RV-10 Centerline @ Wingtip
philperry9
PostPosted: Tue Feb 09, 2016 6:22 pm    Post subject: RV-10 Centerline @ Wingtip Reply with quote
For those of you who have installed the magnetometer in the wing tip, are we all in agreement that the outboard wing rib is perfectly parallel to the centerline of the aircraft?
The Garmin magnetometer states that it needs to be within 1/2 degree of the centerline (much tighter demands than the Dynon) and I'm hoping I can base that centerline measurement off the outboard side of the wing rib.
Phil
 Filesize:  80.2 KB
 Viewed:  3074 Time(s)
john(at)trollingers.com
PostPosted: Wed Feb 10, 2016 4:16 am    Post subject: RV-10 Centerline @ Wingtip Reply with quote
I mounted mine out there, but leveled it with washers on the mounting bolts using a digital level.  Works great.
On Tue, Feb 9, 2016 at 9:19 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Phil
