolts must be
tightened fully to compress the rubber anti-vibration mounts (MT04) onto
the steel spacers MT03. That is the compressing I refer to. There is
probably about .20 inch of compression needed on each rubber mount -
about .40 inch in total which is about the about amount of thread needed
to allow the nut to grab once the washers are on. In their 'relaxed
state' when assembled there isn't enough thread poking through to engage
I assume that the steel spacers set the distance between the large cap
washers MT02.
I can use longer bolts to get the rubbers compressed and then I like the
idea of the tie wraps to keep them compressed while I switch out the
bolts to the correct length ones.
I think later manuals call out AN4-41 bolts so I suspect this was a
problem in the past.
Martin
http://forums.matronics.com/viewtopic.php?p=441011#441011
JonSmith
PostPosted: Sun Apr 19, 2015 10:02 pm    Post subject: Re: Compressing Rubber Mounts Reply with quote
Hi Martin, I remember having the exact problem you describe when I built mine - the uncompressed assembly being longer then the bl(at)(at)dy bolts!
I seem to remember assembling and compressing the mounts in a vice off the aircraft with the nuts and bolts, binding them tightly with locking wire, removing the bolts, assembling onto the aircraft, snipping the locking wire off then finally tightening them permanently. (Then finding the whole things got to come off again for something else....!). Took a while to perfect the technique and doubtless most other people have got a far more elegant method.....!
G-TERN
Classic Mono
grahamsingleton(at)btinte
PostPosted: Sun Apr 19, 2015 11:34 pm    Post subject: Compressing Rubber Mounts Reply with quote
Jonathan
the rubber mounts on the Classic were not "Lord", unless supplied by Rotax. The ones that came with the Classic were much
harder. rubber. They came from a different supplier.
Graham
On Monday, 20 April 2015, 7:04, JonSmith <jonsmitheuropa(at)tiscali.co.uk> wrote:
--> Europa-List message posted by: "JonSmith" <jonsmitheuropa(at)tiscali.co.uk (jonsmitheuropa(at)tiscali.co.uk)>
G-TERN
Classic Mono
http://forums.matronics.com/viewtopic.php?p=441032#441032
< --> http://forums.matronics.com</ -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
davidjoyce(at)doctors.org
PostPosted: Mon Apr 20, 2015 12:12 am    Post subject: Compressing Rubber Mounts Reply with quote
Martin, A couple of those long adjustable clamps that carpenters use for compressing things like joints on chairs, did the job for me. Regards, David Joyce, GXSDJ
On 2015-04-19 23:22, Martin Tuck wrote: [quote]
--> Europa-List message posted by: Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)>
Is there an easier way of compressing the rubber mounts such that you can get the threads of each bolt to show through enough to put the washers and nut on?
When I installed the engine first time round I seem to remember struggling with some kind of clamp but I can't remember what I did now. I figured this must be a common problem so perhaps I've missed a trick.
Martin Tuck
ttp://www.matronics.com/Navigator?Europa-List
ics.com
PostPosted: Mon Apr 20, 2015 1:15 am    Post subject: Compressing Rubber Mounts Reply with quote
I remember what I did now, (from 20 years ago!) I used longer bolts and extra washers.
Graham
On Monday, 20 April 2015, 9:11, "davidjoyce(at)doctors.org.uk" <davidjoyce(at)doctors.org.uk> wrote:
Martin Tuck
ics.com
johnwigney(at)windstream.
PostPosted: Mon Apr 20, 2015 6:31 am    Post subject: Compressing Rubber Mounts Reply with quote
Hi Martin,
It is a long time ago, but I think that I bought some 1/4" hardware
threaded rod and (i) cut it into 4 judicious lengths.
(ii) I then bolted the whole assembly up tight at each mount.
(iii) I then removed one threaded rod at a time and inserted the correct
bolt.
I think that works.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
Subject: Compressing Rubber Mounts
washers and nut on?
Martin Tuck
PostPosted: Mon Apr 20, 2015 6:49 am    Post subject: Compressing Rubber Mounts Reply with quote
I think it does work John
I did something similar
Graham
On Monday, 20 April 2015, 15:32, John Wigney <johnwigney(at)windstream.net> wrote:
--> Europa-List message posted by: John Wigney <johnwigney(at)windstream.net (johnwigney(at)windstream.net)>
Hi Martin,
bolt.
I think that works.
Cheers, John
From: Martin Tuck<MJKTuck(at)cs.com (MJKTuck(at)cs.com)>
washers and nut on?
Martin Tuck
dpark748(at)icloud.com
PostPosted: Mon Apr 20, 2015 11:38 am    Post subject: Compressing Rubber Mounts Reply with quote
Ditto
Dave Park G-LDVO
On 20 Apr 2015, at 15:46, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]I think it does work John
Graham
On Monday, 20 April 2015, 15:32, John Wigney <johnwigney(at)windstream.net (johnwigney(at)windstream.net)> wrote:
Hi Martin,
bolt.
I think that works.
Cheers, John
washers and nut on?
Martin Tuck
;   -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
a-List"">http://www.matronics.com/Navigator?Europa-List
MJKTuck(at)cs.com
PostPosted: Mon Apr 20, 2015 6:21 pm    Post subject: Compressing Rubber Mounts Reply with quote
Thanks all for suggestions.
I managed to get them all done tonight using a combination of tie wraps
and a small clamp along with longer bolts to compress the rubbers first.
Then replaced each one with the aircraft grade AN5 bolt.
Took about an hour and it wasn't easy as the tie wraps kept slipping off
the curved cap washers at first.
The bottom ones were easier as the weight of the engine compressed one
side of the rubber mount enough that I could get the washers and nut on.
All the best,
Martin
On 4/20/2015 9:30 AM, John Wigney wrote:
Hi Martin,
correct bolt.
I think that works.
Cheers, John
washers and nut on?
Martin Tuck
