mppalmer(at)aol.com Guest
				 Posted: Fri Oct 23, 2015 12:08 pm    Post subject: change in rudder trim |
				 	  | Quote: | 	 		   cable spring tension changed, rudder cable slipped,
  wear in the rudder hinge pin, the wheels or wheel pantsĀ
  aren't aligned, engine mounts, hatch seal burbling out air,
  nose wheel slightly cocked, cowling pins worn, aflap position has changed
 Thanks. The first thing I thought about was a broken engine mount. But nothing that I can see. (I had a friend tug on the prop from different angles to see if anything popped open.)
 As for the other catastrophic changes, since I didn't touch most of those, I don't see how they changed.
 But I have observed that an inner cowl hinge (one near the nose) has partially broken thru. Been meaning to replace it. It's possible that that part of the cowl could be opening up in flight, causing a yaw. (I would expect that I would see that, or see some evidence of chaffing if it were lifting open.)
 I'll report back if that fixes the rudder trim problem after I replace the hinge. I don't like it when things suddenly change without an obvious cause.
 Mike <><
  |  | - The Matronics Glasair-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Glasair-List |
