bob88
Posted: Sat Jun 13, 2015 8:38 am Post subject: grounding strap |
Where is best to attach the engine to airframe grounding strap. I get that engine end can be to a case bolt. Where is best airframe grounding point (should be two actually)?
Posted: Sat Jun 13, 2015 10:15 am Post subject: grounding strap |
There are tags on the engine mount for hat, but make sure you remove the powder coating.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
| Quote: | On Jun 13, 2015, at 12:38 PM, bob88 <marty.crooks(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=443456#443456
Posted: Sat Jun 13, 2015 11:52 am Post subject: grounding strap |
Ground the engine to the grounding lug on the starter using the same gauge
wire you have running to the starter. The starter is the highest current
draw so it needs the best ground. I used #2 welding wire to the starter
solenoid on the firewall, then #4 wire for both the starter solenoid to
starter run and firewall ground lug to starter ground lug run. Both starter
and alternator wires run through a piece of fire sleeve under the left
cylinder bank.
You should create a primary ground lug on the firewall. Location as you see
fit but having it in the upper half on the left side works. A ground block
like this provides a heavy lug for a good ground for both sides of the
firewall and a bunch of ground tabs for the cabin side of the firewall:
http://www.aircraftspruce.com/catalog/elpages/elecsystem07-03463-6.php?click
key=97423
Carl
rleffler
Posted: Sat Jun 13, 2015 11:57 am Post subject: grounding strap |
My forest of trees tabs has a bolt going through the firewall. My engine ground goes there as well as ground to the engine mount. All my grounds terminate there.
Bob
Sent from my iPad
_________________ Bob Leffler
N410BL - Phase I
