Fred Klein
Posted: Fri Apr 17, 2015 4:35 pm Post subject: First Fueling |
Gents…
Who among you mono-builders can remember how much fuel was needed…when introduced to our beloved rotomolded fuel tanks for the first time…in order for fuel to flow thru the selector valve (located per build manual) and thence aft to assorted pumps and filters?
I’ve put in 5 (US) gallons and can get nary a drop out of my gascolator which is mounted aft of the baggage bay and considerably lower than the main and reserve fittings on the selector valve.
(Both main and reserve fuel drains function fine, and the aircraft is sitting on it’s main LG and tail wheel.)
A corollary question is: how much unusable fuel is carried aboard a mono with standard tank?
Fred
rlborger(at)mac.com Guest
Posted: Fri Apr 17, 2015 5:01 pm Post subject: First Fueling |
Fred,
To answer your first question: I don’t know as it will depend on your aircraft.
BUT, you will have to add more than 5 gallons, which is just about enough to cover the hump. You will need to add sufficient fuel to a level well above the fuel selector valve. With a monowheel sitting on its tail, probably more than half a tank. Once you reach a level over the valve it should fill the remainder of the line down to the pumps.
Hope these tidbits help.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Apr 17, 2015, at 7:34 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
Gents…
Fred
class="">http://www.matronics.com/Navigator?Europa-List
class="">http://forums.matronics.com
class="">http://www.matronics.com/contribution
Fred Klein
Posted: Fri Apr 17, 2015 5:23 pm Post subject: First Fueling |
Thanks Bob…I'm taking baby steps w/ the volatile fluids…BTW, here on my island, I can get ethanol-free fuel at marinas…F. | Quote: | On Apr 17, 2015, at 5:58 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
Fred,
Gents…
Fred
Posted: Fri Apr 17, 2015 5:39 pm Post subject: First Fueling |
Fred,
Nothing wrong with baby steps and gasoline (of any flavor). Take it easy and careful.
You are a lucky fellow to be able to find ethanol-free fuel. We have a marina on Lewisville Lake, but you have to drive up in a boat to get fuel there. I generally stick with 100LL and accept that I’ll have to change the oil and check the plugs.
On Apr 17, 2015, at 8:23 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
budyerly(at)msn.com Guest
Posted: Fri Apr 17, 2015 8:17 pm Post subject: First Fueling |
Fred,
Gascolators do not prime well. I would check for an air leak. Andairs are well made and pull a vacuum. The standard diaphragm pump does not pull air well enough for some brands. If it won't prime the engine with 2.5 gallons on the ground, will it do it in the air?
Ground Test war story: Ran the main dry, flipped to aux and it would not self prime without more head pressure. Could not find a leak but the gascolator was installed slightly above tank bottom level. With 10 gallons it would prime. It was a trigear. I know they have used gascolators in a/c for ever, but they should be the lowest point in the system. That is, the bowl outside, below the belly.
That is why I don't use them and won't install one. To easy to screw up. Besides, water does not condense in the tanks and filters work as well. Most experimental takeoff accidents are fuel and engine related. Make them flawless then test for fuel exhaustion, on one side then switch and hopefully keep running.
Clean your fuel lines before hooking to the engine. A common assumption is the filter missed some dirt/ debris and the gascolators just prior to the engine caught it. Flush and flush again.
My two cents.
Bud
Sent from my Verizon Wireless 4G LTE DROID
On Apr 17, 2015 8:39 PM, Fred Klein <fklein(at)orcasonline.com> wrote:
Gents…
Fred
| Quote: | http://www.matronics.com/Navigator?Europa-List
onics.com
Fred Klein
Posted: Sat Apr 18, 2015 6:56 am Post subject: First Fueling |
Bud…you wrote: | Quote: |
Bud…now we begin to descend down the rabbit hole of the testing and operational phase of a one-off, non-standard engine installation...recall that my engine is MPEFI’ed…my two (in parallel) fuel pumps are hi-pressure type and (apparently) do not have the ability to “suck” fuel on the input side..
| Quote: | If it won't prime the engine with 2.5 gallons on the ground, will it do it in the air?
An excellent question…for which prudence requires an answer “on the ground”. | Quote: |
With my mono resting on the LG & tail wheel, I’m preparing a diagram with measured elevations of the various points in the fuel system starting from the tank outlet to the hi-pressure fuel pump outlets…However, by eye, it is apparent that the high point in the system is the selector-valve-main-tank-outlet…(selector valve having been installed as per manual). At this stage of the game, I have concerns that if main tank runs dry to exhaustion and I move selector to reserve, will fuel continue to flow? | Quote: |
I’ve been unaware of your thoughts on gascolators…I confess to have one solely because of the frequent mention of them on this list and their apparent widespread use.
| Quote: | Most experimental takeoff accidents are fuel and engine related.
I am indeed aware of that fact.
| Quote: | Make them flawless then test for fuel exhaustion, on one side then switch and hopefully keep running.
Exactly my intention... | Quote: |
And what do you recommend for a cleaning agent?
Grossly undervalued…your knowledge is priceless…
Many thanks,
Fred
PS: A local A&P recommends adding a Facet pump to ensure that fuel gets to my hi-pressure pumps…my engine builder recommends bleeding the lines just upstream of the hi-pressure pumps…for the moment, I’m looking for simplicity and reliability.
Posted: Sat Apr 18, 2015 11:14 am Post subject: First Fueling |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Fred,
I recall your non standard engine, but am confident in the quality of your testing and evaluation.
I don't intend to start a gascolator war, because they are a fine piece of equipment for tractors, metal high wing aircraft with no prime pumps and constant water problems or aircraft with low wings and the gascolator installed and tested with a thirty year track record like a Piper. They are fine for the aircraft with tank drains, and long runs of line that fill with water while sitting. I prefer Andair's gascolators as they work well up to high pressure, seal well, but they are not a visible junk trap. His filters are built into the unit and replaceable. On the ones we've installed in RVs, we put them on the engine side of the aux fuel pump and have had no problems. His pumps are great also.
You’re A&P friend is correct in having a high volume / low pressure pump feed the engine pressure pumps. The Facet pump indeed sucks well. (So does a Piersburg). On the initial installation of fuel injected engines, we used to have to have a header tank. Auto and Marine experience now shows a primer pump at the tank bottom level, will feed the volume needed. However, the volume of the high pressure pumps must be satisfied and proper plumbing to prevent circular flow when one pump fails. Your EFI manufacturer should have that information. As you know, autos now have the high pressure pump in the fuel tank and run pressure lines forward to the engine with the regulator after the fuel rail which prevents starvation and priming problems. Problem with our little aircraft is the fuel selector has to be forward of the pumps because they are not normally pressure tested and submerged fuel pumps are not possible. You probably have already reviewed SDS for their fuel system installation notes, but if you haven't: www.sdsefi.com. They really helped us with an RV as well as the Jason Parker engines. Their stuff works. See their cute little surge tank in their tech section. Small and affordable.
Cleaning the fuel line used to be done with denatured alcohol but since auto fuel is now filled with ethanol and excellent cleaning and plastic ruining addatives, I use plain old ethanol laced auto fuel for my flushings. It does stain if you get a leak and it stinks a bit, but boy does it clean the crud out of fuel lines that may have been sitting on the shelf for a while. Not uncommon to get brown fuel out of an R-14 fuel injection hose.
Our procedure:
Start with clean gas cans and fresh fuel always.
1. We fill the tank nearly full, about 15 gallons (and watch for leaks in the fill neck and bosses).
2. Slosh the plane around
3. Lift the tail and disconnect the fuel line from the engine pump or fuel regulator.
4. Look for static leaks again.
5. Turn on the electric boost pump (pumps about 30 gal per hour or more).
6. Calibrate the fuel flow and sight gauge as appropriate.
7. Change 5 gallon tanks out.
8. When the fuel stops flowing out of the main, switch tanks and exhaust again.
9. Refuel through a Mister Funnel or similar filtering fuel funnel.
10. Repeat two more times.
Repair anything that is wet with fuel. Use care not to overtorque fuel clamps and use the proper type if using other than automotive hose (cheap kind you throw away after a few years).
Cheers Fred
Bud
Fred Klein
Posted: Sun Apr 19, 2015 12:45 am Post subject: First Fueling |
Bud…thanks so much for your additional comments and fuel system test procedure…see my indents below…Fred | Quote: | On Apr 18, 2015, at 12:13 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
Fred,
Your confidence is much appreciated. | Quote: |
The 2 hi-pressure EFI pumps I have each have internal check valves which I would rely on to prevent circular flow when one pump fails or is turned off…I am checking their flow rates so I can be sure I order a Facet w/ sufficient flow rate.
| Quote: | As you know, autos now have the high pressure pump in the fuel tank and run pressure lines forward to the engine with the regulator after the fuel rail which prevents starvation and priming problems. Problem with our little aircraft is the fuel selector has to be forward of the pumps because they are not normally pressure tested and submerged fuel pumps are not possible. You probably have already reviewed SDS for their fuel system installation notes, but if you haven't: www.sdsefi.com. They really helped us with an RV as well as the Jason Parker engines. Their stuff works. See their cute little surge tank in their tech section. Small and affordable.
I had NOT been aware of their fuel installation notes…thanks for the reference…very helpful stuff. | Quote: |
Not knowing this, I put 15 gallons of ethanol-free gasoline in the tank…paid a hefty premium over car gas to boot…oh well…
| Quote: | It does stain if you get a leak and it stinks a bit, but boy does it clean the crud out of fuel lines that may have been sitting on the shelf for a while. Not uncommon to get brown fuel out of an R-14 fuel injection hose.
My hose is SAE J30 R9 fuel injection hose w/ the blue Teflon liner…it SEEMED to be clean as a whistle when I installed it.
| Quote: | Our procedure:
Great procedure…a keeper…
Wish I could fly down to Sun ’N Fun but I’m wanting to push ahead here
Best to everyone who shows up…BTW, had a GREAT ride w/ Kevin Klinefelter two weeks ago when he demonstrated his high-flying 914 above the High Sierras.
Fred
Cheers Fred
Bud
[quote]---
Fred Klein
Posted: Thu Apr 30, 2015 6:36 am Post subject: First Fueling |
A few days ago I posted of my frustrations at being unable to get fuel to my MPEFI engine, notwithstanding dual parallel hi-pressure fuel pumps, requisite filters, a gascolator, proper venting, etc. I feared I was headed down the dark, winding rabbit hole implicit with any one-off, unique engine installation.
After much testing and head scratching, I finally found that the fuel pumps…”accessible” in the context of experimental aircraft, but nonetheless more challenging to remove than anticipated…installed by yours truly…had their polarity reversed…bingo.
…no need to spell out the lesson here…
w/ much chagrin,
Fred
kingsnjan(at)westnet.com. Guest
Posted: Thu Apr 30, 2015 2:14 pm Post subject: First Fueling |
Voilà Fred
Kingsley
