commanderpic
Posted: Thu Jan 14, 2016 5:23 am Post subject: N680rr info |
Barry what records do you have for N680RR >> And do you know why it is showing on the FAA site as a 680F and not 680FP??? Seems several of the "FP's" are showing as "F" only... May be you can cast some light on the issue...
| - The Matronics Commander-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
barry.collman(at)air-brit Guest
Posted: Thu Jan 14, 2016 5:38 am Post subject: N680rr info |
Hello "commanderpic"!
Would be nice to know your 'proper' name!
You're right and there are a number of 680F(P) models that are listed
as 680F.
Sometimes, the FAA aren't too good at getting the Models correct, but
then admittedly they can only work with the documentation received.
However, in the case of the 680F vs 680F(P), it is more easily
understood.
The 680F(P) serial numbers are actually as a Model 680F.
The pressurization package [hence the "(P)"] was an optional item for
the 680F and they both share the same s/n sequence.
See http://twincommander.org/aircraft-models/speedline/model-680fp/
for further info.
Barry Collman
